Autotalent
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > M3/M4 versus...
      07-09-2014, 02:55 PM   #1
Gonven
Gonven's Avatar
624
Drives: BMW X6
BMW M4 vs. Mercedes C63 AMG Edition 507 Comparison Review
BIMMERPOST
     Featured on BIMMERPOST.com
Incoming
Updated with review:
Full review - http://www.caradvice.com.au/297611/b...g-edition-507/
Some excerpts:
Where the new M4 is the first of a new generation, the Edition 507 intends to see this 2008 C-Class out with a bang (pop, crackle and bark). It is the final car ever to utilise the Mercedes-Benz 6.2-litre naturally aspirated V8 engine also used in the SLS AMG supercar.
The next C63 will follow the M4 (and its E63 and CLS63 siblings) and go smaller and turbocharged (but still with eight cylinders and 4.0-litre capacity).
It uses forged pistons and a lightweight crankshaft from the SLS to help raise power from 336kW to 373kW, though it needs you to climb to 6800rpm to reach it. Torque moves from an already BMW-beating 600Nm to 610Nm that requires the throttle to travel far enough into the floor to see 5200rpm on the tachometer.
However the C63 weighs 200kg more than the M4, at 1730kg, and with combined cycle fuel consumption of 12.1L/100km it is as ecologically credible as making a bonfire to burn carbon tax legislation.
The prudent BMW claims 8.3L/100km combined.
For all its accomplished cornering, however, it takes a drive on the same road in the C63 AMG Edition 507 to put a few things into perspective.
Sitting next to the tough, slick BMW, the Mercedes-Benz appears like yesterday’s hero.
It looks just like a two-door version of the seven-year-old C-Class sedan, and there are none of the lovely curves and haunches you get in the M4. Instead you get a grey sticker pack down the slabby sides of the car, and ostentatious bonnet vents from the C63 Black Series, just in case the regular C63 was too subtle for your tastes. If Benz did NASCAR, this would be its perfect entrant.
Other racecar analogies continue to come to mind. The interior looks and feels as dated as the exterior, yet there’s a lovely Alcantara steering wheel and gearshifter, fantastic sports seats, an AMG dial on the console that allows you to scroll through C, S, S+ and M transmission modes, and an Edition 507 badge on the passenger side dashboard applique.
You’d think the older Mercedes-Benz would lag behind for technology, but unlike the BMW it comes standard with adaptive cruise control, blind-spot assist and lane-keeping assist (the latter two are respectively $1000 and $900 options on M4).
The C63 AMG Edition 507 has a smaller 7.0-inch screen, though its Comand infotainment system includes internet connectivity as standard, where a SIM card-based system asks $200 extra on its rival.
The C63’s mighty V8 fires up with the ‘whumpf’ we’ve known and loved since 2008. It’s the immediate response through the throttle pedal that really grabs you though, even at low revs feeling as though your leg extends all the way into the engine bay with toes curled around the little wire tugging open its valves.
Despite its immense torque and eagerness at low revs, the AMG engine urges you to chase its top-end, where the sound is pure and unadulterated.
The way BMW M engineers have allowed a turbocharged six-cylinder to deliver crisp throttle response when the revs are hanging high is commendable, however compared with the C63 the M4 feels doughy at low revs. It’s not the torque delivery that’s the problem, because it soon comes on strong, but there’s not nearly the same immediate reaction from the engine when the throttle is quickly prodded.
The M4 engine is quieter at low revs, too. It segues into becoming louder than the Mercedes-Benz at higher revs, yet it’s not exactly for the better either. Unlike the sweet, creamy, classically six-cylinder sound produced from an M235i turbo 3.0-litre, for example, the M4 sounds more hard-edged and meaty, but also grainy and a bit coarse.
It’s almost as though M Division engineers tried to replicate the sound of the V8, or needed to make the new six louder to appease those who thought going turbocharged was a backwards step. However it’s come off sounding try-hard in the same way the shouty AMG four-cylinder in the A45 and CLA45 does.
The M4 sounds awesome driving past our camera guys, but it takes dropping the windows for the driver to appreciate some of the aural drama. With glass closed, you can barely hear the whip-crack of the exhaust.
The view of all our testers was that it’s a bit characterless inside – including our cameraman Mitch who has owned a Z4 and described the M4 engine as “like a BMW six with a hurricane on top”.
The twin-turbo six also treads a fine line between linear delivery and feeling flat. BMW engineers have allowed this engine to rev well past 7500rpm, which is an excellent achievement, but (even noise aside) there’s little reward for travelling to those heights when peak power is delivered from 5500rpm.
Keep the tachometer needle beyond that point, and there’s great throttle response but no real rush.
Conversely, there is a great theatrical crescendo in the AMG, and you can meter out changes in its cornering attitude based on millimetres of throttle adjustment. It should be noted, however, that the BMW engine is fantastic in isolation, and only eclipsed by what is a supercar-like engine that is basically perfection.
Less perfect is the Benz seven-speed semi-dual-clutch auto, which in manual mode is not as quick to respond to a hit of its steering wheel-mounted paddles as the BMW dual-clutch gearbox is. You have to pre-empt some upshifts before going beyond the 7200rpm redline, where in the M4 the ability to slap away at its paddles comes as easy as the supreme handling. In the C63 AMG Edition 507 you have to be on your game.
The C63 AMG Edition 507 still cannot carve through corners as quickly as the new BMW M4. It feels a bit heavier, and its transition from front-end grip to rear-end slip is less delicate than in its rival, even with the optional ($4990) locking rear differential fitted to our test car, and throttle response sharp enough to leave your foot bleeding.
Continuing the theme, however, the communication from the AMG’s chassis and steering makes the M4 feel a bit remote by comparison.
The BMW’s steering is very accurate and nicely immediate just off the centre position. It is just like the steering in an M235i, really (and that starts to form another comparison). Unanimously, testers preferred the lightest Comfort setting as the weightier Sport and Sport Plus add heft but no extra sharpness.
If ever you need steering feel in a car, it’s when you’re attempting to manage 550Nm-plus rear-drive coupes, and if ever there are two examples of the difference it makes, it’s with these two cars. The M4 can carve 45km/h-signposted corners brilliantly, but in super-tight 25km/h bends when you need to know when the front wheels are giving up purchase, the BMW electro-mechanical steering is mute.
Cars with old-school hydraulic power assisted steering that send true road feel through to your fingertips are diminishing, but the C63 AMG Edition 507 is one of the last bastions of the breed. Its steering is sublime, its single setting perfectly mid-weighted and unbelievably crisp. It dances in your hands over road surface and camber changes, and when the front tyres start to scrub, your fingertips will get lovely little vibrations to indicate so.
The C63 is possibly the most characterful, connected new car on the market, and while it remains a mighty beast, in its final incarnation it is far from untamed. Its tight front suspension means it no longer feels heavy and lurchy at the front, but rather sharp.
The Sport stability control is as finely calibrated as the BMW’s MDM, and it allows beautiful flicks of the tail without becoming unruly. The other area where each car is a match is brakes, both equally powerful, responsive and fade-free.
There’s no denying that you still have to push further into the C63’s reserves to keep up with an M4 that hammers out pace easily, however.
Conclusion:
The BMW M4 is technically the better car, and it did indeed whip its cloak off and near-triple its original freeway fuel consumption. Compared with its older rival, it is just as fast but more efficient, has a better transmission, far more premium cabin, extra technology, superior ride comfort, it is quicker through bends and, subjectively, looks tougher.
Yet in this company it is lacking the connection and character that separates the good from truly great sports cars.
Where the M4 feels like a faster, larger version of the M235i, the C63 AMG Edition 507 is like a cut-price mini-supercar.
Every tester walked away from it enamoured by just how special it makes you feel, from its bombastic engine to every control that talks to you, wherever you’re driving it and at whatever speed. It’s exactly enough to make you forgive its old cabin and hard ride.
Where the BMW M4 is admired, the Mercedes-Benz C63 AMG Edition 507 is adored. As far as grand finales go, this one is both epic and dangerous – the precedent for the next turbo-V8 C63 has just been set for itself…
      07-09-2014, 04:25 PM   #2
CurbBender'90
S
CurbBender'90's Avatar
Drives: 2010 S65
Nice vid, come back when they go head to head..Action Action Action.
DCK
      07-09-2014, 04:45 PM   #3
GOLFFRR
GOLFFRR's Avatar
10816
Drives: GOLFFRR cart
looking forward to it
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST!
Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101
vipfinance@bmwofcamarillo.com for warranties!
      07-09-2014, 06:57 PM   #4
///M ARMY
1003
Drives: F90
sounds like fun
2022 RAM TRX
2021 Ford Bronco
2022 BMW M3
      07-09-2014, 07:11 PM   #5
AlteredBe4st
First Pride
AlteredBe4st's Avatar
110
Drives: M4
Subscribed!!!
Modded M4
      07-09-2014, 08:01 PM   #6
Jockey
Jockey's Avatar
3450
Drives: 992 C4S
The 507 is an absolutely amazing car, no freaking doubt
      07-09-2014, 08:06 PM   #7
gthal
gthal's Avatar
1904
Drives: 2018 340i xDrive
The C63, in general, is an amazing car IMO. If it had a different transmission (a true DCT) that didn't overheat at the track, I would probably still own mine today.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery
2016 M2 | Long Beach Blue | 6MT
2015 M4 | Austin Yellow | DCT
2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3
      07-09-2014, 08:08 PM   #8
Jockey
Jockey's Avatar
3450
Drives: 992 C4S
I've always loved the C63 AMG. Then the 507 came out and almost, almost pulled me over to MB.
Seeing as my future M4 is coming with 6MT, that's one of the reasons. But not the main reason.
      07-24-2014, 01:47 AM   #9
Stallion150
Stallion150's Avatar
45
Drives: 2011 M3 Sedan
So they just did the comparo...
Looks like the C63 507 had a pretty decent showing
2011 Jerez Black M3 Sedan
      07-24-2014, 02:52 AM   #10
brava09
brava09's Avatar
767
Drives: M4C xdrive
rather flattering review for the C63:
"Where the M4 feels like a faster, larger version of the M235i, the C63 AMG Edition 507 is like a cut-price mini-supercar."
The M4 though scored on the fuel economy and up to date cabin
22 M4 Competition xdrive
19 M5 Competition sold
16 F-Type S AWD sold
11 Audi RS5 Misano Red--sold
08 E92 M3 Jerez Black 6MT--sold
08 E92 335i 6MT traded in for M3
      07-24-2014, 10:35 AM   #11
ybbiz34
ybbiz34's Avatar
670
Drives: 2023 330i M Sport
Wow, that was a pretty thorough/fair review.
Current: '23 G20 M Sport 330i
Current: '20 X253 GLC300 SUV
Gone: '20 W205 C43 Sedan
Gone: '18 W205 C43 Sedan
Gone: '13 W204 C63 Sedan
      07-24-2014, 11:41 AM   #12
jc05e46m3
jc05e46m3's Avatar
Drives: '21 F90 M5 Comp
Agreed. I liked it.
'21 /// M5 Comp - Frozen Brilliant White/Black
'18 Porsche GT3 Carrara White/Black/Red - Sold
'18 /// M3 - Individual Imola/Black - Sold
'15 /// M4 - YMB/SO - Sold
'12 E92 ///M3 ZCP - AW/FR - Sold
      07-24-2014, 11:50 AM   #13
VCP
VCP's Avatar
1390
Drives: M4GTS BSM/F90comp/BSM M2CS
My cheek muscles are hurting with Joy!!
      07-24-2014, 11:50 AM   #14
Murph335
Murph335's Avatar
Drives: '07 N54 e90, '10 N54 e93, TBSS
2015 Tesla P85D  [0.00]
I am actually considering the v8tt c63 next summer when shopping for the m3.
Mostly bc v8tt produce the best sounds
E90 - H&R Touring - M3 Front Arms - Work Genosis GS-1 19x9+30 x10+26 225f 265r stretch - AA FMIC - AR DP - Cobb E30 Map +160rwhp/+200rwtq
E93 - Style 95 - RB Turbo - AR DP - Evolution RW FMIC - PTF E50 +242rwhp/+234rwtq
      07-24-2014, 11:57 AM   #15
n14ssv
United Kingdom
Drives: BMW M6 F13 / BMW X6 F16 / BMW
Pro Merc review writer
      07-24-2014, 12:02 PM   #16
BigMacSmallFries
123
Drives: '19 M5C 911 Turbo F430 GT3 RS
"Yet in this company it is lacking the connection and character that separates the good from truly great sports cars."
"Where the BMW M4 is admired, the Mercedes-Benz C63 AMG Edition 507 is adored."
These two quotes say it all. Can't believe the E9x destoryed the C63, and now all of a sudden the new M3 is having trouble keeping up with the C63 that was not considered a great driver's car at the time. The M3 has become more competent but not as fun to drive. Hard to accept electric steering and turbos have detached the driver from the experience this much.
Wish I could have the new body on my E9x, spend 20k to get a supercharger and Brembo brakes, and have a 'proper' sports car. I've test drove the M3 for the third time, definitely feels like a small M5, not what an M3 is supposed to feel like. It's disappointing. Glad I have a GT3 RS for that involved experience, but still finding it difficult to let go and get an M4 for a daily commuter.
Oh well... First world problems. Time heals all. lol
      07-24-2014, 12:05 PM   #17
rjd598
Drives: F30 340i
2016 BMW 340i  [0.00]
i don't really understand this review or the autocar one. this isn't apples to apples and it's going to be hard to compare an amg v8 with more power than the base c63 versus a twin turbo inline 6. the engine sound will create bias alone
      07-24-2014, 12:22 PM   #18
Alex07M3
82
Drives: E92 M3, Evo X MR, A4 Allroad
It's comment like these that make me want to stick with my modded E92, I feel like it has that mini-supercar aura!
      07-24-2014, 12:29 PM   #19
DieGrüneHölle
1309
Drives: M
I honestly think if don't plan on doing track days or need a dual purpose car. The AMG is a better street car experience. The only downfall to the C63 507 is its on track abilities. Can it turn some quick laps, no doubt. It just isn't something I would want to take to the track every weekend. The new W205 C63 is going to one hell of a street car. The MCT gets some hate, but it's best attributes shine in day to day driving.
      07-24-2014, 12:40 PM   #20
Powaup
Powaup's Avatar
Drives: 2021 Supra 3.0 (Past: 2015 M23
2015 BMW M4  [10.00]
I get that the C63 amg edition 507 is a great car and has the best hand built V8 engine but is it that good that even with a crappy automatic transmission it's better than an M4?
I'm obviously bias because I own an M4 and have never driven a C63 but I feel that the final result of the C63 wining the comparison is unfair when the M4 wins in suspension, breaking, transmission, price($10k less), technology and fuel consumption
Check out my YouTube Channel Powaup
Instagram: @ Powaup
      07-24-2014, 12:43 PM   #21
Tornrider
Drives: 2002 E46 M3
Sad day for the M division when you hear statements like this-
      07-24-2014, 12:45 PM   #22
Year's_End
Year's_End's Avatar
Drives: 2020 Shelby GT350
I'm obviously bias because I own an M4 and have never driven a C63 but I feel that the final result of the C63 wining the comparison is unfair when the M4 wins in suspension, breaking, transmission, technology and fuel consumption
Welp.
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT
Current: '20 Shelby GT350|6MT
f80post
