09-17-2014, 06:42 PM | #1 |
8
Rep 104
Anyone want to glance at datalog real quick?
Gears 2-3 (wasn't trying to shift too fast, so don't point that out haha)
-Boost seems to hold pretty well but I don't know the target/tapers are (is that the last column?). -I don't have a wideband, but is AFR alright? -How about timing.....don't know much about that (should read up on it) Thanks alot.....car feels like a monster now, especially second gear. Previously I used the sport map but now that I can reliably get 93 octane, I bumped it up to agressive. The sport map I was using seemed to have surging/boost issues, but seems to pull pretty good now. If you need another format I can convert. Thanks for the help/expertise. Zip file has the excel file if you can open it up, it's easier to read then the pdf
2008 E82 - 6 speed - CP-E Downpipes - Berk Mids - Hartge axleback - BMS DCI - Cobb Stage 2+ - Helix FMIC - Modified CDV
09-17-2014, 07:32 PM | #2 |
8
Rep 101
I uploaded it to datazap.me for you:
http://datazap.me/u/matty135/northwestn54-gear-2-3 Unfortunately, that's where the level of my expertise ends
// [Sold 08/16] 2009 135i SG 6MT | Cobb | Wagner FMIC | MadDad | OCC | RB PCV | MFactory LSD | Forgestar F14 | PSS | ECS 2pc | Ferodo | Goodridge | M bits | Koni Sport | BMW PS, PE, Side Skirts | Rieger | Blacklines //
09-19-2014, 05:38 PM | #3 |
124
Rep 1,362
It doesn't look bad, your getting some correction in cyl 1. The recommended way to do logs is to do one solid pull in 3rd or 4th gear from 2200-2500 RPM and go wide open throttle to close to redline 6800-7000. No shifts it'll give you a better understanding of what's going on.
09-19-2014, 08:56 PM | #4 |
8
Rep 104
I'll keep that in mind, thanks.......4th till redline? Would have to find a good place for that (don't want any tickets).
That logging website is pretty darn cool, thanks Matty.
09-20-2014, 11:21 AM | #5 |
124
Rep 1,362
Yeah I usually use third, but 4th will put more of a load on the engine, which will let you know 3 things if you're running too aggressive of a tune, you have hardware that's worn ie spark plugs, or you're running crappy gas. I've used fourth before and it'll take you to about 120 MPH.
