09-12-2014, 01:17 AM | #1 |
180
Rep 1,310
Installed Spec stg2+ and Spec SMSFW
i have installed my Spec Clutch stage 2+ and Spec SMSFW so far i have done 75miles and the chatter isn't as loud as people say it is. sometimes it doesn't even chatter when I'm stopped in neutral. And when it does its not loud at first i wasn't sure if what i was hearing was the chatter or not so i pressed in the clutch and it stopped the chatter.
for those who have Spec clutches what type of break in procedure did you guys do ?
MHD Custom Flash (E85) [Jake@MOTIV] / Vargas Stage 2 Turbos / Fuel it LPFP Stage 3+/ Moitiv Port Injection/ MMP Turbo Inlets/ 3.5 Tmap Sensor / ER FMIC /ER Chargepipe HKS-BOV / AA Downpipes / Agency Power Race mid pipes / Berk Technology race exhaust / BMW SSK / BC Forged Whees Toyo R888 tires / KW Club sport coilovers+KW Camber Plates / Spec stg2+Spec SMSFW/ APR Wing GTC200
09-12-2014, 06:29 AM | #2 |
The Crowing
111
Rep 2,005
Pretty sure it was 500 miles of normal driving before any hard launches. My chatter got slightly louder over the 500 miles. Now that it's getting cold I noticed it doesn't do it when it's cold. But when everything's up to temp it does. I want to try changing the tranny fluid with a mix I saw in a thread before. Something with redline and another fluid. Can't remember.
2009 135i : BMS JB4 G5 ISO,CXRacing FMIC Kit,Injen Cold Air Intake,Evolution Raceworks Charge Pipe,Walboro Inline Fuel Pump, E85 BMS Backend Flash w/ 60% E85,BMS Meth injection (trunkmount),BMS dual meth nozzles,Spec stage 2+ clutch w/ steel SWFW,BMS Catless Downpipes,Berk Tech Race Axleback |
09-12-2014, 06:37 AM | #3 |
Rep 41
My chatter is pretty bad. It has progressively got louder over the past year. If I drive the car hard it seems to have less chatter to it. I might switch out fluids too to see if it makes a difference
09-12-2014, 09:40 AM | #4 |
180
Rep 1,310
what type of fluids are you guys putting? and how will the fluids make chatter less???
09-12-2014, 12:38 PM | #5 |
33
Rep 578
I found a break in procedure that I thought was pretty nice on a mustang forum. It was basically go to a development or somewhere you can constantly drive around and do loops. Go to a stop sign and without using the gas take off and just keep doing no gas take off's. Like 30 or 40 or them. It keeps the temps just about right with all the stops and fairly gentle take offs. Other than that drive it for about 800 miles and do alot of down shifts. My Stage 3+ took forever to get to a decent point, but I've heard 2+ isn't near as bad. As for the noise put the window down and AC on and then you'll know chatter.
2008 135i - MHD/JB4, MS DP's, AMS IC, UI CAI, CDV delete, M3 control arms/Links, RE Toe Link, ECS Trailing Arm, M3 rear SF & Trans bushings, SS brake lines, Michelin PSS.
09-12-2014, 03:29 PM | #6 | |
180
Rep 1,310
09-12-2014, 04:24 PM | #7 |
Civil Rights Activist
115
Rep 949
Break-ins on new clutches are BS. Do about 10 solid burnouts and your clutch will be golden.
E88 Crimson Red Vert MSport 6MT - Listing your mods in your signature is lame. BMS DCI/MHD E30 Flash!!/AA Sport FMIC/VRSF CP w Tial BOV/VRSF 3" DPs/550i clutch w SPEC SMFW/Apex EC-7s/Whiteline RSFB/E92 M3 FCAs/Bilstein B12 Pro Kit/VRSF inlets |
09-12-2014, 04:57 PM | #9 | |
The Crowing
111
Rep 2,005
http://www.uucmotorwerks.com/html_te...nny_rattle.htm
09-13-2014, 01:29 PM | #10 |
Joint Chiefs of Staff
24199
Rep 190,807
Congrats!
09-13-2014, 08:09 PM | #11 |
33
Rep 578
I tried that in Dallas TX and think that made it worse. Last thing you want to do when breaking in Clutch is to get it too hot. My Stage 3+ was still breaking in way past the mileage everybody else was and I always question if that was the reason.
09-13-2014, 11:45 PM | #12 | |
180
Rep 1,310
i believe driving in the city stop and go is better. i could be wrong though and how in the hell are you "not" allowed to down shift when braking in the clutch?
09-14-2014, 03:57 PM | #13 | |
33
Rep 578
09-14-2014, 04:16 PM | #14 | |
115
Rep 949
09-14-2014, 07:30 PM | #15 | |
180
Rep 1,310
09-14-2014, 10:02 PM | #16 |
62
Rep 581
I would do 700 miles just to be safe. Lots of shifting very often. Fluids doesn't affect the chatter. When the clutch is broken in you will hear the chatter and it is 100x worse with the AC on.
09-14-2014, 10:14 PM | #17 |
180
Rep 1,310
i actually hear the chatter more today
09-14-2014, 10:16 PM | #18 |
62
Rep 581
