09-12-2014, 11:58 PM | #1 |
62
Rep 581
Myth or True?
Hey guys,
I often run high concentrations of E85 and inorder to achieve a more accurate mixture I like to run down my tank close to empty - let's say to 20miles left to the tank.. Now by doing this I was told it could potentially lead to fuel pump failure. Is this true? It has been one of those big car myths from ever since I could remember but could never get a straight answer. Thanks Durim
08' Sparkling Graphite Metallic E82 135i. 6spd Manual. Last edited by ..; 09-13-2014 at 07:40 AM.. |
09-13-2014, 02:19 AM | #2 |
20
Rep 54
The idea is that the more fuel surrounding the electric fuel pump the cooler the electric fuel pump so the longer the life. I believe it even though I have never seen any hard evidence to back this up. I am also interested if any person has done testing on this. On a side note Its good to keep in mind that even though it is usually accurate you can run out of gas even if your car says there is x amount of miles left as this is an estimate. I've seen someone run out of gas on their bmw with it saying 17 miles left.
09-13-2014, 03:01 AM | #3 |
68
Rep 627
Drives: '09 E88 135i M-Sport/6MT/SGM
Had it happen to me once before, the dash said I had 40 KM left but I ran out of gas and stalled. Out of curiosity, I asked the shop foreman and he said that I probably shorten the life on my HPFP. He also said that you should fill up once you reach 1/4 left on the tank (I use to wait for my low fuel light).
| Dinan S2=>MHD | e46 M3 trans mounts | Dinan CF CAI | ER CP | HKS SSQV4 BOV | RB PCV Valve | VRSF DP | N55 MP | BMW PE | OC | VRSF 7" FMIC | UUC Evo3 SSK | EBC GD Sport Rotors | EBC Redstuff | TRW F+R | | Whiteline KDT918 | H&R Front Sway | BMWP 313 | MPSS 225/255 | Scopione CF Rear Diffuser | iCarbon CF Rear Spoiler | P3 v2.1 Gauge | Interior LED Retrofit |
09-13-2014, 03:32 AM | #4 | |
43757
Rep 7,224
09-13-2014, 08:56 AM | #5 |
61
Rep 722
I think it differs by car the sensor could be off in some cars that's for sure. I have run my car several times down under 10 miles even down to 5 miles one time. Although it sketches me out when I have my sensor appears to be very accurate however knock on wood. When I fill up e85 I generally do run down to about 10-15 miles before I mix the fuel however the e85 station is probably less than 100 yards from my house it's very convenient
11' m57 335d 165k Miles - JR 2, ATM Full Exhaust & Intake, Wagner FMIC, AAR Boost Pipe, AAR Swirl Delete, AAR EGR Delete
08' n54 135i FBO E85 - SOLD |
09-13-2014, 09:06 AM | #6 | |
oooooo
53
Rep 320
I try to never let the tank get below 1/3-1/2 before I fill up again. Im sure these tanks are made of materials that will not have issues with a little bit of water (old cars - the tank would literally rust) but the fuel itself and the pump do not like H2o.
2011 135i - Gone but not forgotten | 2017 M2 - Powering out of a corner near you!
09-13-2014, 01:28 PM | #7 |
Joint Chiefs of Staff
24198
Rep 190,807
Never seen any proof of this.
But in theory it does make sense, so i always make sure to keep the gas tank at a 1/3 minimum.
09-13-2014, 07:32 PM | #8 | |
62
Rep 581
09-13-2014, 08:13 PM | #9 |
Proud AARP member in good standing
28
Rep 635
My wife lets our cars (except my 1er) run down way low. I told her never let the low fuel light come on. My dog listens better...
I've been told by several mechanics never let the fuel get too low because the pump can heat up. Fuel keeps it cooler. One SA at my local Mazda dealer sees a lot of Mazda SUVs driven by soccer moms and they replace a lot of fuel pumps due to low fuel. I rarely let mine get below 1/2 tank before I fill it.
2012 135i DCT, Lemans Blue/black leather, PPK1, PE, Stoptech Sport rotors and Sport pads, unhealthy crackles and burbles and an aging demonic driver. |
09-13-2014, 09:37 PM | #10 |
The Crowing
111
Rep 2,005
I get mine to say --- miles left all the time. Haven't had a problem with a fuel pump yet. Guess I'll be the guinea pig. I like being almost empty before I switch to 60% e85. Don't want the mixture being wrong at 19psi and E85 tune.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback |
09-13-2014, 10:07 PM | #11 |
62
Rep 581
What mixture are you doing? 10/3?
09-13-2014, 10:27 PM | #12 | |
The Crowing
111
Rep 2,005
09-14-2014, 06:06 AM | #13 |
62
Rep 581
09-14-2014, 09:32 AM | #14 |
The Crowing
111
Rep 2,005
Like I said. The readout doesn't even read miles any more. Just dashes. Haha.
09-14-2014, 12:56 PM | #15 | |
Civil Rights Activist
115
Rep 949
I'm just a poor planner when it comes to finding a shell station.
E88 Crimson Red Vert MSport 6MT - Listing your mods in your signature is lame. BMS DCI/MHD E30 Flash!!/AA Sport FMIC/VRSF CP w Tial BOV/VRSF 3" DPs/550i clutch w SPEC SMFW/Apex EC-7s/Whiteline RSFB/E92 M3 FCAs/Bilstein B12 Pro Kit/VRSF inlets |
09-14-2014, 12:58 PM | #16 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
I drive to 0 miles left more often than I'd like to admit lol. The next fill up is usually around 13 gallons.
09-14-2014, 01:27 PM | #17 | |
European Editor
10589
Rep 22,992
I do think filling up when you have 1/5 of a tank left is ok. I rarely fill up with the fuel light on. The reason why you can run a car out of gas even with some miles remaining on the dash - is bc that distance to fuel is an average of your last 15 minutes(I think?) of driving. So if you were driving like an old lady, and then once the light comes on, you drive like a mad man... you could run out of fuel even with some miles left to drive on the BC.
10-01-2014, 08:15 AM | #18 |
Rep 176
So should I wait until Im almost empty to run e85 for the first time? Recently installed flex fuel wires and installed my dp... Still have a half tank of shell 93 in my car though. (Im new to the whole e85 procedure)
'13 135is Le Mans Blue #462/586
BMS x BERK x VISHNU x VRSF x BMW PERFORMANCE |
10-01-2014, 08:24 AM | #19 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
IIRC you can have warranty issues if you let the car run dry. Based on this expect there is some truth about getting to low on gas. When I ran E85 I refueled a 1/4 tank so the mix was consistent, same with a 93/100 mix.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
