10-02-2014, 12:20 PM | #1 |
1427
Rep 2,650
► APEX |Redesigned and Reinforced Wheel Studs
It's A Good Time To Upgrade Your Studs Redesigned APEX wheel studs feature an improved shoulder design to reduce stress risers and stud failure. 75mm and 90mm versions are available with a true bullet-nose race tip for faster wheel installs and a cleaner look, or with an easy to install hex head. What's New? The Bullet Nose Don't compromise on safety and quality to get the stud style you want. Most affordable wheel studs today only offer a hex head version. Saving a few minutes during the install is great, but most racers want a true bullet nose tip. We've brought back the bullet nose design and give you the option to pick your preference at no added cost. The Beefy Shoulder Typical wheel studs have no shoulder to seat with the hub. Those studs are cheaper and easier to produce, but can result in new threads being cut into the stud as they are tightened. APEX's new wheels studs were engineered with a beefy, tapered shoulder design, allowing for a consistent and flat surface to secure to the hub. This feature helps eliminate stress risers that can lead to stud failure in most other designs. This feature helps eliminate stress risers that can lead to stud failure in most other designs, and will serve as a visual indicator that your studs have been properly secured during the installation process. Lug Nuts Included No need to order hardware separately. All studs are finished in black, and lug nuts are available in either a black or silver finish. Studs vs. Standard Bolts Less Wear Wheel studs replace your OEM lug bolts by simply threading into your car's hub. Once installed they do not need to be removed when changing or removing wheels, which preserves the threads on your car's hubs. They also guarantee proper thread engagement, as you can see how many threads were engaged during install. Less Time No more time spent trying to line up lug holes while holding wheels up with your feet. Studs make it easy to slide the wheel on and leave it there while grabbing the hardware. Lug nuts easily slide on and off the end of the stud, and can be started by hand with little-to-no effort. Use Any Spacer All spacers require extended-length hardware to be used safely. With our extended-length studs, you are no longer required to buy a bucket full of various-length bolts for use with different size spacers. Our 75mm studs support up to 12mm spacers, and our 90mm studs support up to 25mm spacers. Available Sizes & Options 75mm 5-Lug Stud Kits (20 Studs and 20 Lug Nuts) - Supports Up To 12mm Spacers 75mm M12 BMW 5-Lug Kit with Hex Head - Black Lug Nuts 90mm 5-Lug Stud Kits (20 Studs and 20 Lug Nuts) - Supports Up To 25mm Spacers 90mm M12 BMW 5-Lug Kit with Hex Head - Black Lug Nuts Photos Ordering and Contact Information
04-17-2015, 01:32 PM | #2 |
1427
Rep 2,650
For those of you wondering how to install one of our Bullet Nose stud kits, we filmed this video showing you our process.
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
04-23-2015, 08:10 PM | #3 |
9
Rep 36
Since the kits come with lug nuts but no locks, where do I get locks for an M14x1.25 wheel stud? Shouldn't the kit come with locks? I live in Miami, locks are a must.
04-24-2015, 01:19 PM | #4 |
3526
Rep 6,752
There are some tuner lug nut kits available on the market that comes with locks that you can purchase that would allow you to have locks. Not everybody wants locks on their stud kits, such as track enthusiasts and racers who needs the ease of swapping wheels without any locks, which is why the kits do not have locks as a default. We unfortunately do not have a solution for wheel locks for the stud kits at this time, but are looking for possible solutions in the future.
06-18-2015, 12:14 PM | #5 |
1427
Rep 2,650
For those of you with a Hex Head stud kit, this video will show you just how to install your stud kit.
11-10-2015, 07:53 PM | #6 |
3526
Rep 6,752
All orders have been processed and shipped. We appreciate your support!
02-19-2016, 12:37 AM | #7 |
3526
Rep 6,752
We have stud conversion kits readily available in both the 90mm and 75mm lengths. Feel free to contact us via PM, phone, or email with any questions!
08-22-2016, 04:03 PM | #9 | |
1427
Rep 2,650
-Matt
08-30-2016, 01:07 PM | #10 |
1427
Rep 2,650
For any questions feel free to contact us!
11-14-2016, 06:09 PM | #11 |
1427
Rep 2,650
For any questions on just how tough our studs are, shoot us a PM or email us today!
12-12-2016, 04:02 PM | #12 |
1427
Rep 2,650
For any questions feel free to call or send us an email!
07-25-2017, 12:13 PM | #13 |
1427
Rep 2,650
Give us a call or email to order, or if you have any questions regarding fitment, spacers, or clearances.
08-01-2017, 05:03 PM | #14 |
1427
Rep 2,650
Questions about the benefits of using studs vs. regular bolts? Give us a call or PM and we'll get you the info you need.
04-08-2018, 10:37 PM | #15 |
Coupe'n
21
Rep 149
I have a 2014 Comp package M5 with Competition 20" Wheels. I want to run some spacers but not sure what size yet.
What size spacers and what lug stud kit would you suggest? I like the bullet nose BTW and will likely want to pickup some nice tuner style open ended lug nuts. Thanks. |
04-10-2018, 11:58 AM | #16 | |
1427
Rep 2,650
You can use our 75mm M14x1.25mm stud kit for spacers up to 12mm, and for anything larger we'd recommend the 90mm studs. Unfortunately the bullet nose design is not yet available in the M14 thread pitch.
02-18-2019, 03:38 PM | #17 |
1427
Rep 2,650
04-15-2019, 04:48 PM | #18 |
1427
Rep 2,650
