07-11-2014, 11:20 AM | #1 |
123
Rep 951
Sleeving a S65, inherent issues
It seems both Ferrari and McLaren sleeve their cylinder walls with great success. Now in the time I've been on the board, I've seen few if any successful S65s that have been bored over and sleeved; few exist but the ones that do have blown up. Can experts (VAC, tuners, etc) explain why (AlSi not very compatible with steel??)? I'd like to increase the boost and bore my motor one day hence my curiosity.
07-11-2014, 12:26 PM | #2 |
///M Powered for Life
11496
Rep 10,332
Steel transmits heat much worse than aluminum. 4x worse.
Why would you want to sleeve when the stock alu bores are already specifically treated to make them extremely hard? We have a 825hp VT3 (ESS) car that has run around 20k miles without sleeving. Do you plan to go beyond that? |
07-11-2014, 01:35 PM | #3 | |
123
Rep 951
Drew's car, if that is what you are referring to, I believe is still only 4.0L. I'd like to run 4.6L but fear that the wall thickness is too thin with significant boost (say 14+ psi). |
07-11-2014, 03:44 PM | #4 |
11496
Rep 10,332
You could get to 4.4L without sleeving or boring the block out. Something to think about
Hopefully RG, aussieM3 or BMLVR will chime in |
07-11-2014, 05:17 PM | #5 |
233
Rep 1,673
From what RG and I have talked about most of the sleeved builds are no longer running. Not sure if it is from the sleeve failure or other means. Will get back to you on it.
I would not sleeve it unless you have already blown it up once.
Electronics Junkie, Engine Builder.
07-11-2014, 05:39 PM | #6 |
123
Rep 951
Cool. Look fwd to understanding this more
07-20-2014, 07:07 AM | #9 |
123
Rep 951
07-21-2014, 07:23 AM | #13 |
72
Rep 706
Drives: ESS VT2 650 E92
My motor is sleeved and I have put on 2700km on my break in so far on my ESS 650kit gonna be putting on my vt3 setup once I'm done my break in. Car has beeing running mint no issuse at all so far
07-25-2014, 12:48 PM | #17 |
90
Rep 850
I'm using Darton Sleeves flanged sleeves. So far i spent 4000€ on the block preparation (machining, honing, decking etc...) including the sleeve's price. Have in mind we have higher labor cost in here.
