BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Cracked Ceramic Break Rotor **HELP NEEDED**
      05-17-2020, 01:52 AM   #1
KBM5
23
Drives: 2018 F90 M5
Hello Guys,
So today I was about to go on a drive with my 2018 F90 M5 and a noticed something unusual on my driver side Ceramic Break Rotor. I had a closer look and it looked like a piece of my rotor just fell off and left a hole (look at the pictures attached).
My car has 23,000 Kms on it, I maintain extremely well, I'm extremely cautious with it. The car has been tracked once in its life about a year and a half ago, I also often go for spirited drives, and the car is winter driven as well in Montreal QC, where it gets VERY cold. When I do use my breaks hard, I do give them a cool off period of at least 3-5 minutes of slow driving to air off the heat from the disks before completely stopping, and make sure I do not over heat my rotors. I use the car how it is meant to be used, mostly on highways for speed runs and or twisty roads a times, but again never abusing my breaks. Again I'm very cautious.
Therefore I have the following questions:
I was wondering what could've caused such an issue?
Is this something that can be covered under the warranty?
Can I still drive the car in the mean time? How safe is it?
Thank you guys for any help or insight you have on this issue!
      05-17-2020, 03:57 AM   #2
Alberta
Alberta's Avatar
2028
Drives: F90
I would insist for the warranty to take care of it.
This is absolutely not normal, especially with a low mileage.
I also have CCBs on my M5 with 32 000km (never tracked), and my rotors are in perfect condition.
FSHNGRY2307.50
      05-17-2020, 06:58 AM   #3
Demon Barber
292
Drives: 2018 M5, 2022 911 Turbo S
I have CCBs and I've worried about this scenario happening. It's really difficult to know how any particular dealership will deal with this as far as warranty coverage due to the price of these rotors and uncertainty of damage versus manufacturing defects, but I would approach them with a calm and confident case that this looks like focal delamination due to a weak point created while the rotor was made. The problem is that these rotors are so hard but simultaneously so brittle that a rock hitting the rotor just right could conceivably do this kind of damage as well. Hopefully they will offer a good faith replacement under warranty if you have a good relationship with your dealership and approach them the right way.
It's probably driveable to the dealership, but I wouldn't use as my daily driver until the rotor is replaced.
Please keep us updated through this process, as many of us with CCBs will learn something from it.
EMETREE173.50
      05-17-2020, 11:38 AM   #4
onfireX5
3618
Drives: F90M5,F85X5M
Agreed. Once a failure begins, it could come apart.
      05-17-2020, 01:09 PM   #5
TrevorM3
3322
Drives: 6.3 AMG
wow, i've literally never seen this happen before. On any car forum. I'd be curious as to how bmw will handle it. I wouldn't drive it. Only place you need to go is the dealer, please keep us posted.
FSHNGRY2307.50
      05-17-2020, 01:53 PM   #6
KBM5
23
Drives: 2018 F90 M5
Thank you for your reply! Yes definitely. I'm a little worried but hopefully, the dealership would be willing to change it.
Would you mind posting a close up picture of your brake disk so I could compare what mine look live vs 32K Kms car?
Thank you again!
Appreciate 2
x3525071.50
FSHNGRY2307.50
      05-17-2020, 01:54 PM   #7
KBM5
23
Drives: 2018 F90 M5
Very much agreed! Thanks for the reply. I just hope the dealership dosent go the "wear and tear" route. I was just wondering aren't these disks supposed to have a lifetime warranty?
      05-17-2020, 02:07 PM   #8
TrevorM3
3322
Drives: 6.3 AMG
ceramics aren't covered by warranty.
but this case looks to be an exception
      05-17-2020, 02:26 PM   #9
2021M5C
Drives: M5C
In EU, Latvia, dealership covers CB on f10 m5. It happened three times already.
      05-17-2020, 05:36 PM   #10
gblansten
gblansten's Avatar
1967
Drives: 23 Tesla S Plaid
I was going to brake in hear and say that isn’t a break rotor. But, I saw your pic and sorry. Hope you get that corrected under warranty.
      05-17-2020, 06:07 PM   #11
Demon Barber
292
Definitely no lifetime warranty on any consumables, which includes iron and ceramic rotors. Ceramics do last much longer than steel, but can still be exhausted.
Regarding your comparison pic request, unless chunks are missing like yours, a brand new rotor and one at the end of its service life will look about the same. They don't wear on the surface like an iron rotor, and don't become thinner. They lose mass/become lighter as they wear out due to the carbon oxidizing with repetitive heat. They essentially slowly burn internally as they are used, and weigh less and less. In fact, the starting and minimum weights are printed on the hat of each individual rotor by Brembo, so as long as your dealership has an accurate scale for weighing CCBs, your damaged rotor should weigh within spec, which would give you a strong case for claiming premature failure. I'd make damn sure that scale is calibrated before suggesting this experiment, as a false high reading kills your argument.
Appreciate 2
boredM124.00
KBM523.00
      05-17-2020, 08:54 PM   #12
dardeca
dardeca's Avatar
Drives: 2019 M5 Competition
The whole point of purchasing CCB is to take the add'l "abuse" of high heat from tracking the car, etc. So for BMW or the dealer to deny warranty on these b/c you used the brakes as intended would be ridiculous.
E92 M3 Supplemental manual p.38: "The laws of physics cannot be repealed, even with DSC."
Alberta2027.50
      05-17-2020, 11:51 PM   #13
Neptune7
1433
Drives: M5 CS
I was thinking of ceramics for the next car but am going to see how this thread plays out - BMW should take this very seriously.
      05-18-2020, 01:46 AM   #14
mjr24
1644
Drives: M8 Comp GC, X7, AMG GT53
Personally I would leave out that you ever tracked it when you talk to them.....
It has nothing to do with why this happened so I just think it does nothing positive to mention this to the dealer. They might take anything they can to get out of paying. Why risk it? You want to get this taken care of as quickly and easily as possible.
2022 M8 Comp GC, 2021 AMG GT53, 2022 X5M Competition, 2021 X7 40i, 2019 M5, 2018 M550I, 2017 Audi Q7, 2014 M6 GC, 2013 Mercedes CLS550, 2011 750LI, 2008 M6 Cabrio, 2008 Porsche Cayenne S, 2004 Mercedes SL55 AMG, 2003 Mercedes SL500, 2000 Mercedes CL500, 1993 Lexus SC400, 1989 525i, 1985 318i
      05-18-2020, 05:31 AM   #15
TheRealBob
255
Drives: '18 Bluestone M5
The wear indicator on the rotor clearly indicates heavy usage. It would very much surprise me to see BMW replace this for free. In fact, if the other rotors are equally as worn, they will need replacement as well.
Technical information on CCB's - https://documentcloud.adobe.com/link...2b10&pageNum=1
      05-18-2020, 08:52 AM   #16
onfireX5
3618
Great link ! Looking at the linked pics, it appears the Circle coating has To be worn off completely and some laminate erosion within the circle to determine % wear. He still has some circle coating left and all laminate.....I could be looking at the pics wrong though....???
      05-18-2020, 10:08 AM   #17
euro*
euro*'s Avatar
1658
Drives: F90 M5
Technical information on CCB's - https://documentcloud.adobe.com/link...&pageNum=1
Thank you for this link, very helpful !!
Looks like OP is out of luck, and rotors are due for replacement anyways...
      05-18-2020, 10:34 AM   #18
JOHNBMWM5
Live for today tomorrow never comes
JOHNBMWM5's Avatar
United Kingdom
1989
Drives: 2022 LCI Marina Bay Blue/ Smok
The OP will get nothing for those disks they are well worn, sorry expensive cost coming your way.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      05-18-2020, 11:04 AM   #19
onfireX5
3618
If this is partial wear.....and ok to run....
      05-18-2020, 11:05 AM   #20
onfireX5
3618
And this is greater than 50% wear and should be replaced....
      05-18-2020, 11:07 AM   #21
onfireX5
3618
This has not even removed the top coat yet to start delamination and should be fine to drive.....if it had not "chunked" elsewhere,,,
Unless that wear is deeper than the pic. If it’s into the rotor, then yep, they are used up.
      05-18-2020, 11:42 AM   #22
GhostOne_322
356
Drives: 23 G80 M3 CS (BSM/Red/Gold)
2023 BMW M3 CS  [10.00]
Hello Guys,
Any notable wheel damage?
