07-17-2014, 07:03 PM | #1 |
174
Rep 1,246
Drives: E92 M3
E85/Ethanol Thread
So, an offshoot from a dyno thread revealed that we can actually run a mix of E85 in our cars. The generally accept maximum of this is 30% Ethanol, 70% Gasoline (E30).
There are noticeable gains on the dynojet in my pants, but this thread is to further the discussion on the benefits, methodology and cautions regarding running ethanol. <Discuss> |
07-17-2014, 07:32 PM | #2 |
Dingleberries
76
Rep 1,246
I am interested in this. The gas station half a mile away has some E85 pumps and it would be nice if I could mix. I am hesitant but would like to hear people's responses as well as what tuners think. Thanks for starting this thread up!
07-17-2014, 07:42 PM | #3 | |
174
Rep 1,246
Drives: E92 M3
DrFerry6728.50 |
07-17-2014, 07:44 PM | #4 | |
174
Rep 1,246
Drives: E92 M3
07-17-2014, 07:48 PM | #5 |
174
Rep 1,246
Drives: E92 M3
I'll be dynoing tomorrow on a E30 Blend, I'll post my findings shortly there after.
Previous dyno with Trick 101 on the same dyno. |
07-17-2014, 08:15 PM | #7 |
499
Rep 2,400
What worries me about running an ethanol mix is ethanol naturally retains more moisture. How do we know this isn't bad for the fuel system? Also, doesn't it also gum up/clog the injectors? Between running stuff to clear the fuel system/injectors, wouldn't it be better to have peace of mind and run a mix of 100 octane racing gas with 91 octane to get a 93 octane mix?
07-17-2014, 08:16 PM | #8 |
174
Rep 1,246
Drives: E92 M3
07-17-2014, 08:17 PM | #9 | |
174
Rep 1,246
Drives: E92 M3
07-17-2014, 08:26 PM | #10 |
499
Rep 2,400
True in CA is 10% (maybe more), and every few thousand miles I'm having to put techron in and car feel far better after I run it. We're talking 3x that with the mixes proposed. My worry is also fuel system component corrosion...do we know what the components are made of and do we know what the fuel pump can handle?
07-17-2014, 08:32 PM | #11 |
174
Rep 1,246
Drives: E92 M3
I only run fuels with Techron in them, so yeah.
Re: Components. Most issues with E85 revolve around the cars stock ability to deliver the fuel. Some will hit 100% of their duty cycle and may cause it to cut out up top. So as long as your fuel system can meet the demand for fuel, you should be good. |
07-18-2014, 03:08 AM | #13 |
174
Rep 1,246
Drives: E92 M3
Likewise. Obviously I want to see a gain over what I made previously, but I REALLY want to see the curves and the AFR.
07-18-2014, 05:16 AM | #14 |
Rainbow Racer
1008
Rep 2,539
FWIW, Brazil has a mandatory 25% ethanol in their fuels, and the M3's fuel system is 100% similar to the USDM model. Modern day cars are built to cope with levels of ethanol, so many of the contamination issues are a thing of the past.
you may not make any more whp or wtq versus your previous dyno run using a race fuel blend. The advantage may only be seen after many dyno runs as the engine/oil temps rise as ethanols advantage is cooler combustion chamber temps. <---however, i'm not sure if this applies to non-DI engines though. your AFR may not change though, as the DME will want to reach for lamba 1, however, your fuel trims may show an increase and actual AFR will be different that reported AFR here is a good read on wideband tuning between gas and E85, however, i'm having a difficult time finding reads on E85 blends: http://honda-tech.com/showthread.php?t=3014051 http://www.iwsti.com/forums/2-5-lite...about-e85.html from that post: "Before we continue it is good to understand the concepts of AFR as it relates to E85. Because E85 contains less energy per volume it is necessary to use more of it to achieve the same desired result. As such the stoichiometric AFR of E85 at an ethanol concentration of 85% is 9.76:1 vs Petrol at 14.7:1. You might be thinking it is impossible to tune because our ECU’s only read up to an effective 11.2:1 AFR and can only adjust up to that point. This is not so and here is why. All ECU’s and other stand alone AFR gauges designed use a number called Lambda. That number is the same for Petrol as it is for E85 and is equivalent to 1.0 when either fuel is stoich. What this means is that for a value of 1.0 lambda, for what ever fuel you happen to be using at the moment, it will report its result as 14.7 whether it is E85 or not because the lambda is 1.0 and the gauge is calibrated for petrol. That means when running E85 and your AFR is reported to be 14.7, your real-time AFR is 9.76. " essentially, I think that if your engine is reporting lamba 1 or near a 14.7:1 AFR, the car is happy with an E30 mix. I'm no expert though, so maybe Mike Benvo or ColoradoE92M3 can chime in?
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 Last edited by spool twice; 07-18-2014 at 06:11 AM.. |
07-18-2014, 08:13 AM | #15 |
7494
Rep 12,310
Great thread, finally something new to read on M3post. Luckily, there's a gas station literally next to work with E85 and E93 ethanol free gasoline (which is what I normally use)
In the most basic terms, can you list the pros and potential cons of running this?
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
07-18-2014, 08:26 AM | #16 | |
90
Rep 162
Lambda = 1 will report ~12:1 AFR for an E30 blend of gasoline/ethanol. AFR =/= Lambda. AFR is an output when the lambda value is converted to the ratio of air and fuel for a given fuel type. For example, in my Supra I have an Innovate Wideband. The default fuel type is gasoline, so the reported AFR at Lambda=1 is 14.7. If I go into the software for the wideband controller, I can change the fuel type to E85, the displayed AFR immediately changes to ~9:1 (I run E90-E95). Even though the reported AFR changed, the same lambda value is measured from the oxygen sensor.
2009 E90 M3 DCT
DrFerry6728.50 |
07-18-2014, 08:45 AM | #17 | |
Rainbow Racer
1008
Rep 2,539
I've only ran into one con, mpg drops 2-4 depending on my cycle. The drops are more noticable during steady state cruising, where 70mph will display 26.5 mpg versus 22.5mpg on the OBC. Other than that, everything has been a pro. I have allergies, especially with my eyes, and an E30 mix helps reduce strong exhaust odors since I dont run primary cats. It makes me wonder if running straight E85 in emissions testing day will assist those who are fully catless or running high flow 200cells?
-Loe P.-
Prior Car:'14 Audi S5 3.0t DSG [ APR ECU/TCU | Pullies + basic bolt-on mods | 10.861@127.90mph ] Current Car: F82 M4cs | TT-RS | On Order: i4 M50 |
07-18-2014, 08:45 AM | #18 | |
Rainbow Racer
1008
Rep 2,539
-Loe P.-
07-18-2014, 08:57 AM | #19 | |
7494
Rep 12,310
I was thinking more like which part would need replacing more often. I read potententially 02 sensors and spark plugs? What about things like fuel pumps? Sorry for the noobie question, this is all kind of uncharted territory for me,
Current:
DrFerry6728.50 |
07-18-2014, 09:20 AM | #20 | |
233
Rep 1,673
Electronics Junkie, Engine Builder.
07-18-2014, 12:15 PM | #21 |
30
Rep 496
Not everyone wants a blower. Some want to extract most out of engine. Not to mention it's same price as 91 and mileage decrease for 30 percent mix is negligible. If I had access to 93 at pump I wouldn't bother but 91 in hot weather gives up 10 degrees of timing measure on bt
DrFerry6728.50 |
07-18-2014, 12:59 PM | #22 |
542
Rep 1,195
I was curious after seeing this so last night I put in 3 gallons of e85 and topped the rest off with 93. After a couple pulls I feel like there is a difference. More throttle response and the car seems to pull a bit better. The temp here is in the mid 90's so maybe its simply offsetting that. I have test pipes and a BPM tune as well.
I saw someone mention their exhaust note changed afterwards and I can say that does seem to be true. The exhaust tone seems to be more mellow. Overall it doesnt seem like a huge difference but if you can sense a change I guess thats worth something. |
DrFerry6728.50 |
