10-13-2014, 09:07 AM | #2 | |
67
Rep 373
2010 E90 M3 ESS-vt1 550 SOLD but never forgotten
2015 F80 M3: JB4 and MPE 2022 G80 M3CX: At port |
10-13-2014, 09:36 AM | #3 |
Moderator
7517
Rep 19,368
Strange.
One thing to keep in mind is that if you hold the button down it will be set to the curent settings. So it is possible to inadvertently program it if, for example, you hold it too long while intending to change cruise control speed or adjust volume. Not saying that's what is causing your issues, but it is something that could catch someone off guard and confuse them, and could lead to symptoms similar to these. |
10-13-2014, 09:42 AM | #5 |
21121
Rep 20,741
Drives: 2021 911 turbo
10-13-2014, 09:53 AM | #7 |
X3M Comp
444
Rep 716
I just remember in my E90 M3 a lot of the settings were key dependent. So I had basically labelled the keys with the labels that came in the manual. It appears BMW did not give us those sticky labels this time.
I gotta fabricate something for his/her keys... |
10-13-2014, 09:55 AM | #8 |
346
Rep 1,656
Get a pink cover for one of them, then have your wife choose whatever color she wants.
10-13-2014, 12:51 PM | #9 |
IG@i.am.wah
2779
Rep 3,815
Drives: M2 CS
My M button has reset to default twice since I got the car in August. I only use one key... the other is tucked away in my desk.
10-13-2014, 04:09 PM | #10 |
Rep 14
this happens to me and I'm using the same key. I've seen it happen as I'm actually driving..it also tends to shift the DCT setting on it's own as well from time to time!
10-13-2014, 06:32 PM | #11 |
1030
Rep 1,190
You can set up a driver profile in iDrive so that it keeps your settings no matter which key you choose. If you have multiple drivers for your M, you can set up a driver profile for each one and assign it to one of the radio preset buttons.
2015 M3, 2005 330i ZHP, 2015 228i 6MT Track Handling Pack, 2007 M Coupe (Sold)
10-13-2014, 06:50 PM | #12 |
1003
Rep 3,396
Love those radio presets, they can do everything!
10-14-2014, 10:43 AM | #13 |
M3AT LOVER
322
Rep 1,853
Not everything. I have not been able to make the buttons to toggle between regular HUD and M HUD. Would love to be proven wrong though.
BTW, my M buttons settings have no problem at all. I use the same key fob all the time. If you save it when you are in manual DCT mode, that is what it will be when you press the M button.
2015 F80 M3 | SSII ext SO int | M-DCT | 19" Black Wheels
