      09-10-2014, 01:34 AM   #1
Boosted_N54
Boosted_N54's Avatar
180
Drives: 135i N54
Agency Power Mid pipe hangs a bit more
i have a N54 with AA catles DP stock mid pipes and Berk muffler delete .
Today my shop was going to install my new Agency Power Mid pipes but there was a bit of a problem. The Agency mid pipes were hanging a bit lower and the the bracket the bolts to the cars body couldn't get screwed in because the mid pipes were in the way hanging a bit lower . Both connections on the down pipes side and the exhaust side were perfectly fine connected. My shop told me that they will order some kind of exhaust spacers from Dinan with longer bolts and that it should be perfectly fine.
has this ever happened before ?
what are your guys thoughts?
MHD Custom Flash (E85) [Jake@MOTIV] / Vargas Stage 2 Turbos / Fuel it LPFP Stage 3+/ Moitiv Port Injection/ MMP Turbo Inlets/ 3.5 Tmap Sensor / ER FMIC /ER Chargepipe HKS-BOV / AA Downpipes / Agency Power Race mid pipes / Berk Technology race exhaust / BMW SSK / BC Forged Whees Toyo R888 tires / KW Club sport coilovers+KW Camber Plates / Spec stg2+Spec SMSFW/ APR Wing GTC200
      09-10-2014, 10:10 AM   #2
DietTab
DietTab's Avatar
12
Drives: 08 135i
I used 3/8 spacers between the body and the brace and longer bolts. Mine bolted on, but it rattled against the new pipes (Magnaflow, but same issue). No issues since. I used aluminum stock, but you could use a stack of washers just as effectively
LSXOCET - 404rwhp @ 1600 lbs curb weight... bonkers fast
      09-10-2014, 02:24 PM   #3
Boosted_N54
180
Drives: 135i N54
what's the purpose of the brace?
      09-10-2014, 03:24 PM   #4
DietTab
DietTab's Avatar
12
Drives: 08 135i
Chassis stiffener. it ties the two sides of the tunnel together, and to the rear subframe. It wont hurt anything to run without it, but you lose some stiffness without it.
      09-10-2014, 04:00 PM   #5
Boosted_N54
180
Drives: 135i N54
OK cool by puting spacer inbetween the the brace so there can be clearance won't hurt anything right?
      09-10-2014, 04:09 PM   #6
DietTab
DietTab's Avatar
12
Drives: 08 135i
nope.
