European Auto Source (EAS)
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > M3/M4 versus...
      07-09-2014, 01:21 PM   #1
JMN
37
Drives: 2019 BMW X4 m40d
F80 M3 vs E92 M3 Dyno Numbers by Motortrend
BIMMERPOST
     Featured on BIMMERPOST.com
On K&N's dyno, seems to read quite a bit lower than some others:
http://blogs.motortrend.com/1407_on_...eneration.html
      07-09-2014, 01:24 PM   #2
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
All that matters is the relative difference.
The E90 on this dyno was way lower as well. (I also don't see enough fans, etc)
DSC_3369 by Kit W, on Flickr
      07-09-2014, 01:56 PM   #3
Hobbination
Hobbination's Avatar
Drives: 2015 M4
That was the first thing I was thinking too, where are the fans? This is going to start another dyno convo, it would be so cool if there was one type of dyno, hermitically sealed in a room where all conditions were the same all the time. Were seeing ranges of 370 to the wheels up to 420 to the wheels. Whatevs. Cars still amazing
      07-09-2014, 02:00 PM   #4
Buddy Revell
48
Drives: E92 M3, M4, 991 911 Turbo
Yeah, the relative difference is still huge. Way more than the 11 hp difference that's stated from the factory.
      07-09-2014, 02:00 PM   #5
stressdoc
Moderator
stressdoc's Avatar
Dominica
618
Drives: BMW i8; Toy 4runner TRD pro
306 whp for an E9x M? That is a very low result, even in comparison with the F8x at 380. Maybe the F8x not broken in.
      07-09-2014, 02:01 PM   #6
consolidated
consolidated's Avatar
205
Drives: F80 M3
So strange, 10hp apart per BMW, 70hp apart on this dyno.
      07-09-2014, 02:04 PM   #7
Buddy Revell
48
Damn the F8x makes more power at 4500rpm that the E9x makes at 8000.
      07-09-2014, 02:08 PM   #8
Never Convicted
Drives: M4
But how did it SOUND on the dyno? Let's keep our priorities straight.
Appreciate 4
Ngilbe361618.50
      07-09-2014, 02:09 PM   #9
ASAP
ASAP's Avatar
10159
Drives: '23 X3 M40i
The lowest S65 dyno that I have ever seen in my life that I could believe was 330 WHP... that would make the F80x at 406 WHP; far mooore believable but still on the lower end. This can't be a dynojet and if it is; what settings r they using?
2 x N54 -> 1 x N55 -> 1 x S55-> 1 x B58
      07-09-2014, 02:10 PM   #10
Buddy Revell
48
I wonder what tuners will do to get the top end power on the F8x to the next level.
      07-09-2014, 02:11 PM   #11
kitw
kitw's Avatar
471
You can get any numbers you want to out of a dyno jet.
      07-09-2014, 02:11 PM   #12
BoostedTerp
19
Drives: '15 M3
Seems like a very low reading dyno, but having them both there provides a nice point of reference for the real horsepower difference between the two cars.
'15 Black Sapphire M3
      07-09-2014, 02:16 PM   #13
JoeFromPA
1795
Drives: '15 AW M3 6MT Stripper
The absolute numbers matter little. Assuming they didn't mess with settings between the two dynos, that's an unreal difference in power.
      07-09-2014, 02:18 PM   #14
MKE_M3
MKE_M3's Avatar
Drives: 2011 e90 M3
I'm definitely not an expert, but...
1) Assume E9X makes 414 HP at the flywheel
2) Assume proportionate drivetrain/dyno loss
Loss = 1 - (306/414) = 26%
F8X HP at the flywheel = 379/( 1 - Loss ) = 379/.74 = 513 HP
Obviously I'm making some assumptions and 513 BHP seems ludicrously high, but WOW!
      07-09-2014, 02:18 PM   #15
consolidated
205
Drives: F80 M3
      07-09-2014, 02:23 PM   #16
Black Gold
592
Drives: M3
that's what my e9x dyno'd at. 332 whp stock
and I would say the apparent lack of fans
you can also see how both cars struggle badly at redline compared to every other dyno I have seen. this is likely due to lack of proper airflow. both cars seem to be down about 10-12% power
      07-09-2014, 02:24 PM   #17
VCP
VCP's Avatar
1390
Drives: M4GTS BSM/F90comp/BSM M2CS
This will take some magic. 1024 bit and this motor turns into a NA type monster over 6k rpm. Valvetronic magician required
      07-09-2014, 03:08 PM   #18
jc05e46m3
jc05e46m3's Avatar
Drives: '21 F90 M5 Comp
hahahahahahahahahahahahahahahaha, classic.
'21 /// M5 Comp - Frozen Brilliant White/Black
'18 Porsche GT3 Carrara White/Black/Red - Sold
'18 /// M3 - Individual Imola/Black - Sold
'15 /// M4 - YMB/SO - Sold
'12 E92 ///M3 ZCP - AW/FR - Sold
      07-09-2014, 03:25 PM   #19
solstice
5457
Drives: 2015 M3 6MT
70hp over the E92 M3. That is freakish underrating. Now, let's just hope BMW don't cut that down to the ankles soon by a SW "update"...
      07-09-2014, 03:26 PM   #20
tdizzle
Drives: 2017 F80 ZCP
Tricks with the boost. The BMS folks have apparently already hit 500whp with a dose of E85 tune only.
      07-09-2014, 03:44 PM   #21
JoeFromPA
1795
They are using E30, not E85. Pretty big difference.
      07-09-2014, 03:46 PM   #22
JoeFromPA
1795
Hmm, I'd like to understand more about the airflow restrictions (potential) or cooling restrictions.
NORMALLY an N/A motor is going to give a better dyno as IATs spike - i.e. a turbocharged motor is going to suffer more due to temp than an N/A motor.
Nonetheless, I'd like to understand if there were airflow restrictions here...
f80post
