08-18-2014, 08:44 AM | #1 |
560
Rep 570
Intercooler/Heat Exchanger Efficiency
Some user information :-)
After driving my M4 for about two hours, in 80degF heat on Saturday, I stopped and opened the hood to check things out. The engine was hot and underhood was hot, as well (normal operating temp, of course). I put my hand on the water/heat exchanger (photo) for the turbo intercooler(s) and it was VERY cool. I'll be curious how it feels after a lap session on-track, but I'm impressed w/the indicated efficiency so far! -Brian S. |
08-18-2014, 01:16 PM | #2 |
294
Rep 1,515
Drives: Ever changing fleet
After beating mine around SPA for multiple laps, I pulled in and immediately popped the hood and felt the core. It was downright cool to the touch. I think our AWIC system works better on the street with actual flow over the heat exchanger than on the dyno. I don't think IATs are as much as a problem in the real world, but I'll find out soon once I start data logging it.
23 iX M60, 24 GT3 RS Weissach, 22 Rivian R1T, 23 RS3, 13 E92 M3 Competition: Akra Evo, KW V3, etc
08-19-2014, 06:47 AM | #3 |
112
Rep 969
Saw this yesterday and so I popped the hood as soon as I pulled into my garage.. The intercooler was legitimately cool. Like cold to the touch. Pretty unbelievable.
Th3_Transport3r24.00 |
08-23-2014, 02:20 PM | #4 |
www.facebook.com/weshowellcreative
59
Rep 623
Drives: 2015 AW M4 Coupe Project Car
I've heard that the AC system runs through the intercooler in some fashion. Would make sense as it gets cool to the touch pretty quickly after starting the car.
08-26-2014, 07:33 PM | #5 | |
BimmerPost Supporting Vendor
24193
Rep 190,805
As you will see once you start datalogging, as soon as IAT jumps after a pull, car will not make the same power as 5 minutes earlier.
08-26-2014, 08:21 PM | #7 |
21117
Rep 20,741
Drives: 2021 911 turbo
The S55 has an air-to-liquid intercooler rather than air-to-air as on the N55/54. It is much more resistant to heat soak due to the higher thermal mass of the system.
08-26-2014, 08:23 PM | #8 |
21117
Rep 20,741
Looking at pictures from the intercooler system, there does not seem to be any piping other than the ones needed for the closed loop coolant of the system.
08-26-2014, 09:46 PM | #9 | |
24193
Rep 190,805
I am saying that if IAT gets high, car will not performn well. Are IAT going to get high with the stock intercooler? i dont know we will have to wait for datalogs and find out.
08-26-2014, 10:46 PM | #10 | |
Resident Engineer
135
Rep 748
If anything, I think it would be great to log 1/4 mile pulls and see how each successive run affects the IAT and temperature of the intercooler. I'll confirm what @A418t81 has said. After 6 to 8 consecutive laps at Spa, my intercooler did not experience heat soak. The unit was cool to the touch. <-- Not scientific, but I imagine data logs will likely have similar results.
///M4 (SO/BLK/BLK) Exec, LED, Blk 19s, HK, 6MT <- SOLD
///M2 (LBB), Exec, 6MT <- SOLD 2014 Land Cruiser, Slee Sliders, OME Lift, ARB Onboard Air European Delivery Journal & F8X Door Rattle Fix Machine Shop Directory - www.mfgcenter.com |
08-27-2014, 12:32 PM | #11 |
JOSH SHOKRI.
524
Rep 5,881
Drives: 991 GT3RS, 964, Raptor
I ran my car in 98 degrees on Sunday, full 20 minute session.
With 91 octane, it sucked. It was getting heat soaked. I dumped in 100 octane, I couldn't have been happier.
Current: 16 991 GT3RS , 91 964 C2, 17 Raptor | Past: 2015 991 GT3, 2015 i3,15 YMB F80 M3, 13 E92 M3 DCT, 08 E92 M3 6MT, 07 E60 M5, 02 E46 M3
Instagram: @josh_speeddistrict #SpeedDistrict @SpeedDistrict |
08-27-2014, 12:37 PM | #12 |
61
Rep 776
You guys make me laugh. Does anyone have an infrared thermometer?
My friend drove his M6 3 miles in 94 degree ambient tempts. Popped the hood and the HE was 154 degrees by infrared thermometer. I doubt the S55 is much different. |
08-27-2014, 11:08 PM | #13 |
2095
Rep 43,350
Water takes longer to cool down after it's been warmed up in comparison to air. That means that once the water heat soaks, it'll take longer to get it down to temp.
This is why a majority of race teams use air to air intercoolers on turbocharged setups. BMW is incorporating the water to air intercoolers on most of their performance models in order to reduce as much transient response loss as possible due to the turbocharged system. They want you to feel like this is a naturally aspirated motor. While the existing system is ok for a stock car, it's certainly going to require upgrading at higher than stock HP and boost levels. |
08-28-2014, 08:00 AM | #14 |
560
Rep 570
My original point was just that it's a bit of novelty to see how thermally-efficient systems work. However, water-to-air intercoolers are more thermally-efficient than air-to-air (and are easier to package...esp in the case of the M5/M6) but when ambient air temps are high, not much you can do other than try to drive intake temperatures to ambient (still hot if it's 95 deg F outside). The M4 system is more carefully designed for more efficient cooling than the M5/M6 system, due to redundant intercoolers (two) and volume of the system.
08-28-2014, 12:28 PM | #15 | |
61
Rep 776
Pics of the duplicate heat exchangers? What is the volume of each system? |
08-28-2014, 12:33 PM | #16 |
61
Rep 776
I would argue that placing a heat exchanger just above the head is not the ideal location for heat management. Perhaps for packaging/shortening airflow path length, but not for cooling.
08-28-2014, 02:23 PM | #17 | |
8202
Rep 18,823
Drives: BMW
Very happy. Cooling has MUCH improved on the S55 compared to S65.
08-28-2014, 04:12 PM | #18 |
560
Rep 570
Diagram - Charge Air coolers
Great diagram on page 87 (Page 93 in the Abobe reader) of the attached BMW Tech Guide document that was posted here a month or so back. Tried to copy/paste, but I'm definitely software challenged, so couldn't make it work.
08-28-2014, 07:44 PM | #19 |
JOSH SHOKRI.
524
Rep 5,881
You rock!!! Great information.
08-29-2014, 05:59 PM | #20 | |
352
Rep 2,176
08-29-2014, 09:02 PM | #21 | |
61
Rep 776
It's not so much a redundant HE as they're plumbed in parallel. It looks like more of an attempt to optimize utilization of frontal area airflow. Glancing through the bumper of the M6, I think it may have essentially the same setup (with respect to the IC HE's in the nose). System capacity is 4L. Thanks for posting (or re-posting). EDIT: Read the 63tu engine detail, it actually uses THREE cores to cool the fluid which cools the intake air charge. The s55 engine detail indicates system fluid capacity and system heat dissipation. The 63tu detail does not. It is likely based on what I've read that the 63tu system has the ability to dissipate more heat the the system on the s55. Perhaps more important and unclear at this point is system heat dissipation relative to power (heat) production i.e. which system has more head room. Last edited by turbo8765; 08-30-2014 at 08:13 AM.. |
09-03-2014, 07:41 AM | #22 |
560
Rep 570
S63TU
What's interesting when contrasting the S63 TU system and the S55 system is: The V-8 certainly has more cooling surface area for reducing intake charge temps that the I-6 does, but the S55 uses an auxillary coolant radiator up front to also cool the engine. The S63 engine radiator looks enormous, so maybe that is the balance.
One of the features of good engineering design is proper evaluation of the limitations and minimizing them. BMW has done some hard work here and incorporated some really advanced designs (separate cooling circuits for the turbo coolant flow, etc.). I'll be curious to see where the oil temps climb to, on-track, for the F82. The highest I ever saw on my E90 was at Mt. Tremblant on a 95 degree F day. I was seeing around 250 and started to dial-back my revs to drop the oil temps. |
