09-03-2014, 01:08 PM | #1 |
17
Rep 221
Taking a supercharger kit off, any worries?
I'm looking at purchasing a M3 that's had a supercharger kit on the past 3000 miles or so. I don't want the kit and he's willing to part it to reduce the price but I'm wondering if there's anything to be concerned about afterwards.
He's going to have the shop tune it with an ESS flash since the SC is being removed so that should be ok and should have all the coding I want done, etc since it also has test pipes. However, I'm wondering if there's any other reasons to be concerned about an engine after taking a SC kit off? Thanks. |
09-03-2014, 01:52 PM | #2 | |
BimmerPost Supporting Vendor
8211
Rep 18,823
Drives: BMW
Make sure the lower D/S air duct is replaced, as this is typically cut to make room for the air filter.
09-03-2014, 02:27 PM | #4 |
174
Rep 1,246
Drives: E92 M3
Which kit is he pulling off?
It's completely revertible. Is the car still under warranty? If not, I would get a third party warranty on it. |
09-03-2014, 03:19 PM | #6 | |
17
Rep 221
Budget. The kit prices me out of the car, with it off I'm on the edge of my budget. Also I don't track or plan on racing the car at all, just going to be my daily so I wouldn't get much use out of a 13k SC kit around town.
I will let him know. |
09-03-2014, 03:21 PM | #7 |
17
Rep 221
Thanks for the info. He's not going to put the stock flash back on but rather a new stage 2 ESS tune with coding, etc.
09-03-2014, 03:43 PM | #8 |
26
Rep 767
^this.
Negotiate including it. More than likely he's going to have to pay uninstall and for your custom tune. You'll be much happier you left it on
2019 McLaren 720s / 2018 Lamborghini Huracan Performante / 2019 Porsche Macan Turbo / 2016 BMW M3/// IG @jon.hagerty
09-03-2014, 04:26 PM | #9 |
532
Rep 5,498
See my thread about "non-routine maintenance".
To be fair, intercooled kits are not 100% reversable (maybe 90%)... meaning, once the kit is removed there will in fact be evidence that there was an SC installed. All intercooled kits require cutting of the front clip. Some shops completely remove the lower portion of the clip while other just trim it. In either case, a significant amount of plastic reinforcement is removed from the lower portion of the clip to make room for the heat exchanger. If it was an air/air intercooler kit like AA or Evolve then the majority of the front clip is modified to make room. A new front clip is $500-1000 depending on your source. Replacing it requires a few hours of labor. If you want all signs of a supercharger kit removed then the front clip needs to be changed out. Again, see my thread, I explain the process and post pictures when I changed my VT2 kit back to a VT1.
Instagram: jellismotorwerks |
09-03-2014, 04:31 PM | #10 | |
17
Rep 221
Just not worth 8k to me as I'm just tooling around town most of the time as it's going to be my daily and I'm not going to be @ 6k rpm+ in 35mph zones to take full effect of the SC. |
09-03-2014, 04:36 PM | #11 | |
17
Rep 221
09-03-2014, 04:41 PM | #12 |
532
Rep 5,498
Everything will still be as functional as stock if the clip was only trimmed. If the lower portion of the clip was completely removed then the front center ducting (that is not used with the ESS VT2 kits) will have nothing to clip to. You will be able to tell when you look at the car because there is not duct leading to the oil cooler. I would want that duct in place.
09-03-2014, 04:48 PM | #13 | |
17
Rep 221
09-03-2014, 05:28 PM | #14 |
532
Rep 5,498
09-03-2014, 05:33 PM | #15 | |
17
Rep 221
09-03-2014, 05:40 PM | #16 |
532
Rep 5,498
See the below pic at the two sections.
The intake duct is a different story. Just hope the owner kept the original. 9691625810_2a54a3c7b9_b by JMEllis, on Flickr You can see where I trimmed my original front clip. Notice this is the whole front of the car behind the bumper we are talking about. Notice the area I trimmed. Some shops completely chop this section off.
09-03-2014, 05:43 PM | #17 |
17
Rep 221
Ah ok now I see the sides cut. That makes more sense, thanks for pointing that out.
What is the air duct to? Or rather, what is it directing air to that requires cooling? Radiator or oil? |
09-05-2014, 10:55 AM | #19 |
97
Rep 2,002
If your not going to keep it on, get a different car imo. If you ever try to sell the car later and are honest, you won't get as many buyers on a 2 owner car that was once supercharged. There are m3's everywhere for sale, i'd be patient and get one that wasn't modded.
Or ..... look at this as a great opportunity to get a 13k supercharger for a steal! Try and keep it on so you can have a very quick car at a fraction of the price to build it yourself.
ESS 650 ACM-R Upgrades |
09-05-2014, 11:53 AM | #20 | ||
2739
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
09-05-2014, 02:04 PM | #21 |
915
Rep 3,456
Drives: Harrop E90 M3
Also keep in mind that the 650 kit pushes the limits of the S65. Assume that it's been driven hard on a regular basis and that it will undoubtedly shorten the life of the engine, as stated above. I would ask for compression and leak down tests to be performed properly a reputable shop prior to agreeing to purchase the car. I would also ask if the car has had any oil analysis tests performed and if so, for the results. It may give you a track record on the car's past, present and a road to the future of the engine. Also consider that the 650 kit requires 93 octane and if that wasn't used at all times. There may be some damage to the engines internals due to detonation if improper octane wasn't used, per ESS' requirements for the kit.
