10-07-2014, 09:04 AM | #1 |
52
Rep 261
Brand new Forgeline VX3C-SL
I'm thinking of going a different route and wanted to see if anyone would be interested. The wheels are brand new Forgeline VX3C-SL Transparent smoke outer lips and Satin black faces Price drop! $4500.00 19x10 et 24 19x11 et 34
Present 2022 M5 CS FROZEN BH
PAST~2011 E92M3 Space Grey Gintani STAGE X Last edited by tintboy; 10-25-2016 at 09:24 AM.. Reason: price drop |
10-07-2014, 11:58 AM | #2 |
2739
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
good looking wheels!
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
10-07-2014, 02:45 PM | #4 |
248
Rep 2,271
Super sexy
2011.75 E90 AW | DCT | ZCP | ZCV | ZCW | ZP2 | Prem Sound | Moonroof | BMW Apps |
Mods List: Evolve Exhaust | M Perf Steering Wheel | Tint | Lux | Hardwired V1 | KW V3 | Volshlag CP | Brembo BBK | BBS FI | Yokohama AD08 R| Schroth 4 Point Harness | Challenge GT Diffuser | OEM GTS Wing| GTS Lip| I lied earlier, I wasn't done with mod, but I swear, I'm done now, no more mods... |
10-08-2014, 03:21 PM | #9 |
52
Rep 261
Absolutely! they where specked out to run a 275x30 front and 315X30 rear with no fender modification required. Plus these are actually my second set from forgeline so i know these fit.
PAST~2011 E92M3 Space Grey Gintani STAGE X |
10-08-2014, 03:36 PM | #10 |
94
Rep 398
Very nice, good luck with the sale!
'17 Porsche C4S Sapphire Blue Metallic / Bordeaux Red - Softronic tune - Soul Sport Cats - Soul Exhaust
'13 E70 X5M Black Sapphire Metallic / Bamboo Beige - Full Dinan Suspension - Dinan Exhaust - BPM Sport Tune - xHP Flashtool Transmission Tune |
10-08-2014, 04:32 PM | #12 |
52
Rep 261
Yes they wit over KWCS and Ohlins with no problem and they are also big brake friendly
10-08-2014, 04:54 PM | #13 |
2739
Rep 6,734
I like the specs of these wheels and think they look great but they will not fit with KW CS without a spacer. That is unless you run a stretched, narrow tire. You will need at least a 5mm spacer with a 275/30/19 front tire.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 10-08-2014 at 05:57 PM.. |
10-08-2014, 05:09 PM | #14 |
88
Rep 533
10-08-2014, 05:57 PM | #15 |
2739
Rep 6,734
OK; whoops. Still needs the spacer.... with a 275/30/19 tire.
'23 X7
10-08-2014, 07:29 PM | #16 |
52
Rep 261
[QUOTE=slicer;16752060]I like the specs of these wheels and think they look great but they will not fit with KW CS without a spacer. That is unless you run a stretched, narrow tire. You will need at least a 5mm spacer with a 275/30/19 front
I personally don't have KWCS I have Ohlins on my car but thank you for the clarification. So worst case if your running KWCS you would have to get a 5mm spacer. Not so bad.
10-12-2014, 08:18 PM | #20 |
52
Rep 261
Mee too! Hopefully someone on the forum buys them so I can see them mounted!
10-13-2014, 05:58 AM | #22 |
Currently Driving
269
Rep 1,426
Drives: BPM tuned '13 AW ZCP E92 M3
These are hott!
