08-15-2014, 02:08 PM | #1 |
BimmerPost Supporting Vendor
8152
Rep 18,821
Drives: BMW
▀▄ eas | DIY: Rear Foglamp Mod
Free mods are the best. A popular early mod on the previous E9X chassis was the Rear Foglamp, or Euro fogs.
Rear fog lamps (or "fog taillamps") have since the 1970s been mandatory equipment on all cars sold in countries that adhere to European (ECE) vehicle safety Regulation 48, which governs the installation and hookup of lights and reflectors. But, they're only just beginning to show up on US-market cars. They are intense red lights manually switched on by the driver in conditions of very poor visibility (heavy fog, rain, snow) to increase your car's visibility to vehicles behind you. A rear fog lamp is very much brighter than regular taillights, and is in many cases even more intense than brake lamps. Regulations in most of the world, including North America, permit vehicles to be equipped with one or two rear fog lamps. If only one rear fog is fitted, it must be on the driver's side of the vehicle. It's safest and best to have just one rear fog, much as it offends the sense of symmetry of those who don't know any better. Having two is legal, but makes it much more difficult for following drivers to see a change in your car's rear lights when you step on the brake. Many vehicles that do come from the factory with rear fog functionality have rear fog optics and sockets on both sides, with only one wired up -- this isn't a factory oversight. It's done this way because the "driver's side" of the car varies depending on which country the car is sold in! The headlamp switch is very similar as a base F30/F32, which is equipped with front foglamps. These buttons are "blank" on the M models by injection-molded "stops", which physically limit the button from being depressed. While the quick and easy way to accomplish this would be to order a Euro Headlight switch, but where's the fun in that? Instead, we're going to mod the existing US switch. Let's begin. 1. Remove driver's side air vent, pulling slightly on outward edges 2. Remove Headlight switch, press on (2) outward retaining clips and pull 3. Disconnect headlight switch connector 4. With headlight switch on bench, slightly lift on (6) retaining tabs and separate halves 5. Pull apart plastic housing from headlight switch 6. In this image, you can see existing buttons for Front (upper) and Rear (lower) foglamps, even the Front foglamp LED is lit on US switches when powered on. Rear foglamps when activated will illuminate an icon on the instrument cluster after coding is completed. 7. Position of switches, we will be working with the rear fog (bottom switch) only 8. Press bottom switch out from backside 9. Injection-molded plastic "stops" are integrated on US switch assemblies, these will need to be carefully removed with a hobby knife or razor. There are (3) stops total (two on other side) 10. Reinsert Rear Foglamp back into headlight switch 11. Completed shot, with Rear Foglamp button depressed for illustration. This will be pressed back out flush when reassembled back together. 12. Reassemble headlight switch housing, snaps back into place. 13. Reinstall headlight switch and air vent back into place Coding Coding is required for the switch to operate. REM Module REM -> Mapping_Nebelschlussl_L_output: nsl_l REM -> Mapping_Nebelschlussl_R_output: nsl_r FEM_BODY 3060 NSL_Verbaut: verbaut Operation Once coded, operation is exactly like if you were equipped with a EU Headlight switch. Simply flip on the headlamps, press the bottom headlight button and we are greeted with our new Rear Foglamps: Standard Rear Foglamps Enabled As an added bonus, an amber Rear Foglamp icon illuminates when button is activated: This and much more covered in our journal thread here: http://f80.bimmerpost.com/forums/sho....php?t=1020487
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 08-23-2015 at 08:35 PM.. |
19
08-15-2014, 03:32 PM | #2 |
Commander-In-Chief
2121
Rep 8,922
Rear fog activation
Thanks, as usual, guys!
08-15-2014, 05:12 PM | #3 |
10816
Rep 27,599
I need this! add it to the list lol when I come down in a week
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
08-15-2014, 06:05 PM | #4 |
8152
Rep 18,821
Drives: BMW
no prob, you got it!
PayamFSU209.00 |
08-28-2014, 09:46 AM | #5 |
54
Rep 121
Drives: 2015 M3
Thanks. I will certainly do that to my car when I get it.
Question: What does the front fog lamp switch do in an F80/82 car since there aren't any front fog lights? Is that a switch we can re-purpose for something else? |
08-28-2014, 11:10 AM | #6 | |
8152
Rep 18,821
Drives: BMW
There are only 3 wires going to the switch itself, the engaging pin would need to be sourced from the Front Electronics Module (FEM_BODY).
08-30-2014, 12:24 AM | #7 |
95
Rep 293
Drives: 2015 BMW M4
W00t! I might come down for this too! I remember you guys down at EAS was playing around with it on my M4 when it was there, but we couldn't figure out why it didn't work! Coding it is!
09-20-2014, 01:48 PM | #9 |
14
Rep 80
These instructions are really great. No tools needed up to the point of using the razor to shave off the tabs. The A/C duct is best pulled out from the bottom. I used a mirror to locate the tabs on the top of the switch to depress them then rotate the switch out from the top. This is an easy and cool mod.
09-22-2014, 06:02 PM | #10 |
Maverick
57
Rep 228
Wait a minit---our cars come with rear fog lights, and those cheapies at BMW don't activate it? We have to buy some expensive switch and have the dealer mod it?
Ludicrous. M |
09-22-2014, 06:09 PM | #11 | |
14
Rep 80
There is nothing to buy. Modify the switch as indicated a do a little coding. And the reason BMW didn't activate it in the first place is that rear fog lights are probably in the gray area legally with the USDOT. |
09-22-2014, 09:45 PM | #12 | |
118
Rep 287
09-23-2014, 08:24 AM | #13 |
Commander-In-Chief
2121
Rep 8,922
In this case they are not saving anything; the switch & lights are installed. In fact they have to have a special version of the switch with buttons locked off. Makes no sense, other than the fact that Americans don't know how to use them properly and drive around with them on all the time.
BMWjunge0.00 |
09-24-2014, 01:54 PM | #14 | |
8152
Rep 18,821
Drives: BMW
09-26-2014, 01:29 PM | #15 |
54
Rep 121
Drives: 2015 M3
Works great!
09-26-2014, 03:38 PM | #17 | |
54
Rep 121
Drives: 2015 M3
It was hard enough to do that I cut the tabs off the upper switch too, just in case someone finds a use for it! |
09-26-2014, 11:55 PM | #18 |
14
Rep 80
Use an inspection mirror or a makeup mirror stolen from your wife to look at the metal (not plastic) tabs from the inside. Once you see where they are and how they depress, it becomes much easier.
03-07-2015, 07:35 PM | #19 |
226
Rep 482
Honestly it is quite easy provided you push the end of the clip down. The key is to use either a 90 degree l shaped panel tool or something similar to push down the part of the clip that is pressing into the back of the dash. If you just try to press the far end of the clip with your finger it will not depress the part of the clip hitting the dash.
03-07-2015, 09:42 PM | #20 |
137
Rep 236
Drives: Various
Great information Tom, but I was able to simply pull each of the 2 buttons out without having to take out the vent or the whole switch.
I used a regular house knife. I covered the whole blade with painters blue tape. A couple of turns around the blade. Inserted the covered blade tip on the button's edge closest to the driver's door. Simply moved the knife towards the front of the car and the button came off. Proceeded to cut the plastic stops as you showed. The car was already coded for rear fogs. |
iatacs19458.50 |
03-09-2015, 01:33 PM | #21 | |
8152
Rep 18,821
Drives: BMW
03-09-2015, 08:40 PM | #22 |
137
Rep 236
Drives: Various
Took a couple of snaps to post here, in case my details sounded confusing. Nevertheless, Tom's snaps from the original mod were extremely useful in getting this mod completed, and giving me the idea to try to pry the buttons off without having to remove the vent.
One thing I also found was a small mistake in the coding Tom. You have it showing both left hand side entries. Here is the correction: REM -> 3063 -> Mapping_Nebelschlussl_L_output (Value = nsl_l) REM -> 3063 -> Mapping_Nebelschlussl_R_output (Value = nsl_r) Last edited by nene; 03-09-2015 at 08:47 PM.. |
18
MattJ13201.50 iatacs19458.50 Race_Doc11459.50 CanadianDriver98.50 chuckles01188.50 Whatcoloristhat66.50 hoyas490131.50 Bon F80127.00 BMWjunge0.00 |
