09-08-2014, 11:45 AM | #1 |
143
Rep 190
Drives: F80 M3 (Sold) @downf0rce
Car moves while in park
Has anyone had this issue? While on and in park, my car rocks back and forth ever so slightly, like it's trying to get in gear and go. It's a 2012 135i with DCT.
09-11-2014, 10:58 AM | #3 |
8
Rep 195
You should set the handbrake whenever you park. This takes the stress off the transmission and prevents the rocking motion. You should do this always on an automatic and a good idea on a manual.
09-11-2014, 11:20 AM | #4 |
Proud AARP member in good standing
28
Rep 635
I need to check mine. Mine has lunged forward when in D and foot on the brake. Try turning off your AC and see if it still does it. Idle jumps on mine sometimes.
2012 135i DCT, Lemans Blue/black leather, PPK1, PE, Stoptech Sport rotors and Sport pads, unhealthy crackles and burbles and an aging demonic driver. |
09-11-2014, 11:30 AM | #5 | |
151
Rep 929
F87 '16 M2 ... Mineral Grey, 6MT, Exec, MPE Gone: E82 '13 135is 475/586 ... Mineral Grey / Oyster, DCT, Premium, Tech, HK, Michelin PSS, BMW Performance Suspension |
09-11-2014, 12:21 PM | #6 |
143
Rep 190
Thanks for the responses guys. I was planning on taking it to the dealership for service, but if you are all experiencing a similar issue I may not. I will try the A/C and see if that is the issue. The ebrake also sounds like a good idea to prevent any stress this might be causing.
Do note this video was taken before I left from home (not upon return), so the engine was still warming up. |
09-12-2014, 08:52 PM | #7 |
151
Rep 929
Your car does this, and my car does this. You may try posting your question in one of the higher-traffic areas and see who else has this problem. My car doesn't demonstrate this behavior reliably, and wouldn't do it at the dealer, but it's there.
12-14-2014, 02:53 PM | #8 |
283
Rep 888
Drives: 08 135i M Sport 6MT, 15 X3 35i
If you have a torque converter, that could be the answer, since the engine side is always in motion when the engine is on. If you have a dual clutch trans it could be that the clutch is making contact, from what I understand the clutch never fully disengages, but I could be wrong. In my AT vehicles I apply the park brake when parked on an incline to prevent excess stress.
I used to work with an ex RCMP (Canadian National Police) who told me they would just push AT cars out of the way if they were blocking fire hydrants if the fire dept needed it, and break windows if E brake was on/MT. It may have damaged the trans but it made me wonder how much play there is when in 'park'. It would be worth looking into how the park function brakes the trans, could be it has some plsy
2015 Cosmic Blue Metallic Wrapped X3 35i ///M Sport Full 3M Vinyl Wrap | Flat Black Grilles |
12-16-2014, 07:37 AM | #9 |
2015 X1 35i XDrive with NAV
76
Rep 659
Drives: 2015 X1 35i
With most auto cars there is a plastic gear or finger that engages when its in park to keep the car from moving (other then fluids being diverted in a loop to keep the car from trying to move). That's what get broken in the event you push the car when its in park.
2015 X1 35i XDrive Ultimate, NAV & Cold Weather Package MHD, FTP Motorsports Charge Pipe, Drop in K&N |
12-18-2014, 09:46 AM | #11 |
Senior Chief Petty Officer USN
106
Rep 501
My car (DCT) does this as well. If I have it in park on a hill it will roll back slightly. Like a manual does. My VW GTI with DSG used to do this as well. I just take it as a by product of the twin clutch design transmission.
