02-15-2018, 01:34 PM | #111 | |
1116
Rep 1,904
Ludicrous mode is ALWAYS on if you enable it. "Max Power" is an additional setting which optimizes the batteries and can take several minutes (depending on the ambient conditions). ...and if I remember correctly it actually WARMS the batteries - not COOLS them... "Max Power" adds a little bit more power (maybe a tenth of a second?) but I've never had to use it to run the wheels off anything and everything that "wants to give it a go"... If you roll up to someone itchy at a light, its way too late to turn on "Max Power", but it doesn't really make that much difference. Ludicrous mode is always there and you can really snap your passengers neck if you don't warn them before you put your foot down!
The Jiggery-Pokery is Strong with this One
https://f80.bimmerpost.com/forums/sh....php?t=1645366 https://f80.bimmerpost.com/forums/sh....php?t=1197553 https://f80.bimmerpost.com/forums/sh...4&postcount=35 Last edited by evanevery; 02-15-2018 at 02:27 PM.. |
02-15-2018, 01:36 PM | #112 |
1116
Rep 1,904
10-4! Your rep is safe!
https://f80.bimmerpost.com/forums/sh....php?t=1645366 https://f80.bimmerpost.com/forums/sh....php?t=1197553 https://f80.bimmerpost.com/forums/sh...4&postcount=35 |
02-15-2018, 01:43 PM | #113 | ||
3436
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
02-15-2018, 03:09 PM | #114 | |
F10 1/4 WR: 9.9s / 142.5mph 1/2 WR: 175.5mph
1092
Rep 1,968
My best was 2.5 and that was on MT's, 850wtq.... |
02-15-2018, 03:21 PM | #115 | |
1116
Rep 1,904
My P100D has been in Ludicrous mode since the day it was delivered a year and a half ago. ...and I routinely drive between Milwaukee and Chicago and back without recharging. I see about 220 miles of range while constantly in Ludicrous mode. I doubt anyone could tell whether "Max Power" mode (what you call "Launch Mode") is actually enabled or not. We're talking maybe a tenth of a second here...
02-15-2018, 03:23 PM | #116 | |
1319
Rep 1,067
Or are you saying there is no overheat limit? Also - if you drive like a hooligan, how much does that affect your range? |
02-15-2018, 04:11 PM | #117 | |
1116
Rep 1,904
My battery has NEVER overheated! (I don't even know if its possible) Specifically cause I don't drive CONTINUOUSLY like a hooligan. My range has always been around 220 miles and my car has NEVER been in anything other than Ludicrous mode. (...and thats only charging to a battery-friendly 90% capacity - I can get to 240-250 if I turn the charge limit all the way up to push the range) "Ludicrous mode" is simply a setting to control the MAXIMUM power the drive train will deliver. It doesn't require or force you to drive like a hooligan. It doesn't effect your range or your battery temp UNLESS you drive like a hooligan. Its like being able to enable/disable BMW "Competition Pack" power. It just makes it available if you want it. Doesn't force you to use it. I see no reason to ever turn it off. Maybe if I was in some long distance race and wanted to prevent the car from ever using its max power to help lengthen the range... Even turning on "Max Battery Power" mode doesn't force you to use it. It does two things: It warms up your battery pack (if necessary) to maximize power delivery, and it does enable a traction optimized "Launch Mode" just like in a BMW. I don't know why anyone with a Ludicrous Mode capable Tesla would ever turn it off. (Do folks ever code out their Competition Pack?) ...and I've only enabled "Max Battery Power" once just to test it. (It turns off when you shut the car down) "Max Battery Power" is OK cause it enables a true Launch Mode but that is only really useful - not because of any real difference in traction control - but because you can stand on the brake and the accelerator at the same time and then just release the brake. You know - "Launch Control"! But we're talking a minimally measurable difference in performance. I don't need "Max Battery Power" Launch Control to spank pretty much anything that rolls up next to me. I just need to put my Ludicrous foot down! It seems to me a lot of folks don't understand what Tesla's Ludicrous Mode is all about - or that a completely different "Max Battery Power" (Launch Mode) is available... I'm not sure, but "Max Power" might even be available whether you have Ludicrous mode or not.
https://f80.bimmerpost.com/forums/sh....php?t=1645366 https://f80.bimmerpost.com/forums/sh....php?t=1197553 https://f80.bimmerpost.com/forums/sh...4&postcount=35 Last edited by evanevery; 02-15-2018 at 04:22 PM.. |
02-15-2018, 05:03 PM | #118 | |
586
Rep 1,935
Yep funny part is when they say (to every model) is that is the fastest m5 ever built by BMW. Of course it is. Reviews are full of bs. Even respected folks became like this, read Chris Harris, yes...:
My 1st love was 2006 BMW 325i Sport + Prem 6MT but I married the 2016 M3 BSM MDCT.
02-15-2018, 06:22 PM | #119 |
233
Rep 354
Drives: 335XI MPerformance edition
Hey guy's, i think we can accept all that tesla and m5 are great fast car, and have some advantage one over the others.
I think both has made a great car. But if it's about going from point a to point b, both do that very fast no? One burn gasoline, the other coal, diesel, nuclear or some more cleaner energy to go fast ... I have seen truck going as fast as an m5 and a tesla. If you want to go very, very fast, buy a bike, a space shuttle, a f1.... But what i can say, it's if the m5 do a 2.8 and a 10.9, it's enough for me. |
02-15-2018, 06:27 PM | #120 | |
41
Rep 567
Drives: 991 GT3, '12 CLS63 Kleemann K3
(horribly slow transmission? id love to see anyone out shift an smg in s6) |
02-15-2018, 09:33 PM | #121 | |
1918
Rep 3,222
Drives: 2018 BMW 440i GC
02-15-2018, 10:08 PM | #122 | ||
915
Rep 3,456
Drives: Harrop E90 M3
Madvillain161.50 |
02-15-2018, 10:39 PM | #123 | |||
43
Rep 104
02-16-2018, 03:23 AM | #124 |
3388
Rep 7,542
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
02-16-2018, 03:45 AM | #125 |
Barge driver
8685
Rep 12,436
I was going to ask the roll out question, I guess the M5 was also subjected to a roll out? so 3.1 not 2.8 etc....
I get roll out when doing 1/4 mile times as that is what happens at the strip but not for 60mph and 100mph runs it's misleading.
730d/Z4C
02-16-2018, 03:48 AM | #126 |
Barge driver
8685
Rep 12,436
65ms per shift is not slow even SMG2 was 80ms maybe they dumbed it down for the US market?
730d/Z4C
02-16-2018, 07:25 AM | #127 | |
41
Rep 567
its also the most fun transmission iv'e ever driven. there is no clunking whatsoever. the shifts are perfectly smooth when cruising, and absolute savagery when in s6. maybe your m5 was broken, or you don't know how to drive. |
02-16-2018, 08:28 AM | #128 | |
1116
Rep 1,904
The BMW boards are extremely harsh on the Tesla's. I currently own a VERY Individual M4, and an M6. I uses to own an X6M. I have an i8 Roadster on order. I used to own a Chevy Volt and now my daily driver is a Model X. They were/are all really great vehicles in their own right. Why do we feel it necessary to bash one vehicle just because its not OUR vehicle. Do we feel threatened by its success? Are we envious of its appeal? I think the F90 is turning in some pretty amazing numbers, but why do so many think its necessary that a Tesla should LOSE so that a BMW can WIN? My ModelX is an amazing car. It doesn't have the fit and finish of a BMW but its truly amazing in its own right. BMW (and many users on this forum) could learn a lot if they would care to look and understand what make these cars so special! This thread should be about the M5, not the Tesla, but when folks start spewing incorrect uneducated crap, I thinks its best to stand up for one of my very favorite vehicles. TRUE car aficionados don't love one brand at the expense of all others. Its possible to appreciate BOTH Camaros and Mustangs, BOTH M5s and Corvettes. The appreciation of fine automobiles might be easier if we simply pry off the manufacturers badges... Ever look whats in the garages of celebrity car aficionados like Jay Leno or Tim Allen? (Its more than one brand...)
Bönz183.50 |
02-16-2018, 11:43 AM | #129 |
121
Rep 374
I haven't read every post in this thread, so not sure if anyone else brought this up. But isn't the method to get the time from 0-60mph cheating?
"When fluid temperatures are right, the computer allows the engine to rev to nearly 3000 rpm, and the rear wheels start spinning as if the M5 were rear-wheel drive. Release the brakes, the front wheels kick in, and the M5 pounds forward. In 2.8 seconds you’re at 60 mph and in 10.9 you’re whisked through the quarter-mile at 129 mph." The wheels are already spinning before the light turns green. True, the car isn't moving yet so it's still at "0" mph, but something doesn't seem legit here about this process to get a true 0-60mph time. |
02-16-2018, 12:02 PM | #130 |
2878
Rep 7,886
That's not true. G-Power supposedly is already now selling a Piggyback for the S64tu4. They're claiming 700PS. Looks stupid expensive, although in their defense G-Power has never been cheap. But yeah, here we go with companies like Performing Imports selling Press Tunes for $4,000 dollars again. Lol!
https://www.g-power.com/benoetigt-de...00-ps_3946.php
02-16-2018, 12:27 PM | #131 | |
233
Rep 354
You have a lot of Nice car's Will be my first time with an M cars .... april ... |
02-16-2018, 01:00 PM | #132 |
184
Rep 764
This entire conversation is in ludicrous mode. All these cars are effin fast. And there's far more to them than just 0-60 times.
Besides, if you're drag racing, there are so many factors besides published times to compare. Ambient, road and tire conditions all play a major role in launching off the line. But more than all those put together is driver reaction time. If you blink in a stop light race, you can lose an entire second. I've come across cheaters who roll out when they see the opposing yellow. It's all fun and games. We should consider ourselves fortunate to afford and drive these amazing modern cars. Enjoy! |
