      09-03-2014, 10:24 AM   #1
Thirdkelley
11
Drives: Blacked Out 128i
Increasing bore and stroke
Been researching a lot about potentially stroking out the n54 engine, taking us from a 3.0 L to a 3.2L.
Firstly, here are the specs of the n54 engine:
Compression ratio 10:2:1
Displacement: 2979 cc
181.8 cu in
Stock Measurements:
Bore: 84mm or 3.30709 in
Stroke: 89.6mm or 3.527559 in
Rod Length: 145mm
-At 7000 rpms pistons go 34.37 m/s
I've found forged pistons for our engine that will take the bore to 86mm. If we can find a way to increase stroke by 2mm, we would get the numbers of a 3.2L engine. I have attached an image of the end calculations from these increases.
The displacement would go from 2979 cc to 3190.7 cc which is a considerable amount!
Just trying I brain storm here.
I also found schrik cams on a euro site for around 480 euros.
08 Alpine White 135i// JB4 G5 ISO/Alpina TCU flash/BMS DCI/Berk race mids/VRSF Cat-less DPs/ER Chargepipe w/HKS BOV/Walbro 255 Lpfp/BMS Flash
      09-03-2014, 12:58 PM   #2
fboutlaw
Cone Cruncher
fboutlaw's Avatar
Drives: Dinan 135i
You'd need a crankshaft designed for the extra displacement. Is there clearance to carry the extra size in the block? Likely, but you lose margin and would have to measure your block to make sure it fits.
Fuel/Air: Once you change the cylinder size, you start stretching what you can do with fuel and air delivery. The car should be ok as it's conservatively boosted and has a super high pressure fuel system, but you'll likely wear down the components faster in the fuel system.
ECU... I'm not sure ours would automatically compensate for the extra size, and it very likely would not run effectively. You'd need a complete re-map of your ecu on a dyno before doing any real driving or an aftermarket ecu that's made for complete custom applications like this.
Cooling: with the extra cylinder size, you'll also have to find a way to amp up engine cooling. Larger radiator? High flow water pump? Not quite sure how to accomplish this one.
Usually in cars with an iron block they do make slightly oversize pistons OEM to be able to rebuild the engine, but I haven't seen BMW do this, and that makes me wonder if going oversize is something they've tried and deemed not worth doing with the aluminum block.
      09-03-2014, 01:17 PM   #3
darkrom
darkrom's Avatar
Drives: 135i
Wouldn't it be cheaper/safer/easier to run bigger turbos?
      09-03-2014, 01:22 PM   #4
DietTab
DietTab's Avatar
12
Drives: 08 135i
displacement wont do anything, you're limited by the air the turbos push.
LSXOCET - 404rwhp @ 1600 lbs curb weight... bonkers fast
      09-03-2014, 03:29 PM   #5
135Pats
135Pats's Avatar
Drives: A few BMWs
This isn't the motor to do that to...native bore to stroke is already aggressive.
Find yourself more fuel and more airflow, the power will follow.
E88 N54 Alpinweiss/Coral Red/Motiv HTA 3586r Tial .82AR/Other stuff...652WHP
F30 N55 XDrive EBII
      09-03-2014, 09:11 PM   #6
flinchy
126
Drives: E82 135i
boring the motor by 2mm will just make it weaker unless you sleeve it, which would probably let you bore it even further
better off keeping the cylinder walls thicker for strength and run more boost.
      09-03-2014, 09:24 PM   #7
Nugget
Nugget's Avatar
650
Drives: G81 M3 Touring, GR Supra GTS
2011 BMW 135i  [10.00]
Not sure you want to be boring out a boosted open deck block.
I'm with everyone else here, just add more (or more efficient) boost.
      09-03-2014, 09:53 PM   #8
amsnow440
Olmec's Temple Guard
amsnow440's Avatar
80
Drives: 2010 135i 6MT, 05 Legacy GT
Also the block comes sleeved from the factory. This tells me that BMW engineers felt that the open deck cylinder walls were not strong enough for a boosted application. I don't know if I'd feel comfortable reducing the size of the cast iron reinforcements they implemented, via boring or re-sleeving.
      09-03-2014, 10:44 PM   #9
Taskmaster
Japan
2465
Drives: M235i 6MT / E92 328 Msport 6MT
headwork and cams - and it won't cost you nearly as much.
      09-04-2014, 12:06 AM   #10
Spoolin Montego
Spoolin Montego's Avatar
604
Drives: 16 m3/20 x5m/23 m3
It would make a lot more sense to just invest that money into upgraded turbos. I'm willing to bore and stroke the engine would cost a fair amount more than the aforementioned.
      10-27-2016, 06:39 AM   #11
BeGood69
BeGood69's Avatar
Drives: 2007 335i, black, JB4 G5
I reached 3204cc
my stroke is +3mm and piston/sleeves 85.5mm
And shaved 200+g from piston/rod/wrist pin/rings and rods and pistons never bigger.
Oh and price wise I am still way below a build cost even with st3 head and ferrea valve kit.
      10-27-2016, 01:34 PM   #12
drogods
Drives: 2010 135i 6AT M-Sport
Originally Posted by BeGood69 View Post
I reached 3204cc
How did this affect the performance of the engine?
