proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > Regional Forums > CANADA
      08-08-2014, 08:57 AM   #1
xtasyx
10
Drives: M4
Gas
I'm just wondering, what are you guys using for gas for your M?
I've been using Esso 91 for my E46, but i'm thinking because it's a turbo, maybe I should start considering Petro's 94 for the M4.
Esso has better reward program than Petro though IMO lol.
Thoughts?
      08-08-2014, 09:23 AM   #2
hacxyzzy
hacxyzzy's Avatar
50
Drives: e46 M3, SO/SB M4 MT
I've been using Shell's V-power since it's one of the few gas sources that doesn't contain ethanol
      08-08-2014, 09:25 AM   #3
hacxyzzy
hacxyzzy's Avatar
50
Oh forgot to mention - I also get discounts on gas purchases as a result of shopping at Sobeys. So the more food I buy, the greater the discount per liter of gas
      08-08-2014, 10:00 AM   #4
redline9001
redline9001's Avatar
223
Drives: E92 M3, F15 X5, G14 F150
2011 E92 M3 | JEREZ BLACK | EXTENDED BAMBOO NOVILLO | EXECUTIVE PKG | M-DRIVE | EDC | M-DCT
MODS | KW S/O | HRE P40SC | Akra Evo |ESS Akra Tune | ESS DCT tune | BMC drop in | StopTech Trophies | TMS Pulley | LUX V3 | BE Bearings and BE ARP rod bolts
      08-08-2014, 10:27 AM   #5
E92LNGCGY
434
Drives: F97/Q5/982 GT4
Do you actually feel a difference with Shell gas? I've only been using Esso because of the reward program.
      08-08-2014, 11:09 AM   #6
redfox
INSTAGRAM: @yaasplease
redfox's Avatar
166
Drives: 2015 YMB M4
BMW recommends 93. I've got the P3Car Gauge installed which shows me ignition timing live. Timing retards more with 91 versus 94 from Petro under WOT. Ethanol is not an issue with this modern engines. But you will get more more out of 94.
2015 ///M4: M/Vorsteiner Aero, P3Cars, HRE R101, Dinan S2, Coils & Intake; Eis/Akra Exhaust
2013 WRX Hatchback: LED Conversion, Blacked Out, Rally Armor
2015 Macan Turbo: Techart Exhaust, Cargraphics Lowering Module, Blacked Out
      08-08-2014, 11:12 AM   #7
E92LNGCGY
434
Good to know. I will have to try 94 and see if I can feel a difference.
      08-08-2014, 12:06 PM   #8
kbb
kbb's Avatar
129
Drives: 24' M3cs, 23' 911 GTS
I'm using Esso 93 on mine. I noticed a minimal improvement in fuel economy on my e92 m3. It's just 2 cents or so more per litre over 91.
      08-08-2014, 12:09 PM   #9
hacxyzzy
hacxyzzy's Avatar
50
That's a loaded question. In my experience, it's really hard for me to feel performance differences between blends of gasoline since the ECU can compensate for a lot. I have several reasons for using non-ethanol gasoline:
- Ethanol laced gasoline, depending upon the percentage, provides lower mpg
- Ethanol will readily dissolve water so any moisture in the gas could become an issue
And finally, there's the philosphical objections that I have to the forced use of ethanol blended gasoline
      08-08-2014, 06:44 PM   #10
farbmw
farbmw's Avatar
Trinidad_and_tobago
422
Drives: 2015 M4 6SPD MANUAL!
Hate to get off topic but any pics of the P3 Car gauge? I had on my 335is (I still have it actually) and where did you get it?
I run 94 in Europe I found 98!
The car loves it even on the dyno.
      08-09-2014, 06:59 AM   #11
Kuwen
Drives: 2015 M3 6MT
I've been using Petro 94 for my
first two tanks but I don't really have a reference for 91 octane. At 3 cents a litre difference, hard to debate about an increase of ~$1.50 per tank.
      08-09-2014, 10:14 PM   #12
redfox
redfox's Avatar
166
Drives: 2015 YMB M4
No pics, but looks the same as the F30 ones on the P3Car website. It's the same gauge. F30 uses digital boost control as well. So no difference.
f80post
