07-27-2014, 11:32 PM | #1 |
465
Rep 1,636
Difficulty getting alignment after lowering the car!!!
I got the car lowered on H&R springs and when I took the car for alignment the shop said the front passenger wheel cant be adjusted? Now the front wheel is off by 0.3 and they said it is not a big deal!!!!
I will scan and post the specifications tomorrow. There is no issue with springs. They are installed correctly. Is this true? Is there such a thing that the wheel can't be adjusted? |
07-27-2014, 11:41 PM | #2 | |
145
Rep 1,130
07-27-2014, 11:54 PM | #3 |
102
Rep 701
07-28-2014, 06:46 AM | #4 |
5288
Rep 10,686
Fixed camber plates like the Dinan above will do nothing to help equalize L to R alignment specs that have become unequal for some reason. However 1/4 degree difference is not a cause for alarm. Pull the alignment pin as noted in Post #2, and you should be able to adjust camber on the affected side. You can also pull both sides and have a little more negative camber on each side. I am on H&R springs and pulled the pins.
