BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
European Auto Source (EAS)
      08-22-2014, 07:55 PM   #1
jblaze21
17
Drives: 2008 E90 M3
Questions on superchargers
I'm considering buying a M3 with a VT2-650 supercharger kit. Now I've never had a supercharger before so I'm not terribly knowledgeable about that.
I'm wondering what extra maintenance/special care you have to take with the supercharger?
Is there anything to watch for with a car with a supercharger? Does the engine get stressed more? More frequent oil changes, etc?
Any gotcha's regarding superchargers?
Any advice and knowledge is appreciated. Thanks.
      08-22-2014, 08:06 PM   #2
JEllis
JEllis's Avatar
532
Drives: E36 M3, E92 M3
I change my oil every 3000 miles. I would do it regardless of the supercharger.
You need to change the supercharger oil every 7000 miles.
You need to check your air filter frequently for debris.
Spark plugs should get changed, at least checked, every 10,000 miles.
I frequently check my bracket and supercharger bolts to ensure everything is tight.
Other than that, enjoy!
http://www.m3post.com/forums/signaturepics/sigpic14547_7.gif
Instagram: jellismotorwerks
      08-23-2014, 06:02 AM   #3
BobS
BobS's Avatar
97
Drives: M3
What Jellis said. I would suggest getting a gauge that shows AFR's as well so you can monitor in real time how he car is running. My P3 gauge does the job perfectly...oh and you can see boost too ;-)
ESS 650 ACM-R Upgrades
      08-23-2014, 10:58 AM   #4
jblaze21
17
Drives: 2008 E90 M3
The car I'm looking at has a P3 gauge as well.
      08-23-2014, 11:21 AM   #5
BobS
BobS's Avatar
97
Drives: M3
Perfect! But not all p3 gauges show afr. Some just show boost. I think its the earlier ones or the base P3 gauge that only show boost.
Mine shows EGT, AFR, Boost, IAT's, 0-60, etc....
      08-23-2014, 01:26 PM   #6
jblaze21
17
Drives: 2008 E90 M3
Another question: how is the power delivered? Is it only "active" when above 5500 rpms + or is the power available all throughout the rpm range?
Does it help with low end torque?
I DD this car so I'm not running around town at 6k rpm all day so I'm not sure how much use I'd get out of it. I don't drag or track either. Might be overkill but if it has real life DD applications for "spirited" driving, then I'd get some use out of it.
Thanks.
      08-23-2014, 01:53 PM   #7
JABSprings
11
Drives: '11 E92 / ESS VT2-650
ESS recomends min of 93 octane with 650 kit. Not all states have such.
      08-23-2014, 03:40 PM   #8
JPH704
JPH704's Avatar
Drives: Huracan Performante & 720s
^ this
Also periodically inspect the belt and pulleys.
2019 McLaren 720s / 2018 Lamborghini Huracan Performante / 2019 Porsche Macan Turbo / 2016 BMW M3/// IG @jon.hagerty
      08-23-2014, 04:05 PM   #9
Ezio
Ezio's Avatar
Drives: 2023 Alfa Romeo, 2023 m240i
the car is for sure under more stress with 600+HP. everything drive train part will wear faster if you drive it hard.
although that doesn't mean you will have problems. it just means you gotta take more care of the car. i wont go around doing burnouts, and driving hard on a cold engine etc.
usually people like to buy a M3, and put there own blower on it. So they know the car hasn't been abused with lots of power Vs abused with stock power.
      08-23-2014, 11:26 PM   #10
Longboarder
Longboarder's Avatar
3431
Drives: 2016 BMW i8
Thanks.
There is more torque but boost is linear with any centrifugal supercharger. The power above 6,500 is insane...tires can start spinning so be careful. The power band is similar to something like a Ferrari 458 Italia so you need to keep the rpms up.
You should really try to take a drive in one if you can.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S
1979 Porsche 911 Turbo (930)
a couple others
IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w
      08-24-2014, 07:59 PM   #11
TommyLights
213
Drives: Man
I heard the newer P3's dont work well with the 08's and only show boost. That right?
m3post
