09-27-2014, 09:51 AM | #1 |
433
Rep 1,286
Rear sway bar replacement
Quick question: To replace the rear sway bar do you have to lower the differential only or do you have to lower both the diff and the rear subframe?
09-27-2014, 12:58 PM | #3 |
2747
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Yes you must drop the sub frame. It makes sense to do solid sub-frame bushings and rear sway bar at the same time.
I honestly didn't think I needed adjustable sway bars but I did them when I was doing the sub-frame bushings since there was little, if any, additional labor cost.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
