08-25-2014, 10:27 AM | #1 |
BimmerPost Supporting Vendor
1007
Rep 4,619
SOLD SOLD SOLD Car is sold, need to sell my coils. PSS10 coilovers - $1,250 - 8500 miles on the setup Setup is off the car, email me for pics off the car. Last edited by Bart@AUTOcouture; 11-10-2014 at 08:39 AM.. |
10-02-2014, 09:46 AM | #5 |
1007
Rep 4,619
BKarktic3,
A common mis-conception on this forum is when people think that coilovers "with EDC" retain your EDC adjustability. You lose the adjustablity the moment you install a manually dampening control system; Bilsten, KW, Ohlin, etc etc etc. There is no difference. The question is do I have EDC delete modules, and the answer is no. These, and all coilover sysmes, work with EDC and non-EDC cars, it's just a question of does your car have the EDC setting, and will it need to be disabled. You can run this on a car with no EDC without a problem. Or you can run this car that is currently equipped with EDC and do 1 of 3 things: 1. Get the modules that trick the car into thinking that the EDC is still operational, and not throw a light on your dash, even though you obviously lost the EDC capability. 2. Code out the light completely via some coding. 3. Live with the light on your dash. Whichever you choose - your car will perform the same. Last edited by Bart@AUTOcouture; 10-02-2014 at 10:54 AM.. |
10-02-2014, 03:57 PM | #6 |
13
Rep 201
Thanks for the clarification!
-Bryan
e92 M3 Coupe DCT | Space Gray/Fox Red | VF620 | Forgestar | RD Sport | B&B |
10-02-2014, 08:31 PM | #7 |
761
Rep 7,408
can you send me pics, e90jin@gmail.com
any reason why you went with blistein and not KW or Ohlin? |
10-03-2014, 11:43 AM | #8 | |
1007
Rep 4,619
I'll snap some pics for you this weekend. |
10-03-2014, 05:03 PM | #9 |
2745
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
FYI - EDC vs Non-EDC uses different top mounts in the rear. You would need to replace them depending on which version the Bilsteins are designed for - relative to what you have. It's a cheap part that only costs around $20 IIRC.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
10-04-2014, 12:22 PM | #10 |
213
Rep 2,602
Dude I pm'ed you yesterday.
10-06-2014, 08:58 AM | #11 | |
1007
Rep 4,619
No pics yet, will have some soon. |
11-11-2014, 03:33 AM | #13 |
103
Rep 999
So will these fit vehicles with edc? Only reason I ask is because after some research the rear struts are different diameter. If they do fit edc equipped car I'm very interested
Performance ESS 625 VT2 Supercharger - CAE Shifter - Revinora race+ axle back - Macht Schnell down pipes - SOSI X-pipe Looks M colors grill - CF trunk - Sapphire Blue Forgestars F14 |
11-11-2014, 09:05 AM | #14 | |
1007
Rep 4,619
11-11-2014, 03:19 PM | #15 |
103
Rep 999
One more question. When it comes to camber plates which ones would work on these?
11-13-2014, 01:50 PM | #16 |
1007
Rep 4,619
11-22-2014, 08:56 PM | #18 |
174
Rep 1,246
Drives: E92 M3
I believe they're progressive.
