05-26-2021, 02:34 PM | #3 |
Senior 1Addict
5166
Rep 2,426
Drives: BMW iX, Porsche GT4 RS
05-26-2021, 02:57 PM | #4 |
1716
Rep 1,909
Drives: 2023 M5C
CCB owner here. Never seen that before, but it almost looks like a small rock got stuck in the caliper and wore all the way around the disc? No clue.
IG @windtendo_m5
05-26-2021, 02:58 PM | #5 |
146
Rep 241
I had CCB's on my M3 Comp and now have CCB's on my M5 Comp and haven't had any issues like this. I agree with windtendo, looks like something got stuck in between the pad and rotor.
Peter
2024 BMW M3 CS -- 2021 STO UGR TT -- 2019 McLaren Senna -- 2021 McLaren 765LT -- 1997 Toyota Supra Turbo -- 2006 Ford GT -- 2022 Lamborghini Urus
05-26-2021, 03:21 PM | #7 |
6290
Rep 5,324
I have seen this before from track damage on one 911 before. It was ran very hard. The ceramic disc literally started to crumble like a pie crust and have the integrity of the ceramic discs come apart. This can be from a few reasons but manufacturing defect is not out of the question even if a stone did get in there from street use. With that low miles and never tracking the car, I can’t believe that would be considered any abuse by the dealer. That is a dealer visit for sure.
05-26-2021, 03:45 PM | #8 |
2337
Rep 2,029
Drives: INDIVIDUAL F90 M5C LCI
Oh. Oh my God. Man I hope you can get that resolved. But as windtendo said - looks like a rock got caught in there. Did you feel this happen while braking? Or did you notice it while the car was off?
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG | IG: @FSHNGRY |
05-26-2021, 04:06 PM | #9 |
701
Rep 778
Dear Lord. Best of luck getting this resolved, dude. As everyone else has mentioned, it sure looks like some debris got lodged in the caliper and tore up your disc.
Hopefully the dealership can help, but this is one of those things that may end just being a huge pill to swallow. Please keep us updated. |
05-26-2021, 07:03 PM | #10 |
3322
Rep 8,083
ok first of all, stop driving the car, that rotor is now garbage.
2nd, get it on a lift, and remove the rotor and replace it... and see if you can see anything in between the pad and rotor. This is going to bite, and hard. I would change the pads on the front axle and buy a new rotor.... You can still keep the other rotor on the opposite side providing it's in decent shape. Which it should be if the car hasn't been tracked. |
05-26-2021, 07:35 PM | #11 | |
199
Rep 572
I'd love CCB's due to low brake dust, but threads like this scare me. I shudder to think how much a replacement rotor is. |
05-27-2021, 03:53 AM | #12 |
41
Rep 38
05-27-2021, 05:26 AM | #14 |
2035
Rep 1,843
Here you go : https://f90.bimmerpost.com/forums/sh....php?t=1721364
05-27-2021, 05:43 AM | #15 | |
1471
Rep 1,308
I'm no expert but this post looks pretty different with those trailing abrasions. But shit I'd try to jump on the getting it replaced under warranty train. It might not leave the station but what's the alternative? 😬
Current: 2022 M5 CS
Past: 2021 M550i (BSM) Past: 2010 535 xDrive (Alpine White) |
05-27-2021, 08:36 PM | #17 |
BMW Elite Master Tech | HV Gen 5 | HV Specialist
3511
Rep 4,208
Should be covered under warranty. They will also only warranty the one faulty rotor. The material on the rotor should obviously not come off like that lol. I wonder if any of it is stuck in the pad now too.
05-28-2021, 03:55 AM | #18 |
137
Rep 859
Like many have said it looks like some debris has got caught between the pad and the rotor which has caught a cross drilled hole and it ripped the caliper.
I can't see you getting warranty, but good luck. Also if you decide to retrofit steel let me know as I'd like to retrofit CCB! |
05-28-2021, 08:59 AM | #20 |
982
Rep 1,797
Good point on the insurance, but I would hope this would be covered by warranty even though it is not likely a manufacturer's defect. I wonder if the owner has any extended warranties. Sometimes they cover things like road hazards or failures that are not caused by manufacturer defects
05-28-2021, 01:06 PM | #21 |
239
Rep 473
I recently had something similar happen to the rear left disk on my 991.2 Turbo S. It’s called delamination, I even found a BMW PDF saying areas up to 5cm are OK to drive with. I ended up replacing the disk and the car was out of warranty 🙂
You should be able to have it replaced under warranty, it’s probably a defect. |
