09-20-2014, 03:57 PM | #1 |
748
Rep 4,429
Stripped threads on oil pan won't release oil plug ?!?!
I recently purchased a 2008 E90 M3 from a private seller on this forum. Today, I took the car in for an oil change and the tech told me that he could not unscrew one of the oil plugs. He said that it just turns and turns. He also told me that he literally had to use a breaker bar to unscrew the first oil plug and that whoever previously change the oil must have over tighten the plugs. I checked it out for myself and the screw in fact does turn either way without tightening nor loosening. Now I'm stuck not being able to get a oil change. I believe my only alternative is to buy a new oil pan. The best price I've found so far is around $900 shipped. Are there any other things I can do to remedy this issue before I pull the trigger on this oil pan??
ModeCarbon V1 CF lip/PF AG CF SS ext./ARKYM CF Diffuser/OSS AE's/B&G Springs/CF Performance Spoiler/V2 Led Performance SW/Meisterschaft GT exhaust
09-20-2014, 04:01 PM | #2 |
So Kewl Guy
49
Rep 619
2010 E93 M3 / MS Catless X-Pipe / AA Catback / Vorsteiner Vented Hood and Bootlid E93 Trunk / ADV1 7.1 Wheels GB / LS3 LED Lights / Harrop Supercharger
09-20-2014, 04:10 PM | #3 | |
748
Rep 4,429
09-20-2014, 04:40 PM | #4 |
115
Rep 1,470
You must turn while prying at it or pulling down to overcome the stripped section. Tough but possible.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
09-20-2014, 04:43 PM | #5 |
20
Rep 816
This. Plus you can retap the threads and get an appropriately sized plug. This happens now and then. No need to buy a new pan unless they completely trashed the drain hole.
09-20-2014, 04:49 PM | #6 |
748
Rep 4,429
Thanks guys for all the ideas. I wanted exhaust every measure before ordering a new oil pan. Much appreciated!!
09-25-2014, 10:25 AM | #7 |
18
Rep 241
Drives: 2011 E93 M3
I had the same problem with my car. A Time-Sert kit saved me big time. Did it myself, very easy. You drill out the old threads, re-tap a little larger, add steel threaded insert, then just put your drain plug back in.
2013 F10 M5/TTFS CUSTOM TUNE/PURE S1 TURBOS/METH/AMS CL DPS/RPI CATBACK/KW SLEEVE OVERS/RPK FRONT LIP/M PERF REAR SPOILER/20" LOMA SUPERTEC SUPERLIGHTS
09-25-2014, 10:49 AM | #8 |
476
Rep 1,711
09-25-2014, 03:18 PM | #9 |
748
Rep 4,429
Its at a local shop and I believe that's what they are doing. The tech explained the procedure and it sounded pretty much like what you described.
