09-10-2014, 07:40 AM | #1 |
460
Rep 4,531
Review of Remote Coding via Alpine MSS
I didn't know where to put this, but I figured here was okay. Mods move where appropriate.
As some of you know, I installed race seats and got the dreaded airbag lights. I searched for emulators, and other solutions. No local indy BMW shop could do it because it was a newer vehicle. So, I found Alex at Alpine MSS offering remote coding solutions. http://www.alpinemss.com/product_p/rme.htm Basically, Alex sends you a coding cable w/a deposit, and when ready you install some software that allows to to connect to a virtual machine and thus connect to Alpine where Alex can login and code the car. My main concern was the airbag lights, but during the session Alex basically has a sheet of things he can code....which is ALOT. I chose the following: Race Seat Coding (Driver and Passenger) Windows Up/Down with key Unlock Doors when engine is turned off Window Safety Feature Double Blinking Euro Hazards Removal of Amber Headlight Sidemarkers Disable Seat Belt Chimes (Driver and Passenger) Fog Lamps with High Beams Brake Force Display Everything is no additional cost, which is awesome. When I was ready yesterday, I hooked up the computer and cable, let Alex know and he started coding. Took about 20 minutes total and everything was complete. STUPID EASY. Compared to other companies that want to charge $300 for a 1-time coding fee plus a cable (that they do not loan out). Alex is a steal. Super easy to communicate and talk with him and I suggest anyone who wants to code some things without trying to do it yourself, please look into this option. |
09-10-2014, 04:21 PM | #2 |
Rep 26
Thanks for the tip. The price is very reasonable.
When I first got my 128, there were a few things I wanted to code. After seeing the $300 price tags from anyone I could find online I decided to try it myself with NCS expert and a $100 cable I bought. Bottom line, this approach isn't for everyone as the software is super finicky. But I was able to code: -windows up/down with key fob -disable seatbelt chime -disable "hill hold" feature that keeps the car from rolling back before letting out the clutch (this really drive me nuts) -disable brake fade compensation (I didn't like what it did to brake pedal feel when slowing down on an incline) -enable fog lights with high beams |
09-10-2014, 04:57 PM | #3 | |
460
Rep 4,531
09-10-2014, 05:07 PM | #4 | |
European Editor
10594
Rep 22,992
09-10-2014, 05:18 PM | #5 | |
460
Rep 4,531
I'm asking about brake FADE compensation |
09-10-2014, 05:36 PM | #6 |
Rep 145
09-10-2014, 06:59 PM | #7 | |
Rep 26
When your brakes get hot from heavy use (i.e. spirited driving), the friction between the pads and rotors goes down. This means you have to push the pedal harder to get the same amount of braking force. With brake fade compensation, the ABS/DSC module compares brake pedal force to the de-acceleration of the car. If it notices that the driver has to apply more brake pedal effort to get the car to stop at the same rate, it assumes the brakes are fading and it applies more hydraulic pressure to the calipers without the driver pressing any harder on the brake pedal. The intent is to make brake fade imperceptible to the driver. But the trade off is that pedal feel gets weird when trying to stop quickly as the car is pointed downhill (because the effect of gravity on the incline throws off the sensor readings). It almost feels like the brake pedal is pushing back at you and the car is fighting to be slowed down. Furthermore, I'd much prefer to know when my brakes are beginning to fade so I know to bring it down a notch before it's too late. |
09-10-2014, 07:48 PM | #8 | ||
460
Rep 4,531
09-11-2014, 08:34 PM | #9 | |
1418
Rep 781
What drives you nuts about hill hold? That the car doesn't roll backwards when starting on a hill? As for brake fade compensation, if it is actually there (and lord knows the internet says it is), it doesn't actually work anyway. Our stock brakes fade just fine. |
09-16-2014, 08:14 PM | #10 | |
Rep 26
Hill hold drives me nuts because it completely neuters the feel of clutch engagement. I always feel like I'm over revving the engine before the clutch catches. With 20+ years of driving a manual trans, it's more of a hindrance than a convenience. Furthermore, I have an axe to grind with any technology that dumbs down the driving. This includes other things like adaptive steering, stability control and rev matching (as seen in the Nissan GT-R and the latest gen Minis). As for brake fade compensation, it is only a band-aid. Indeed it doesn't eliminate fade, it only delays it. So why bother having it at the expense of brake pedal feel? That's why I disabled it. |
09-17-2014, 09:41 AM | #11 | |
369
Rep 3,547
I blip the throttle on downshifts and like that I have learned to do that but I would prefer the car do it. When I am driving in an autocross, I get a bit overwhelmed with the number of things to do all at once at times and one less would be OK. This is about the only time I downsift when up around 5000 rpm so my normal driving practices are not exactly what I need to be doing. It's one more thing to potentially go wrong but that's the only downside. We aren't going to get the computer out of our cars. That genie is firmly out of the bottle. So once you accept that a modern car will never be like a 1960s or earlier car from the standpoint of electronic control, why not just accept the help? That's my theory. But I guess that logic takes you to an automatic transmission too. So maybe we all have to decide how much we want our car to do and how much we'd rather take care of ourselves. Having different lists is OK.
128i Convertible, MT, Alpine White, Black Top, Taupe Leatherette, Walnut, Sport
Ordered 5/22/09, Completed 6/4/09, At Port 6/9/09, On the Georgia Highway 6/13/09, Ship Arrived Charleston 6/24/09 at 10pm, PCD 7/21/09 |
