Cruise Control when Traction Control Off
01-29-2015, 01:08 PM | #23 |
687
Rep 2,770
Umm.. what do you suppose DSC stands for? hint... it has stability control in it...
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
01-29-2015, 01:17 PM | #24 | |
Wastegate Rattle
114
Rep 897
01-29-2015, 05:20 PM | #25 |
432
Rep 1,602
01-29-2015, 06:35 PM | #26 |
687
Rep 2,770
So what are you referring to then? Our cars have a two stage stability management system known as Dynamic Stability Control. One press reduces the system to allow some wheel slip and is referred to DTC or Dynamic Traction Control. It is still part of the DSC system. They are not disparate things. When you engage DTC you are still partially disengaging your DSC system.
07-18-2016, 02:54 PM | #27 |
70
Rep 1,565
If you have a DCT car, this is an issue. I run around with cruise control on all the time, use it to drive unless stopping/starting.
Hence, when you want convenience of cruise, yet you need power, you stomp the throttle and uh-oh!!!! DCT slipping, traction control issues etc... You completely nullify any ability to just stomp the throttle and not screw your transmission. Big DCT issue and no-no. Never should you go full throttle unless you have DTC disengage or go full OFF on the control and have Sport mode on at least. Best performance, full off, sport and manual mode...but then again, there goes cruise control. Switched off in any mode except regular drive setting, and Sport button engaged, any other mode, cruise control won't work. Would like the best of both worlds. Have DTC off, and in Sport Mode, and still have cruise control available. People have the coding, but can't seem to get cruise to work as well? Thx
2020 M340i: Dravit Grey Mettalic. Loaded.
