09-25-2014, 05:16 PM | #1 |
66
Rep 820
Realistically how unreliable is a supercharger. Need real input.
Debating on doing a low boost setup on a 60k mile 09 m3. Car is meticulously taken care of, always warmed up before going above 3k, barely consumes any oil(1/2 qt beween changes). Maintenance always done on time.
I'd like some straight hard facts/input. Preferably from other FI m3 owners and preferably those with higher miles. I don't want to be dealing with a blown up motor. Thank you all. |
09-25-2014, 05:31 PM | #2 | |
BimmerPost Supporting Vendor
8215
Rep 18,823
Drives: BMW
09-25-2014, 05:40 PM | #4 |
420
Rep 1,678
Drives: 2011 MCB E92 M3
That is a widespread issue, not just a forced induction issue. Let's not exacerbate it.
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
09-25-2014, 08:58 PM | #6 | |
532
Rep 5,498
Another happy ESS customer here. Just keep in mind the extra maintenance required, SC oil, spark plugs, belts ect.... Jason
Instagram: jellismotorwerks |
09-25-2014, 11:04 PM | #8 |
Rep 24
The whole point of a SC is the simplicity over a turbo setup. I have an 08 55k Miles with VF540 for the last year and a bit. Just did oil analysis and it was perfect. I would say the negatives of a SC are not many. With AC on in hot weather it can be a tad tougher to start of the line in a manual. I also find the car get hot on the track when flogging it. Do not expect to much power gain down low. very linear power like stock with a bunch of power added up top. Unfortunately the M3 could use more low end power around town.
09-26-2014, 02:23 AM | #9 |
237
Rep 1,095
Drives: 09 SC E90 M3 / 13 F10 M5
It's hard to drive a stock m3 after driving a supercharged one.
09-26-2014, 09:15 AM | #10 |
1469
Rep 3,157
We have had many Customers with this same concern and the only thing that comes to mind on the s65 is the bearing issue. If you are unaware of your bearing condition or have not been doing an oil analysis such as black stone you may want to consider throwing in some Wpc Bearings at the same time as your supercharger install. Peace of mind and a supercharged engine is a hell of a ride. Best of luck
PS: Keep in mind we have seen bearing issues on stock and modded cars alike. As of yet we have not seen any correlation with premature bearing wear and superchargers. * I highly recommend lowering your oil service intervals * Last edited by SflBimmer8484; 09-26-2014 at 09:27 AM.. |
09-26-2014, 09:35 AM | #11 | |
476
Rep 1,711
09-26-2014, 11:37 AM | #13 |
731
Rep 3,735
Rod bearing issues and engine failures are prevalent in many stock E9x M3's. Many engines have popped with very low mileage and zero modifications.
As others stated, most SC kits have done well with time. The most common issues I have seen with SC kits have been a result of mediocre workmanship.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
09-26-2014, 12:56 PM | #14 | |
20
Rep 816
09-26-2014, 01:33 PM | #15 |
62
Rep 1,381
Agreed. Seems like the vendors just wanna sell supercharger kits. The supercharger is not the main cause of the bearing issue. But it definitely is an exacerbating factor. The S65 engine already has a tendency for high bearing wear. No doubt the added stress of a supercharger can increase that rate of wear.
09-26-2014, 11:40 PM | #16 | |
20
Rep 816
09-27-2014, 01:54 AM | #17 |
127
Rep 2,224
I think manufacturer is important because all kits have different pulley designs. I think some place a higher radial load on the crank and bearings.
09-27-2014, 03:37 AM | #18 |
2511
Rep 4,381
Its simple physics isn't it?
You get more power from a bigger bang...a bigger bang equals more load on the piston which transfers to more load on the oil film between the upper rod bearing and the crank (as well as more load on the rest of the engine). It would be unrealistic to expect to get more power from an engine without increasing its wear rate. FI cars will fail at a higher rate than stock cars, that's the price you pay, but a good installation used with mechanical sympathy should ameliorate the risk....there are plenty owners who have put good mileages on their cars without problem. |
09-27-2014, 09:33 AM | #19 |
264
Rep 584
Drives: 2023 M3 CX
Is the oil analysis really something that can be used to tell if you have accelerated bearing wear?
I thought I read somewhere that the composition of the bearing changed like mid production...
2023 BG G80 ///M3 COMP XDRIVE Dinan CF Intake | Valvetronic SS Full Exhaust | AST Adjustable Springs | UNIT 17 Front Splitter | UNIT 17 Sideskirts | BC Forged HSC21 Wheels 20x10 et12 / 20x11 et12 |
09-27-2014, 09:44 AM | #20 |
87
Rep 1,253
Drives: F10535, E90M3, E30M3, E28M5
Garage List 2017 Alpina B6 GC [0.00]
2014 535xi M Sport [0.00] 2014 X3 3.5 M Sport [0.00] 2011 M3 E90 [9.74] 2007 Z4 M Coupe [7.00] 1990 M3 [9.50] 1988 M5 [10.00] |
OP, I have had my SC for 3 years, have done many track days (25+). Current mileage is 28K of which 22K is with a SC. I change the engine oil and SC fluid every 3,000 miles. Blackstone evaluates both and currently no issues.
Knock on wood, I have had no problems. Reliable and unbelievably enjoyable! I would do it again. Good luck in your decision. Cheers, Chris
ESS VT-1 550 | M24 Oil Cooler | Fall Line Half Cage | RaceTech 4009W | 6 pt Harness | Lifeline Zero 360 Fire Suppression | Rear Seat Delete | Motion Control DA Dampers w/remote reservoirs | 900/650 Hyperco Springs | RD Sport Sway Bars | Brembo 380 BBK | GC Camber Plates | Hoosier R7 | Eisenmann Sport | Stack Gauges | Painted Challenge Front Lip | Painted ZCP Rear Spoiler | Xpel Ultimate Film | LuxAngelEyes |
09-27-2014, 02:44 PM | #21 |
314
Rep 1,017
Drives: 2010 E92 M3 6MT
I just had ESS 625 supercharger installed yesterday, of course I replaced my bearings with wpc and upgraded my rodbolts while I was at it...
Here's what my bearings looked like at 31,000 miles. 2010 manual trans. If you are worried about supercharger causing wear... well you prob already have a lot of bearing wear and don't even know it. Spend the 900 bucks on labor and 500 on new upgraded bearings and save yourself some pain. Car was never tracked, oil changed every 7500 miles. Other than the outrageous bearing wear for such a low milage car the shop said my engine was completely flawless.
4.4L LC stroker/ESS VT2-625/Volk te37 sl's/AA exhaust/DSS Carbon Fiber driveshaft/ARH Headers.. etc |
09-28-2014, 04:13 PM | #22 |
97
Rep 2,002
You shouldn't worry. As others have said, change your oil every 3k once supercharged, continue with proper warm up before driving hard, and get a p3 gauge so you can monitor afr, boost, etc. You will love it. 50k miles here, 5k supercharged.
ESS 650 ACM-R Upgrades |
