      09-03-2014, 11:04 PM   #1
bellducci6
bellducci6's Avatar
Drives: 2009 135i
DME 2AB4 Fault Code
Hi all! I,ve been on the forums for a few years now, but I barely post haha. Anyways I've been searching all night why my car got this code with very little luck. The car would stop responding as if the battery died, but eventually "wake up" again and everything will work as if nothing happened. Eventually especially after driving the car or letting it sit the car would do the same thing all over again with no power to anything. I checked all my connections in the DME and as of now I just removed the JB4 g5 with still no power. I also forgot to mention that the key is also stuck in the key hole because currently it needs power to release. Any input on this will be greatly appreciated!
2AB4:
2AB4 DME, internal error: RAM-checksum
Error will cause a warning light
Error is not currently present
Test conditions have been completed
Short circuit or signal interruption
Ar Downpipes, Custom Exhaust, JB4 G5 ISO Board Map 5, 255 inline pump, Spec Clutch Stage 3+, Shifteck Short Shifter, BMS Single Filter, BMS Oil Catch Can, BMS Oil Thermostat, VRSF 7" Intercooler, tial Bov, Er Charge Pipe, Schroth Rallye 4 Quick Fit Harness, Apex Arc 8's, Star specs, CDV, Clutch Stop, BMS Cabin Filters.
