New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      05-24-2010, 11:26 AM   #45
Memphis1
Memphis1's Avatar
Drives: Z4 SDrive 35i
Originally Posted by Oh Captain My Captain View Post
Although I did a double-take with the thumbs-up pose; it appeared that your wife had a freakishly-large left hand.
      05-24-2010, 11:27 AM   #46
Memphis1
Memphis1's Avatar
Originally Posted by ramiles View Post
Curious what are the rated limits of the Dual Clutch Transmission? What is the margin of strength before it becomes an issues (torque and tires). Am guessing it is a fairly new unit - maybe its fairly robust. Have read about issues with the HPFP, haven't heard any items with the tranny.
i've provided info on this before...
      05-24-2010, 11:29 AM   #47
Memphis1
Memphis1's Avatar
Originally Posted by alpha325i View Post
Are you sure about the negative statement you made about the BMS dual cone intake? They have a dyno result
http://www.burgertuning.com/images/filterdyno.jpg
Godius had them on his and he said he took them off because it felt as if the engine was being running out of air... (not his exact words)
      05-25-2010, 07:47 AM   #48
bulldog_yyc
bulldog_yyc's Avatar
130
Drives: GT3RS
Originally Posted by VintageBMW View Post
I am sure. Once the engine heats up, nice and toasty at about 250 degrees F, the dual cone results will suffer greatly. I have no doubt that while the motor is cooler that the dual cones will produce more power because they will suck in more air. So, make sure you race people before the car has warmed up to its normal operating temp. and let her rip. They do sound good with all of that air being sucked in to the cones.
you realize that as the car is moving, cold fresh air is inducted into the engine bay, which is what the dual cones "suck" in. Your statement is true for a car that is idling only. Also, recommending people "race" before the car reaches normal operating temp is a recipe for disaster, more so if you are running a tune.
      05-25-2010, 08:01 AM   #49
mrboon
mrboon's Avatar
77
Drives: Speeeed
Not really running out of air i think i said, i think the performance was slower, and i didnt like the sound the engine made.
      05-25-2010, 08:02 AM   #50
Vintage
Vintage's Avatar
Drives: BMW G80 (MT), 718 Spyder
good point, BUT why do modern air intake systems induct air from the front exterior of the car instead of just sucking in "fresh air" from the engine bay?
      05-25-2010, 09:28 AM   #51
dwagner00
7
Drives: Z4 35is
They're called "Cold Air Intake" for a reason
Colder air is higher density, so more O2 for a given volume.
      05-25-2010, 09:52 AM   #52
Vintage
Vintage's Avatar
agreed, I was being a bit of a smarta-- in my last post. yes, colder air is much better and dual cones are bad, but sound really good when you open the throttle
      07-20-2010, 12:23 AM   #53
Projekt35i
Drives: Z4
good work!
      07-30-2010, 11:20 AM   #54
Banton
Banton's Avatar
Drives: ordered: '11 35is loaded
Vintage-
I have enjoyed the posts on your upcoming mods. Look forward to seeing the results!
As a noob whom is planning to purchase soon, I would like to ask a couple of questions that might provide answers for some of us that are just learning about the various Z4 models.
Since you have a '10 35i, and the 35is was not available then, would you get the 35is if you were buying today? What is the difference between the 2 cars, besides, but relative to, the hp? Example: If I got a 35i, what would I sacrifice if I loaded it up with the M package, premium, Nav, etc. (other than a $5K savings), over the 35is?
If I got the 35i and did the same mods as you have done, would I be sitting with a better, faster car over the 35is?
Your knowledge of these cars is pretty spectacular and I would appreciate your thoughts rather than be sorry later that I took the wrong path.
Thanks in advance
Bill
      08-01-2010, 08:41 PM   #55
ttuner
ttuner's Avatar
68
Drives: z4
wheres the pics at?
      08-01-2010, 11:00 PM   #56
Vintage
Vintage's Avatar
Originally Posted by Banton View Post
Vintage-
Thanks in advance
Bill
If the 35is was available I would have probably bought it b/c I tend to buy the most powerful model even though it is not always the best. However, my wife would have made the final call as it is her car - I really like the black sapphire with walnut interior. Truly, I love the 35i but the 30i with the NA engine is also a true joy.
As for performance, our 35i will smoke a stock 35is. Keep in mind that it is truly pushing around 400hp and 400lb/ft. of torque with the ESS Stage II, FMIC, Eisenmann exhaust, charge pipe, etc. I drive around in sport shift mode or manual plus Sport setting all of the time - it screams and the power is ridiculous. That being said, our mods cost around $5k+; for that price you could buy the 35is and skip the mods if you wanted. In addition, with the 35is and no mods there will be no warranty issues at the dealer if there is a problem.
I really think there are two paths: 1) buy the 30i stripped down with manual = light, very quick, and really fun to shift without all the expensive stuff or 2) a loaded DCT 35i or 35is. Then, mod away if you want.
      08-02-2010, 12:12 AM   #57
Banton
Banton's Avatar
Thanks, Vintage. I guess that my quandary is: what do I get on the stock 35is that is different than what I could get on the 35i? Bigger engine, different exhaust, but is the suspension or the handling any different? Better, or just different?
Thanks
2011 Z4 35is Melbourne Red over Extended Walnut, 326M wheels, Premium Sound, Premium Package, Nav, Comfort Access and Heated Seats
      08-02-2010, 01:05 AM   #58
Dr Stig 2
Criminally Insane
Dr Stig 2's Avatar
Australia
53
Drives: Like a Demon!
2010 BMW Z4 35is  [10.00]
2013 BMW X5 30d  [0.00]
The exhaust is louder, the dct and steering programming are more aggressive.
PLus theyy give you a thicker tiller, but you lose the nice stainless trim on it and get a plastic ///M badge as compensation...
Dr Stig
2010 Z4 35is
2011 X3 30d M Sport
Australia
      08-02-2010, 03:22 AM   #59
BLKZ
Australia
Drives: Z4 sDrive35i - sapphire black
You've described the steering wheel on my 35i, right down to the plastic ///M badge. I was surprised when it arrived with this wheel fitted, as I wasn't expacting it, but I certainly didn't complain. I prefer the thicker rim and lack of brushed metal on the M wheel over the standard tiller.
      08-02-2010, 03:25 AM   #60
Dr Stig 2
Criminally Insane
Dr Stig 2's Avatar
Australia
53
Bit like Monopoly then. BMW error in your favour...
Dr Stig
2010 Z4 35is
2011 X3 30d M Sport
Australia
      08-02-2010, 04:31 AM   #61
Alext
141
Drives: B M W
The 35is basically comes with the M Sport package which includes more aggressive front and rear bumpers and the M Adaptive suspension as the most integral components. Interior-wise there are the aesthetic enhancements - M steering wheel, trim, foot rest & side sill trim etc.
Then as Dr Stig mentioned the DCT and steering programming are different. Plus a sportier exhaust.
Also you get a fatter front anti-roll bar. I recently watched a you tube vid of a 35is being driven around Imola race track shot from the interior. Body-roll looked minimal - a lot less than my 135i for sure.
And of course the extra power. As I have mentioned previously a tune will become available for the 35is eventually. A JB3 v2.0 will work for example, just needs some custom settings.
      08-02-2010, 05:18 PM   #62
richard in NC
Drives: 2009 Z4 35i
EDIT: Wrong post....
2020 X3M non-comp, Alpine White over black : Exec Pkg, ventilated M Sport seats, 20"s
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims
Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i
zpost
