09-04-2014, 03:17 PM | #1 |
1056
Rep 1,459
Cleaning the Air Filter
Whats the rule of thumb for cleaning vs. replacing the stock air filter? My M3 has 30k miles and it has never been done. Today, I shook it out, and vacuumed it with a hand held bristle attachment. I then used my finger to clean out any debris inside each "blade." I noticed the cleaning from the vacuum may have rouged up some of the lining on the outside of the filter, but nothing too bad. Is this a concern? Should I just replace it after 30k miles anyway?
09-04-2014, 03:26 PM | #2 |
4467
Rep 7,110
Changed my stock filter shortly after I bought the car, around 14k miles. Definitely needed in my eyes. $50, nothing to spare on to keep the S65 clean and happy mate...
09-04-2014, 04:33 PM | #3 | |
PAZUZU
545
Rep 2,058
Drives: '15 M4
09-04-2014, 04:45 PM | #4 |
Bad Lieutenant
233
Rep 3,517
I replace mine yearly (~5k miles), they're cheap.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
09-04-2014, 10:08 PM | #5 |
391
Rep 1,133
Drives: 2008 Jet Black M3 Coupe
The filters rely on very small fibers and other materials to trap very small particles. Cleaning methods are critical, poking with a too stiff a brush, blowing it out with compressed air, maybe a vacuum, depending on how strong, can all potentially damage the fibers and leave big holes in your filtering capability. Oiled filters make the fibers sticky to improve filtering, theoretically.
You can check and clean a replaceable air filter every oil change and you would not be too anal. 30000 miles or approximately two oil changes seems like a lot of miles in between checking and cleaning to me. I change my oil every 10k and at least inspect the filter, and I change my plugs every 30k. The air box comes off to do the plugs so there's no excuse not to clean it. |
09-05-2014, 06:35 AM | #6 | |
115
Rep 1,470
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
09-05-2014, 12:24 PM | #8 |
380
Rep 3,934
I usually replace my filter every 10k miles. I also use aftermarket filters. They are to cheap to clean IMO. For 50-100 bucks every 10k miles I will just buy one
09-05-2014, 12:35 PM | #9 |
1889
Rep 5,506
I think the air filter change interval is 30k miles for the M3. Every car is different. I guess because the filter element is larger on the M3, they change it less.
I have a cleanable aftermarket filter so I clean it every 7.5k miles or so.
Auto Detailing Enthusiast!
09-05-2014, 06:33 PM | #10 |
192
Rep 3,633
09-05-2014, 06:45 PM | #11 |
Bad Lieutenant
233
Rep 3,517
Aren't you the guy who spends $100/day in fuel?
09-05-2014, 06:55 PM | #12 |
192
Rep 3,633
09-05-2014, 07:43 PM | #13 |
380
Rep 3,934
09-06-2014, 08:59 AM | #14 | |
Bad Lieutenant
233
Rep 3,517
I guess, for me, where I live, my filter gets dirty within one year. We have a high dust/mold/spore count and the filters can be had cheap, so it's part of my yearly maintenance. They are about $35 so it's not much and also recyclable paper and rubber.
