10-05-2014, 05:08 PM | #1 |
10
Rep 72
Concerns over S65
Hello all. New member here. I currently own a 2012 boss 302 with lots of mods. I made the mistake of test driving an 08 e92 6speed the other day and pretty much fell in love.
Now I am used to great handling, and a very strong v8, as I have previously owned a 13 GT and 03 cobra. I guess the part I fell in love with is the fit and finish of the car. Light years ahead of ford. Obviously it's a luxury can and I really liked that. That being said, I began to do a little research and all I find is the rod bearing issues! Now I understand, people won't get onto the forums and say how great their car is running, but it is everywhere. I am very familiar with fords #8 cyl issue with new 5.0's, but even that is not as prominent as these m3's with rod bearing problems. I guess my question is, how often do these things blow? I'm sure I'm beating a dead horse and everyone is tired of hearing about it, but I didn't know who else I should ask. I do not want to buy a car and blow a 25k engine. Which is outrageous. I guess I could just buy another boss motor that's fully forged and throw it in there Any help or guidance is appreciated! |
10-05-2014, 05:23 PM | #3 | |
10
Rep 72
10-05-2014, 05:51 PM | #4 |
8912
Rep 4,107
As you pointed out, it happens but we don't really know how often it occurs. There are a number of sensational stories about failures but those of us with no issues are generally silent. You hear the horror stories but not the good stories. If you want the car, get it, but only if you are comfortable with the risks. Get a CPO car or an extended warranty to CYA...
2021 X3 M40i
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 |
10-05-2014, 06:28 PM | #6 |
174
Rep 1,246
Drives: E92 M3
JFC. There's enough threads about rod bearings already.
10-05-2014, 06:40 PM | #7 |
980
Rep 4,001
^this
Grigio Telesto M4, 6MT. Coyote 5.0 F-150 991 GT3 |
10-05-2014, 07:13 PM | #8 | |
10
Rep 72
10-05-2014, 09:25 PM | #9 |
5234
Rep 10,616
Is a warranty less than doing the rod bearings?
I agree rod bearings should not need to be replaced, but I was out of warranty and did not want to worry. I also could not buy any other car I wanted more for the same money I could have sold mine for. |
10-05-2014, 09:37 PM | #10 |
101
Rep 701
'12 Boss 302 is nothing to sneeze at. Other than fit and finish, have you found the M3 has anything performance wise which the pony car doesn't?
I am in the opposite sitaution and don't want to deal with high-priced repairs on German machines any longer. I will be opting to go American next. |
10-05-2014, 10:31 PM | #12 | |
10
Rep 72
10-05-2014, 10:41 PM | #13 | |
62
Rep 1,381
10-05-2014, 11:22 PM | #14 |
380
Rep 3,934
I had the chance to get into a 302, sat in the M3. and the rest was history. WAY better interior, and the M3 looks sexy/classy. I understand why are you lusting over a M3.
Honesty though i dont think the M3 is worth worrying over. If you want one, maybe do a rod bearing swap. |
10-05-2014, 11:36 PM | #15 |
Finally done modding...until the next mod.
10
Rep 130
Don't worry about the rod-bearing issue, buy the E92 if you love it. If you can't get the issue out of your mind have a Blackstone oil analysis done to test the copper/iron levels. This can be indicative of a rod bearing issue on a used/unknown s65 motor. It's super cheap to have the oil analysis done, maybe worth it for peace of mind. Otherwise, it's around $3k to have the bearings replaced as "preventative rod-bearing maintenance."
How many miles are on the E92 you want?
'10 6MT ZCP E90 M3 - Brembo: GT BBK(front/rear) / Dinan: Mid-pipe & Race SW, Pulley Kit, Stage 2 Suspension, Strut Braces, Rear Toe Links / AFE: Stage 2 Intake / BMW Performance: V2 Electronic Steering Wheel (w/ AutoCarbon CF Trim), CF Mirror Caps, CF Spoiler, CF Interior Trim / LTMW: 1M M3 Front Bumper w/ Slek CF Lip / AEPX: ARC-8s / Akrapovic: Rear Exhaust / Arkym: CF Rear Diffuser / Vinyl Styles: partial matte grey wrap / etc...
10-05-2014, 11:57 PM | #16 |
532
Rep 5,498
The bearing failures you have seen are real. That being said, even the die hard alarmists know that the failure percentages are small. The S65 is high tech and very advanced piece of machinery that does not respond well to mistreatment. Find a good one, take care of it. Sure, some babied S65s will fail, but most will be fine with proper care.
Instagram: jellismotorwerks |
10-06-2014, 07:06 AM | #17 | |
5234
Rep 10,616
I agree the odds are on your side that you won't have a failure. Same goes for life insurance and homeowners insurance and car insurance, but I bet you worry enough about those similar odds that you insure against them. It was not something I wanted to worry about. $10k for a used engine would be a major setback for me and you can be sure I would be doing a preventative maintenance bearing swap on that motor. That is me doing all the work. Figure on $15-20k for a shop. If that kind of money is no worry to you, then that is great. Preventative maintenance rod bearing is $2350 parts and labor at an expensive shop like EAS in CA. You can DIY for $500 to $800 depending on what parts you use. However, it is an advanced DIY. Figure on 8-16 hours depending on how good you are, and I would not count on being on the short end of that if you are doing this job for the first time. I suspect EAS in CA, which lowers the subframe just far enough to get the pan off but no so far any hoses have to be disconnected, is doing this in 8 hours using the quicker but more expensive ARP bolts. |
10-06-2014, 07:47 AM | #18 |
90
Rep 850
Owner of 3 E9x M3s. The first one was an early E90 model and one of the first cars to have idle valve problem (before they launched a recall). The second one which was heavily modded was my DD and i clocked 111,000 kms in it untill i sold it to someone else. Didn't visit the dealer not even once (did the maintenance all by myself). My current E92 serves as a track car. Not a high mileage model but most of the 28,000 kms were done on track. When we opened the engine to have it built the bearings looked excellent.
As you said no one comes to forums stating how great they cars are, when shit hit the fans you see topics pop up. Just something to have in mind. Since you are looking to get a older model, i'd definitely replace the bearings to have peace in mind. It's not that much of a hard job. If you have access to a lift and know the tools and done bearing replacement before it's a weekend job with a buddy of yours. The newer cars with the revised bearings don't show anything prior going kaboom. The older ones with lead used in the bearings show a good amount of lead in the oil and that serves as a warning. |
10-06-2014, 10:17 AM | #22 |
980
Rep 4,001
Nice
