KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
07-25-2014, 09:12 AM | #1 |
Sophisticated hobo
48
Rep 423
10.5 rim front
Hey guys, need some wheel advice..
I want to run a square setup of vossen cv5 20 x 10.5 offset 27 all around, the rear fits fine but I'm not sure what I can get away with in the front .. Im also lowered on h&r springs... Any help would be appreciated .. Thanks Vince
"The Love of Driving Comes with a Price"
- Vince |
07-25-2014, 09:25 AM | #3 | |
Sophisticated hobo
48
Rep 423
Dam you limited phone app
- Vince |
07-28-2014, 03:41 PM | #4 |
2740
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
haha... I like that
I have seen people run 18 x 10.5" wheels squared with 275/35/18 tires. I don't see how it makes any sense to run 20 x 10.5" wheels square. It's probably possible but your 20" tire sizes are severely limited. A 275/30/20 will be too tall for the front, a 275/25/20 doesn't exist (to my knowledge) and the sidewall would be ridiculously short, a 255/30/20 will be waaaay stretched, a 265/30/20 might work. Overall just a silly pointless endeavor IMO. 20's suck on e9x M3's. The car is not set up for a wheel larger than 19". Porsche 991 and Nissan GTR work with 20's because they are designed for a larger overall diameter tire. Note that the aspect ratio on the 20" wheels put on the above listed cars is equivalent to 19" tire aspect ratio on the M3. There is a loss of performance if the tire sidewall gets too short.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M Last edited by slicer; 07-28-2014 at 04:05 PM.. |
07-29-2014, 11:44 AM | #5 |
Sophisticated hobo
48
Rep 423
thanks slicer, the reason i asked is because i'm running vossen cv5 20"x9 and i'm using a 17mm spacer in the front to bring it flush to the fender, just by looking at a 17mm spacer it looks like it can accommodate something wider than a 9 width...
you make very good points as to the other components that would stop this setup from working properly..
- Vince |
07-29-2014, 12:03 PM | #6 | |
2740
Rep 6,734
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
01-22-2015, 04:05 PM | #7 | |
683
Rep 1,528
Drives: '11 BMW M3
New: '11.5 e90 M3 | DCT | Space Gray/Novillo | ZCV | ZCW | ZP2 | ESS 625 | BPM | M Performance | iPE | BC Racing | BPM | iND | LUX | Volk | Coby | Recaro
Sold: '11.5 e92 M3 | DCT | Mineral White/Novillo | ZCP | ZCV | ZCW | ZP2 | M Performance | ACM | BPM | iND | Thule | LUX | Macht Schnell | Broadway Static | Rogue Engineering | BBS | Challenge | Metak |
01-22-2015, 11:41 PM | #8 |
2740
Rep 6,734
A 10.5" wheel does not fit in the front with "no problem". It's a pointless fitment IMO. What are you trying to achieve? Do you want to be able to tell your friends you fit a 10.5" in the front?
'23 X7
