European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      10-07-2014, 01:14 PM   #1
Gac101177
M4-SAHD
Gac101177's Avatar
512
Drives: M3
2015 BMW M4  [10.00]
M4 Service and Open Campaign - Can Terminator (Service Bulletin - SIB)
Hello Thanks to forum member RobRed i was able to get my SIB done in case anyone miss it here
      10-07-2014, 04:46 PM   #2
DocWeatherington
DocWeatherington's Avatar
Drives: F90 CP
23 Bmw M3  [10.00]
What exactly is this for?
      10-07-2014, 05:01 PM   #3
redfox
INSTAGRAM: @yaasplease
redfox's Avatar
166
Drives: 2015 YMB M4
silent "recall". This is one of them. There are two right now.
EDIT: as pointed out by another forum member. This is not a full on recall. My understanding of a silent recall is one where the customers do not have to be made aware of the situation. The dealership quietly fixes it the next time vehicle is in for service. That usually means the issue is nothing major. I wanted to clarify this point.
2015 ///M4: M/Vorsteiner Aero, P3Cars, HRE R101, Dinan S2, Coils & Intake; Eis/Akra Exhaust
2013 WRX Hatchback: LED Conversion, Blacked Out, Rally Armor
2015 Macan Turbo: Techart Exhaust, Cargraphics Lowering Module, Blacked Out
      10-07-2014, 05:03 PM   #4
SakhirM4
SakhirM4's Avatar
Drives: '15 SO M4/'20 Z4 M40i
2020 BMW Z4 M40i  [10.00]
2015 BMW M4  [8.76]
Originally Posted by redfox View Post
silent recall. This is one of them. There are two right now.
It is not a recall. It is a service bulletin. There is a big difference.
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
      10-07-2014, 05:08 PM   #5
MoxieMoxie
Drives: 2015 M3
I don't know what it is but I want my can terminated now. Thanks.
      10-07-2014, 05:13 PM   #6
DocWeatherington
Drives: F90 CP
23 Bmw M3  [10.00]
What's the other?
      10-07-2014, 05:26 PM   #7
redfox
redfox's Avatar
166
Drives: 2015 YMB M4
Originally Posted by DocWeatherington View Post
What's the other?
Water drainage - apparently applying sealant to an area that could leak.
      10-07-2014, 06:32 PM   #8
DocWeatherington
Drives: F90 CP
23 Bmw M3  [10.00]
Side note, any decent tint shops in Toronto?
      10-07-2014, 07:27 PM   #9
NorCal f80
346
Drives: M3
WTF is a Can Terminator?
      10-07-2014, 07:31 PM   #10
DocWeatherington
Drives: F90 CP
23 Bmw M3  [10.00]
I THINK IT HAS MADE IN GERMANY on it somewhere.
      10-07-2014, 07:38 PM   #11
Gac101177
M4-SAHD
Gac101177's Avatar
512
Drives: M3
2015 BMW M4  [10.00]
      10-07-2014, 08:31 PM   #12
huatian
Drives: SS M4
CAN bus, or Controller area network. It's a protocol used mainly in the automotive industry and audio. It's used for control boards and systems to communicate. It's a linear bus topology and needs to be terminated to work correctly. Lack of proper terminal in a linear bus can lead to all sorts of errors. But, I'm sure there are more then one CAN bus within M4, and I'm sure it's not a critical one, however, all CAN buses need to be properly terminated.
Not a bad write up on CAN bus protocol for those interested. http://en.wikipedia.org/wiki/CAN_bus
Since it says retrofit resister, that means either the value is off a bit leading to internal reflections on the bus, or the value of the resister isn't up to spec in tolerance maybe a 5% resister was used instead of 1% or, maybe the resistor wasn't automotive grade quality. Most circuitry in an automobile has a tolerance of -40C to 250C. My gut tells me it's along those lines hence the retro fit.
But being a BMW, this resister isn't a simple ceramic, it's most likely SMD (surface mount and you can't be just replaced) hence in reality, they'll yank the board that part of the termination and replace it (probably a 100.00 board for a .5 cent resister). Now some CAN buses are terminated with a simple RJ45 terminated internally and used for this purpose, really depends on how it's done. I have my money on a simple little board swap (BMW isn't going to use RJ45 connectors for CAN bus termination - that's for little shops with no money)
      10-07-2014, 08:45 PM   #13
wg8221
Drives:
Right after these two service bulletins were done (1200 mile Svc) I got the Drivetrain Malfunction indication which I outlined in the Drivetrain Malfunction Thread that has put my M4 out of service from Sept 29 until the parts arrive from Germany on 15 Oct at the earliest.
I hope this is a coincidence but thought I'd share my experience.
      10-07-2014, 08:51 PM   #14
huatian
Drives: SS M4
Interesting, Now the drive train system would communicate to another system of its status over a CAN bus. If somehow that protocol got messed up (say one wrong bit from 0 to a 1) it it would indicate an problem but in reality there is no problem. I'm just speculating not saying that's what happened. Point is, all communications in todays auto's use CAN bus as the primary protocol for system communication. So if you have one 1 bit out of sync and you'll get messages that are not accurate. And an improperly terminated bus (CAN, RS232, RS485, USB etc) will easily do that; SOB to track down these types of problems too from an engineering prospective.
      10-07-2014, 09:40 PM   #15
CanAutM3
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
Nope. Made in Austria
      10-11-2014, 04:21 PM   #16
JPBesl
JPBesl's Avatar
29
Drives: 2014 F82 M4
Just went in for my break-in service and had the CAN terminator show up as a bulletin. They didn't have the part so they have to bring me back in. Might want to call to make sure they have the part if you're bringing it in for service and want to get everything in one go.
2015 F82 M4 DCT (current) / 2012 991 C2S PDK / 2011 E92 M3 6MT / 2009 Cayman 6MT / 2007 E92 335i 6MT / 2004 E46 325xi 6MT / 2000 E36 Z3 M Coupe 5MT
      10-13-2014, 04:23 AM   #17
nasdaq100
nasdaq100's Avatar
France
66
Drives: BMW M4 DKG
Attachment 1102178
What is your production's date? I have read that this SIB is for March to July prod
      11-27-2014, 06:14 AM   #18
Gac101177
M4-SAHD
Gac101177's Avatar
512
Drives: M3
2015 BMW M4  [10.00]
Attachment 1102178
It's June
      02-06-2015, 10:37 AM   #19
major one
67
Drives: 18 750i x-drive; 16 g550
i just returned from the dealer after having a 6mos check up completed. my m4 is subjected to this open campaign and will have the part replaced when it comes in. i was surprised really as the car runs beautifully and would not have known there was any issue whatsoever.
      02-06-2015, 10:38 AM   #20
major one
67
sorry - april '14 build.
f80post
