      09-03-2014, 06:41 PM   #1
nj135i08723
Drives: 2008 135i Convertible
New 135 Owner, New league of problems. . .
I've had my 2008 135i for about 9 months now but certainly have driven it more than most (got it with 36k, now has 53k) and after doing the plugs and oil changes myself (50k and 46k respectively), I'm running into my first repair situation.
I have what I think is a BIG (half a quart in about 3 weeks after topping off after noticing I was down a quart) oil leak somewhere and I cannot figure out what it is. After putting the car on the lift at my godfathers' shop who deals mostly in domestics, it looks to be a rear main because there is a lot of oil back there but also a ton of oil under the belts near the sway bar. The Pan itself is dry.
WTF?? could I really have a rear main issue at 53K miles doing what BMW recommends for maintenece? if so what does this cost and could it be a less severe problem that's more common? I know there is a different school, of thought between foreign and domestics, so please help a newcomer to this community out. I really don't wanna shell out thousands on a car I just bought or put a "for sale" sign on it. I love the thing.
      09-03-2014, 06:55 PM   #2
amsnow440
Olmec's Temple Guard
amsnow440's Avatar
80
Drives: 2010 135i 6MT, 05 Legacy GT
Did you check the valve cover gasket?
2010 135i 6MT Jet Black M-Sport
      09-03-2014, 07:12 PM   #3
nj135i08723
I did not. is it that hard to get to? how much more work is there than getting to the plugs?
      09-03-2014, 08:55 PM   #4
amsnow440
amsnow440's Avatar
80
You have to first take the cowl off and then it's four bolts to remove the engine cover. You should be able to tell by then.
Cobb has a nice DIY video on changing the plugs which shows the engine cover removal:
Valve cover gasket DIY:
http://www.e90post.com/forums/showthread.php?t=775317
      09-04-2014, 08:11 AM   #5
Stvee
21
Drives: 2010 BMW 135i
Make sure to check the valve cover itself for cracks while you have the engine cover off. Fairly common issue on our shitty plastic valve covers.
      10-01-2014, 04:59 PM   #6
nj135i08723
thank you for your input guys!! it turned out to be the oil filter housing gasket. not a drop now!! Sorry for the delayed response
      10-01-2014, 06:49 PM   #7
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Drives: E82 Mutt, M57 Truck
oil filter housing gasket and you had oil down by the rear main? That explains the wet belts, but I'd check on that rear main again in a little while.
N54/3 FE82 Mutt | BUILD THREAD | GARAGE SALE
      10-08-2014, 09:48 AM   #8
nj135i08723
it was actually dripping into a crevase on the bottom of the engine and runnng to the back and down.
      10-08-2014, 10:00 AM   #9
RsPhi
Drives: 2009 BMW 135i
I would check the oil filter housing first, When those leak the oil goes all over the place. When you're driving the oil gets all over the back of the engine and transmission, that's probably why you see oil coming from the rear main seal.
      10-08-2014, 03:04 PM   #10
TheSt|G
Resident Tamed Racing Driver
TheSt|G's Avatar
Drives: 911, 130is, E39 M5, E36 M3
Go look at any older BMW with a M54(which is largely the basis for the N54/55), the oil filter housing gasket leak distributes oil on that entire side of the engine.
2005 E46 M3 Interlagos/Cinnamon with Sunroof Delete
      10-08-2014, 04:56 PM   #11
edisapimp
Civil Rights Activist
Drives: E46 Sedan, E88 Vert
Glad this worked out to be an easy fix!
E88 Crimson Red Vert MSport 6MT - Listing your mods in your signature is lame.
BMS DCI/MHD E30 Flash!!/AA Sport FMIC/VRSF CP w Tial BOV/VRSF 3" DPs/550i clutch w SPEC SMFW/Apex EC-7s/Whiteline RSFB/E92 M3 FCAs/Bilstein B12 Pro Kit/VRSF inlets
      10-08-2014, 05:01 PM   #12
ShocknAwe
1Addict
ShocknAwe's Avatar
3234
Was tinkering a little today and when I was in there I looked around. I see how it would now. Interesting.
      10-09-2014, 11:10 AM   #13
TheSt|G
TheSt|G's Avatar
The even more interesting part is that the S54 does not have this issue despite using the same gasket as the M54 and being based loosely on the M54.
Tags
oil leak, rear main
