08-05-2014, 06:08 PM | #1 |
163
Rep 1,790
Installed TP's... what to do with the stock bracket
So I spent 3 hours on my back under my car installing my Test Pipes. It was a success with a sore back (now) but its worth it every time I hit that start button . Anyways onto my question. So you have two exhaust mounting brackets (passenger and driver) and only one is used once the test pipes are installed. What is everyone doing to keep the driver side bracket from rattling? I have the ACM test pipes and they dont have a spot to connect the pipes back to the stock bracket.
Thanks!
Stupid Photobucket
08-05-2014, 06:14 PM | #2 |
Currently Driving
269
Rep 1,426
Drives: BPM tuned '13 AW ZCP E92 M3
I removed mine.
08-05-2014, 06:24 PM | #3 |
163
Rep 1,790
like the whole thing I assume? I thought about trying to put something rubber between it just because I hate exhaust rattle (it so honda/JDM)
Stupid Photobucket
08-05-2014, 06:51 PM | #4 |
145
Rep 1,130
You're saying the bracket is just sitting loose on your x-pipe? Remove it or figure out a way to make it useful.
Without the bracket I can feel some vibration in the accelerator. I am going to try to find a way to attach it better. |
08-05-2014, 07:42 PM | #5 |
Currently Driving
269
Rep 1,426
08-05-2014, 09:08 PM | #9 |
433
Rep 1,286
You shouldn't have a rattle or noise. It might depend on the test pipe but I was able to retain the passenger side bracket but not the driver's side. On that side you just have to remove the whole bracket (the thing that goes all the way around the pipe) and let it sit free.
I had a rattle initially too, on the driver's side but it was because the clamp between the header and test pipe was not holding the metal gasket tight so it rattled between the header and test pipe. This may be what yours is doing. Suggest going under the car, grab the test pipe and shake it back and forth, you should be able to figure out where the noise is coming from. |
08-05-2014, 09:43 PM | #10 |
163
Rep 1,790
I used the clamps.
Stupid Photobucket
08-05-2014, 09:45 PM | #11 |
163
Rep 1,790
This is the bracket im talking about. Only the passenger side can be used. The driver-side is just in limbo...
Stupid Photobucket
08-06-2014, 07:56 AM | #12 |
205
Rep 729
Most installations I've seen have the bracket removed. However, I think AA's test pipes have a brace built in so that you can retain and use the bracket. Maybe you can look at them and get a brace fabricated and welded into your test pipes.
08-06-2014, 09:15 AM | #14 |
569
Rep 3,742
I believe it also removes some exhaust rattle and drone. If you look at where it attaches, the holes appear to be rubber lined as if to dampen sound. My bracket is currently removed and there is some additional noise as a result.
08-06-2014, 09:16 AM | #15 | |
163
Rep 1,790
Stupid Photobucket
08-07-2014, 07:10 PM | #16 |
84
Rep 2,792
Mine has been off the car for about three years now. Fabspeed setup with HFC.
2008 IB E92 M3| BBS | KW | Arkym | Platte Forme A.G. | Active Autowerke | K&N | Fabspeed | Dinan | Evolve-R |
