Cruise Control when Traction Control Off
01-25-2015, 04:10 AM | #1 |
15
Rep 68
Drives: Alpine White 2008 e92 335xi
I was wonder if anyone has coded this? Just wondering if it's even possible for 2008 e92 pre-lci 335xi. Thank you in advance.
01-25-2015, 09:13 AM | #4 |
687
Rep 2,770
Seriously, are you driving around with your traction control off all the time? I truly hope, for yours and everyone else's sake, you be careful.
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!! 2011 e92 X-Drive Coupe - SOLD!! |
01-25-2015, 11:00 AM | #6 | |
687
Rep 2,770
The point here is that cruise control is to be used during steady state cruise situations to allow the driver to relax a little. Relaxed is not the state you should be in when you have your traction control turned off. It is there in case a serious situation arises to prevent you killing yourself or others. I do not see the case for anyone turning it off on the street unless they are a certified racing driver. And even then, take it to the track.
01-25-2015, 12:41 PM | #7 |
15
Rep 68
No, I was just wondering if it was even possible with our cars. This past week I had a 2015 Camaro rental for a few days and it would keep the cruise set with traction off. I thought it was kind of odd that the cruise would still be sit, since it's a safety feature. jwzimm thanks for reassuring me and expressing your concerns.
01-25-2015, 01:21 PM | #8 | |
687
Rep 2,770
01-25-2015, 01:24 PM | #9 |
15
Rep 68
01-26-2015, 02:13 PM | #10 |
Wastegate Rattle
113
Rep 897
What's wrong with driving with the traction control off ? I drive with it off 95% of the time. and the other 5% it's DTC.
01-26-2015, 02:19 PM | #11 | |
687
Rep 2,770
Why do you feel the need to turn it off? Are you breaking traction that often on public roads that you need to disable it?
01-26-2015, 02:36 PM | #12 |
33
Rep 655
I still remember the first time when my cruise control cut off while on the highway and I was like "WHHHHHAAAAT limp mode again!!!??" then I looked and no light but I am slowing down, that is when I realized what really happen. Having RWD and cruise control on I am glad that it turns off itself when one wheel is loosing the traction. When driving and relax a little you have 0 ability to react as fast as you should and as jwzimm says, we are driving tanks at high speed, it is dangerous. Driving in the city is different, I turn it off partially to allow for a little spin, but my roads are almost always covered in snow so little spin is needed at times but then no cruise control.
01-26-2015, 02:36 PM | #13 |
11
Rep 49
DCC_DTC
There is the coding option:
C0F_DCC_DTC - DYNAMIC CRUISE CONTROL (DCC) AVAILABLE IN DYNAMIC TRACTION CONTROL (DTC) MODE [WERT_00: DISABLED, WERT_01: ENABLED] I have not had any luck enabling this fuction.
2011 BMW 335i auto
JB4 Stage 2, FF/wires, BMS Intake, Pure Stg2, Pure intake, +DV, Helix FMIC, AR DP, ER CP, Alpina Trans Flash. |
01-26-2015, 03:19 PM | #14 |
583
Rep 2,233
Drives: '12 M3
That's not possible due to a major safety issue. Imagine driving in rain or incelement weather with cruise control on, suddenly you hit standing water and the tires break loose. The last thing you want is your cruise control accelerating in the slip to maintain the exact speed and sending you into a ditch.
If you are cruising, your DTC has no business being off. WTF is the point of that? |
01-26-2015, 04:14 PM | #15 | ||
Wastegate Rattle
113
Rep 897
01-26-2015, 09:32 PM | #16 | |
687
Rep 2,770
Experience only works for things you have seen before. When something new occurs I prefer to have the much higher reaction time of a computer available.
01-27-2015, 07:04 AM | #17 |
432
Rep 1,602
Seriously, 10 years ago traction control wasn't even available on many vehicles. How did we all survive without traction control while using cruise control?
01-27-2015, 09:09 AM | #18 |
687
Rep 2,770
We had cars that were much heavier and more stable as well as slower. And not everyone survived btw. The advent of traction control (along with seatbelts, airbags, and other pesky devices) has resulted in a massive reduction in motor related fatalities.
01-27-2015, 11:54 AM | #19 | |
432
Rep 1,602
Cars were not heavier 10-20 years ago...they actually tended to be the same weight or lighter. All of these additional gadgets add nothing but weight to a vehicle. There were a number of stock cars making 300+ HP in the 90's without traction control. |
01-27-2015, 11:59 AM | #20 | |
687
Rep 2,770
People seem to forget they are in control of a 3000+ lbs kinetic energy weapon. Reducing your margin for error invites unreasonable danger.
01-29-2015, 12:05 PM | #21 | |
687
Rep 2,770
You asked... Granted it does not show that traction control alone contributed to it but it does state that it had a lot to do with it.
01-29-2015, 12:16 PM | #22 | |
432
Rep 1,602
Traction control != stability control. |
