10-16-2014, 05:27 PM | #1 |
templarklimek
142
Rep 868
7k miles and running hot
Gents,
I have only 7K on my CPO'ed M3. It a stripper with test pipes and bolt on mods and ECU tune(dinan), This is my 3rd E92 M3, none of the others ever ran hot. But this one when I run up to 8k RPM's get warm immediately. The temp gauge jumps up a tick from the normal around 210 to maybe 230 from just a quick run up on the feeder. Should I be concerned? Thanks for your thoughts and advice. |
10-16-2014, 05:43 PM | #2 |
63387
Rep 24,678
What type of oil is used ?
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
10-16-2014, 07:43 PM | #5 |
980
Rep 4,001
You bought her used right? Maybe previous owner had a pulley installed and dealer overlooked it. I would consider it normal if it has a pulley and you're redlining her.
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
10-16-2014, 07:59 PM | #6 |
templarklimek
142
Rep 868
good point, I have dinan pulleys ready for install actually. I had the same thought. Again it's weird, my previous M3 had pulleys and no increase in temp.
I'll do oil change and get cooling system. I'm a life long BMW customer with 12 cars bought. I'm confident they will address this. |
10-17-2014, 02:41 AM | #7 |
1056
Rep 1,459
Mine does this too. Second M3 and stock. Comes back down to 210 pretty quickly. From the research I did, it didn't seem to happen to every car, but it happened to enough cars not to worry.
10-17-2014, 01:55 PM | #9 |
18
Rep 241
Drives: 2011 E93 M3
I experience this as well. I thought my issue may be because the AA SC intercooler requires moving the oil cooler lower to make room. Possibly reducing air flow thru the oil cooler. I think they have redesign the Intercooler on their newer kit. Now they are wider, and not at tall.
Temps do come back down soon enough though.
2013 F10 M5/TTFS CUSTOM TUNE/PURE S1 TURBOS/METH/AMS CL DPS/RPI CATBACK/KW SLEEVE OVERS/RPK FRONT LIP/M PERF REAR SPOILER/20" LOMA SUPERTEC SUPERLIGHTS
10-17-2014, 02:23 PM | #10 |
templarklimek
142
Rep 868
10-17-2014, 02:31 PM | #11 |
Dingleberries
76
Rep 1,246
I have a pulley and I don't see my temperatures spike and decline as stated. I can get some higher (but still with-in normal operating range) when I run it hard for an extended period of time, and it needs to be fairly warm out...
10-17-2014, 07:20 PM | #13 |
templarklimek
142
Rep 868
Oh Jeez, relevant point. I will definitely do this thru dealer operations so I have history on this issue with BMW actual. Thank you. I'll have them note on service my concern about this may be bearing issue for the future.
10-18-2014, 04:29 AM | #14 |
2511
Rep 4,381
Bearings would be a very unlikely cause of the phenomenon you are seeing....there is some other problem, a sticking oil cooler thermostat or something like that.
10-18-2014, 07:46 AM | #15 |
1056
Rep 1,459
A lot of bad advice on here. If you are at 230 on spirited driving, then you are fine. Go check your owners manual and see what it says for normal operating temperatures (hint: you're within specs). Read other posts on this issue and you'll find many have the same phenomenon and have since day 1.
10-18-2014, 08:28 AM | #16 | |
63387
Rep 24,678
10-18-2014, 08:36 AM | #17 |
Grown Azz Man
429
Rep 3,021
I've been running my Dinan pulley for over 40k miles and many track days. I've never seen a spike like you're describing. Make sure the oil cooler is clean and not blocked by plastic or paper.........Phil
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
10-18-2014, 12:58 PM | #20 | |
templarklimek
142
Rep 868
