07-10-2014, 03:49 PM | #1 |
9
Rep 285
R1 Concept Complete Brake Packages for BMW 135i | Acute Performance
Read over 18 pages of customer reviews by following this link: http://forums.5series.net/vendor-cla...117383/page18/ All Packages are for 2008-2012MY 135i Diamond Slotted Package - $640 - R1 Concept Premier* High Carbon Diamond Slotted Performance Rotors for Front and Rear w/ 1 Year Warranty - Posi Quiet Ceramic Pads Front and Rear - Pair of Brake Sensors Front and Rear Cross Drilled Package - $660 - R1 Concept Premier* High Carbon Cross Drilled for Front and Rear w/ 1 Year Warranty - Posi Quiet Ceramic Pads Front and Rear - Pair of Brake Sensors Front and Rear Cross-Drilled Slotted Package - $655 - R1 Concept Premier* Drilled & Slotted for Front and Rear w/ 1 Year Warranty - Posi Quiet Ceramic Pads Front and Rear - Pair of Brake Sensors Front and Rear Shipping - Free R1 Concepts Premier Series - Cross-Drilled & Slotted Design - Drilled holes provides maximum air circulation for increased cooling - Diamond slots reduces debris and prevents pad glazing - Chamfered holes for increased durability - Double disc ground finish reduces rotor vibration - Meets or exceeds OEM standards - Same Vane count as OEM parts - Mill balanced ensures long lasting durability - High Carbon - Black Electro-Coated for rust protection - Fitment guarantee Posi Quiet Ceramic brake pads - Minimal dust levels - High friction level - Scorched to eliminate break-in period - Shim included to reduce noise - Precision cut backing plate to reduce vibration & noise - Stable performance across wide temperature range - Fitment guarantee Posi Quiet brake pads are manufactured using the same positive molding process utilized by Original Equipment suppliers. Positive molding uses extreme pressure to compress the friction material and bond it to the backing plate. This process assures consistent friction material density throughout the pad, resulting in even wear and performance characteristics throughout the life of the brake pad. The number one cause for customer returns are noise and vibration. Centric Parts has recognized these issues and is constantly improving its products to eliminate these issues. Posi Quiet brake friction features either precision cut or shaved backing plates and mechanically attached shims; these small details ensure proper fitment in the caliper and virtually eliminate noise associated with pad vibration. In addition to these features Centric Parts has added a scorching process to all of its Posi Quiet brake pads. This additional process forces any impurities out of the friction material and pre-burnishes the pads to greatly accelerate the break-in process. Last edited by Gor@AcutePerformance; 07-10-2014 at 04:00 PM.. |
