08-25-2014, 04:24 PM | #1 |
Rep 10
Possible bent cam follower: Diagnosis help greatly appreciated!
My E90 M3 (2008, 94k miles) started making this noise:
[u2b]http://youtu.be/_QDGL_cL42M[/u2b] The rhythmical nature of it, yet staggered every so many engine revolutions makes me think it is either a bad/bent cam follower or something with the timing chain/guides. Video is dark, but in any case, noise appears to be coming from the Bank 1 (passenger side) valve cover. Hopefully it is the top of the engine and not deeper! No fault codes, warning lights, oil reads in range. I do however think the power is down 30% or so, but with the noise I didn't drive it very far and didn't try any full out pulls or anything I will be taking the valve cover off and posting back soon, but would love any advice, tips or other similar experiences/noises like you hear in the video. Also, I searched for valve cover (or related DIYs) but closest I could find was a throttle body replacement DIY (at least helps get through taking some of the top stuff of). If anyone knows of something better, please let me know. I could also buy TIS for a day if need be. Thanks all! Jeff |
08-25-2014, 05:44 PM | #2 | |
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
08-25-2014, 06:16 PM | #3 | |
9
Rep 104
08-25-2014, 06:55 PM | #5 |
Grease Monkey
295
Rep 2,646
Copied from my first reply: I can't think how a cam follower could be bent but it is possible that you could have a sticking lifter. The S65 runs hydraulic lifters and by their design and how they fit in the lifter bore, if one were bent/damaged it is most likely that it would want to seize in the bore and your problems would be much greater than just a noise.
08-25-2014, 07:06 PM | #6 |
Rep 10
Thanks. Is the sticking lifter problem similar to that with the S54 engine? Looks like a potential fix for that was warming the engine and then holding rpm at 3-4k for a few minutes. That may have been to purge air, but perhaps that's the issue here.
08-25-2014, 07:20 PM | #7 |
Bad Lieutenant
233
Rep 3,517
S54 has no hydraulic lifters, so no, you mean the N54/N55.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
08-25-2014, 08:47 PM | #8 | |
Grease Monkey
295
Rep 2,646
