Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Engine / Drivetrain / Exhaust / Bolt-ons / Tuning
      08-03-2014, 03:18 PM   #1
Needsdecaf
Needsdecaf's Avatar
6599
Drives: 2024 G80 Comp xDrive
Golf Tee Mod?
I know that the infamous "golf tee mod" has long been popular with BMW's that have vacuum operated exhaust flaps. Has anyone who owns an F8X found a way to wire the exhaust flap open so that it's at it's loudest setting all the time?
Has anyone who owns one really had a desire to?
Just curious.
      08-03-2014, 03:32 PM   #2
/// M sa
/// M sa's Avatar
241
Drives: F80 MG
I think I read somewhere that it doesn't work with the M. I will try mike out and see if it works.
      08-03-2014, 03:36 PM   #3
parky1215
parky1215's Avatar
564
Drives: F90 M5C | G06 X6 M60i
You just have to unplug (leave it unplugged) wire to valve when exhaust flap is fully open.
      08-03-2014, 03:46 PM   #4
/// M sa
/// M sa's Avatar
241
Drives: F80 MG
At what point? Turn car on and unplug from trunk?
      08-03-2014, 04:46 PM   #5
kinimod
134
Drives: 911 GT3
If true this could be a simple cool mod.
      08-03-2014, 04:59 PM   #6
bishop4142
bishop4142's Avatar
Drives: 2024 M4 Convertible
  [0.00]
I thought if you had the engine dynamic mode set to sport plus the butterfly remained opened at all times
      08-03-2014, 05:04 PM   #7
parky1215
parky1215's Avatar
564
I don't know at what point.
But that's what EAS going to do to my car when I bring her in next week.
      08-03-2014, 05:04 PM   #8
bdoooh
Drives: 2014 SSII M5 CP
I thought the same. If you switch from efficient to sport or sport+ the idle exhaust is louder.
      08-03-2014, 05:44 PM   #9
ss134
ss134's Avatar
United Kingdom
230
Drives: F80 M3
That's correct. Set engine response to Sport + and the valves stay open. Easy mod!!!
2014 AW F80 M3 DCT
2011 AW E90 M3 DCT - Sold
2010 JZB E90 M3 DCT - Sold
2009 6MT E90 LCI 335i M -Sport - Sold
      08-03-2014, 05:48 PM   #10
tooch
Drives: F82
96 E31 JB
07 E92 AW
F82 BSM
      08-03-2014, 06:00 PM   #11
parky1215
parky1215's Avatar
564
This is not true.
They still close in sport+ mode.
Here is quote from interview with bmw m3/m4 acoustic engineer, Rainer Drees.
"For instance, if you select the COMFORT mode, the exhaust valves are fully closed in the lower revs ranges. If there is a greater load demand at higher engine speeds, they open up. When driving with a constant load in COMFORT mode, the valves generally remain closed to achieve a maximum level of everyday comfort over long distances.
In SPORT and SPORT PLUS modes, other engine characteristics are selected for controlling the exhaust valves. At lower gears, the exhaust valves are always open, while when higher gears are selected under constant driving conditions, they are closed; however, if the load conditions change accordingly, they open up in a flash. There are also ranges in which we have chosen to close the valves, for instance at low engine speeds in high gears. In these ranges, which are frequently selected in the automatic mode of the M DKG Drivelogic for driving at maximum efficiency, the exhaust tract in turbo engines would have a tendency to drone if there were no damping."
      08-03-2014, 06:17 PM   #12
bishop4142
bishop4142's Avatar
  [0.00]
"At lower gears they are open" I'm okay with that because at highway speeds who is really going to hear it.
      08-03-2014, 06:22 PM   #13
tdizzle
Drives: 2017 F80 ZCP
If it's the same as the F30 it's right under the drivers side muffler.
      08-03-2014, 08:02 PM   #14
BMWJ
61
Drives: 2011 E92 M3
This is not true.
This is great. Far better than open all the time. Just when you need it
      08-03-2014, 08:46 PM   #15
ss134
ss134's Avatar
United Kingdom
230
Drives: F80 M3
Exactly. In lower gears it's open - good. While cruising its quieter- good. While cruising and you put your foot down it's louder- good. Can't see the issue at all.
2014 AW F80 M3 DCT
      08-07-2014, 08:57 AM   #16
bobbyz
13
Drives: E90 M3
Good for the DCT guys to just always dump it into Sport+. But as a 6MT guy, I want the option to be able to drive in Sport (still retain Rev Matching), while still having the flaps always open.
Would like more information or a (DIY) on where to disconnect when flap is open to keep it open.
Anyone successfully done this yet?
****EDIT**** JUST SAW THE DIY POP UP IN THAT SECTION OF THE FORUM. THANKS!!!!!
      08-07-2014, 04:11 PM   #17
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
http://f80.bimmerpost.com/forums/sho....php?t=1006077
Thanks.
Anyway, it makes a big low RPM difference. I covered the plugs with a rubber glove and tied them off, and tucked them up under the heat shields.
DSC_3369 by Kit W, on Flickr
      09-07-2014, 09:28 AM   #18
Axlefoley
Drives: M4
Just unplugged mine. Most definitely makes a difference. You can have it in Eco mode and it still barks.
I didn't experience any drone and it eliminates the start up rattle.
      09-07-2014, 12:25 PM   #19
TMR
TMR's Avatar
Drives: M3
unplug the connectors and if the valves are shut, grab a long screw driver and push them open. Or you can put it in sport plus and go unplug the connectors. Sounds good!
2015 M3 BPM Tuned, Eibach, Magnaflow and more www.tmrmzine.com/m3/f80
SOLD E92 Slēk Carbon Fiber Widebody M3 www.tmrmzine.com/m3/slek/
SOLD E92 335i Stage 3+ with all the toys www.tmrmzine.com/335/
SOLD E39 M5 Modded, What a great car! www.tmrmzine.com/m5/
      12-20-2014, 02:50 PM   #20
r3dbimmer89
r3dbimmer89's Avatar
331
Drives: P-Car
I have mine unplugged with the valves open and it has a lot more character but there is a drone when cruising on the freeway which can be annoying.
Past: BMW (22 G20 M340i, 15 F80 ///M3, 12 E92 335i, 08 E90 335i, 02 E46 325i)
Mercedes-Benz, Porsche, VW, Lexus
Present: 24 992 C2
      03-07-2015, 10:01 AM   #21
biggripper
biggripper's Avatar
725
Drives: 2024 G80 M3 Comp xDrive
Has anyone tried unplugging just one...maybe that would be a happy medium. More bark, less drone?
CURRENT///G80 M3CX | Isle Of Man Green | Kyalami Orange | Bi-Color 826M Wheels
FORMER ///F80 M3 ZCP | Yas Marina Blue | Black | DCT | Black 666M Wheels
FORMER ///F87 M2C | Alpine White/Orange | DCT | Black 788M Wheels
FORMER ///F87 M2C | Sunset Orange/Orange | 6MT | Black 788M Wheels
FORMER ///F82 M4 | SSII | Full SO | 6MT | Black 437M Wheels
      10-25-2015, 10:41 PM   #22
Cfichman
48
Drives: Tesla M3P
Thanks.
I've done this and I'm wondering if anyone can help me find the extra plugs so I don't to just uses electrical tape to protect them from dirt getting into the connectors. I'd like to find the plugs from somewhere online so I can plug a blank male into the actual actuator and a female into the part that is unplugged. Does this make sense?
f80post
