10-17-2014, 08:46 PM | #1 |
Rep 41
Stumbling on boost
I'm now running into another issue after my turbo swap and. The car seems to stumble over its self randomly at idle. It also as if boost comes in and out when i roll on the throttle. I've also done new plugs along with the turbo swap. Its almost as if they're fouled up
Is this something that could be related to the JB4? I did throw a code for the catalytic converter ( im cat less) I will try data log tomorrow |
10-18-2014, 06:58 AM | #2 |
Rep 41
I've been thinking about this over night and it hit me that we just threw the o2 sensors back in. They may not be in the correct pipe since I forgot to label them. I'm catless on jb4, is this something that could relate to the sputtering problem?
10-20-2014, 08:23 PM | #3 |
Rep 41
Just filling everyone in in case they run into the same issue. The Primary o2 sensors were switched up causing it to run terrible
10-20-2014, 09:09 PM | #5 |
Rep 41
10-20-2014, 09:42 PM | #6 |
Rep 141
just for a heads up if you run e85 i would suggest the NGK plugs.. and did you get the bmw branded bosch or just the bosch.. i once ran bosch plugs that are made for our cars that i bought from autozone.. they were bosch but not the bmw version and they went bad quick.. they didnt look to bad after removing, but i upgraded to NGK plugs things ran better, then after i gapped my plugs supa smooth
10-21-2014, 05:43 AM | #7 | |
Rep 41
Will the botch plugs just get burnt up fast using e85? |
10-21-2014, 12:15 PM | #8 |
Joint Chiefs of Staff
24198
Rep 190,805
This is a very common issue when guys install catless DP
