08-22-2014, 08:20 PM | #1 |
Rep 30
Grinding noise from 1st to 2nd, 6MT, Potential Solution!
Oh yes...another thread on the famous gears grinding sensation!
I wanted to share something that I noticed and which may help some people out there who have the same issue. I usually feel the gears grinding from 1 to 2 when changing gears at 2000-3500rpm...It happens on occasions. I noticed that when when I try to change gears at higher RPM from 1 to 2, I seldom sense the grinding...and the shift feels smooth...I'm referring to 4000rpm and up. Could it be that the car requires us to change gears at higher RPM when going from 1 to 2? Could it have been designed like that? It's a performance car after all! It's also worth mentioning that my car doesn't suffer of gears grinding in any other gear than when changing from 1 to 2. |
08-22-2014, 09:38 PM | #2 |
BimmerPost Supporting Vendor
3387
Rep 7,541
Mine will grind on a fast shift from 1 --> 2 at redline. I can't stand it sometimes so I will probably put a new transmission in it.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
08-22-2014, 09:54 PM | #3 |
915
Rep 3,456
Drives: Harrop E90 M3
And your new one will probably do it as well :
08-22-2014, 10:12 PM | #4 |
7334
Rep 7,298
BMW is special in that they can spec 3 different manual transmissions (E46 M3, E86 Z4M, E9x M3) from 2 different vendors (Getrag and ZF) with grinding issues / resistance from 1->2.
They never bothered to pay for a transmission that can cope with 8k redlines. |
08-22-2014, 10:22 PM | #5 |
101
Rep 701
08-22-2014, 10:27 PM | #6 |
7334
Rep 7,298
So it's normal that your 65k car has to be babied into 2nd gear? My 20k Mazda 3 6MT in 5 years has never once had a grind no matter how fast it's shifted at any RPM.
08-22-2014, 10:45 PM | #7 | |
101
Rep 701
I agree with OP and have found the sweetest engagement for the 1-2 to happen somewhere in the 4-5K range. Is there room for improvement on this MT? yea for sure, definitely not as smooth as a Honda, or Mazda Funny sensationlistic title...calling it a small design flaw may be more accurate, also routine transmission fluid changes help a lot |
08-22-2014, 11:00 PM | #9 |
7334
Rep 7,298
If your transmission "grinds" with a very loud buzzing sound and almost feels like it does not go into 2nd gear, then have it replaced. From what I understand they don't all do that. The low RPM grind the OP posted about is an issue.
08-22-2014, 11:06 PM | #10 | |
101
Rep 701
The occassional burbble you feel in the stick at low rpms on the 1-2.. I don't agree that is an issue, just design of the trans to shift at higer rpms. |
08-23-2014, 09:03 AM | #13 |
146
Rep 1,201
Agreed. BMW used this transmission because it was convenient, not for any performance reason The 1st to 2nd gear change on this car is one of the worst I've ever seen. I'd rather 1st be made taller TBH. There'd be less drop-off and less wheel-spin. Make it shift into 2nd at like 50-55mph or something.
'08 E90 w/ just boltons
'09 Z4 sDrive35i w/ just boltons |
08-23-2014, 09:47 AM | #14 |
2511
Rep 4,381
You should be able to shift from 1st to 2nd without grinding even if the gearbox was built with no syncromesh at all.
The syncromesh should be strong enough to be able to resist the occasional poorly timed shift. If you make poorly timed shifts and ram it into second gear enough times you will eventually wear out the sycromesh rings. |
08-23-2014, 10:25 AM | #15 |
Putcha ang ganda...
281
Rep 5,441
4 years ago my tranny had issues with the tranny due to second 1st 2nd gear shifts. I had a really hard time shifting to 2nd not sure what caused it but dealer replaced it with a new Tranny..
But the issue that everyone is talking about is normal the s65 tranny sucks on 1st and 2nd gear u have to shift it at the right rpm otherwise it will grind.. I usually just try to feel it engage then shift.. But fast shift between 1-2 gears sucks and will grind
08-24-2014, 08:15 AM | #16 |
146
Rep 1,201
Mine never grinds, but it will bog like hell even if you hit it perfectly. I found the only way to avoid bog is a little clutch slip on the engage point and afterwards.
08-24-2014, 08:57 AM | #17 |
274
Rep 2,664
Drives: Goggomobil
Solution ... skip 2 and go from 1 to 3. Problem solved. It works form me when I am not driving spirited. Saves fuel to in stop-n-go city traffic.
F86 X6///
08-24-2014, 09:52 AM | #18 | |
2511
Rep 4,381
But thats the case with any manual box if you try and make the shift too quickly and with too much force. |
