08-03-2014, 11:12 AM | #1 |
Rep 16
oil change overfill warning
Help, had a leak in the oil filler cap and had my indy shop replace it. I lost a significant amount of oil and towed the car to the shop. My receipt indicateshe added 5 qtrs. When the car came back, the max oil fill warning was on. It's the weekend so I could not call the shop to confirm the level after adding.
I read many posts about overfilling so decided to remove some oil to see if the warning goes away. I removed 1 qt and checked level by starting the car (but not driving or revving) still max fill. Removed another quarter and still over max. Removed another 1/2 quarter and still over max. I am afraid to remove much more. Anyone had similar issue or can help? How quarters or liters can the engine hold? I want the dipstick back |
08-03-2014, 11:51 AM | #2 |
542
Rep 1,195
When you are checking the oil level make sure the car is fully warm on an even surface and then manually reset the oil level measurement by holding down the stalk button.
08-03-2014, 12:42 PM | #4 |
514
Rep 3,482
they added 5 quarts?!?!!?
Honestly, at this point, I would just do another oil change so you know where you sit with how much oil is in the car.
2011 e90 M3 Space Grey DCT ZCP- eAs, BMW Performance, Agency Power, Macht Schnell, iND, Milltek, Volk, Challenge, Stoptech, Ohlins
BMWCCA:518970 |
08-03-2014, 01:35 PM | #7 |
20
Rep 816
08-03-2014, 01:47 PM | #8 |
Rep 16
there was a massive puddle under the car. My son was driving the car and smelled oil so I assume was leaking when he was driving. When the cap was replaced, they cleaned the engine and no leak. I could not believe how oil was leaking.
08-03-2014, 03:56 PM | #10 |
20
Rep 816
The problem is the shop did not have any idea how much oil was lost. I bet they just arbitrarily picked five quarts to add and didn't check the oil level. When you say there was a "massive" amount of oil on the floor, it probably wasn't five quarts worth. Five quarts would almost cover the whole floor. Also when you check the oil, are you driving for ten minutes to allow the oil to warm up? At this point I would just drain it all and see how much comes out. Use a clean container and you can just refill it back to spec.
08-03-2014, 04:32 PM | #11 |
Rep 16
we lost oil while driving in addition to what was on the floor. Hard to know how much but the level was low when we brought it in. Each time I took oil out, we allowed the car to warm up on a level surface. I agree I am to the point that just change the oil. I miss having a dipstick. What a F__kin hassle
08-03-2014, 10:17 PM | #14 |
96
Rep 545
Why not just drain the oil into a spotlessly clean container like a new 3 gallon plastic paint bucket that will fit under the car on jack stands. Refill using the used oil measured to the correct refill amount. Then he can get back to enjoying his M3.
