BMW M3 Forum (E90 E92)
BPM
      06-11-2018, 11:10 AM   #67
slicer
slicer's Avatar
2746
Drives: 'E46 M3 Race Car, '23 X7
Originally Posted by jritt@essex View Post
Originally Posted by slicer View Post
You asking about the Essex Radi-Cal kit? If so, yes the e88 can clear that brake. You just need to be sure you get the correct center as the e88 is available in a number of different center designs.
Thanks for the data! Do you have specific size/offset on that wheel so we can add it to our list? Thanks again!
That's difficult with a 3 piece wheel because different centers can produce the same size and offset but one might clear and the other doesn't. For example you could build a 10 et25 wheel with a 2" lip and a center that clears. Conversely the center that yields a 10 et25 with a 2.5" lip will not clear the front brake. That being said, almost all 18" e88's clear Essex brakes (I have the thin pad version). I have not done much checking on the thick pad version. I love my Essex kit and they are one of the most friendly options for fitting 18" wheels. I can help anyone determine bbs e88 fitment.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
      07-24-2018, 07:28 AM   #68
jritt@essex
jritt@essex's Avatar
Drives: e90 335i, NSX, 997.2, 987.1
Originally Posted by enycerz View Post
Essex AP Racing 9660
Clears Stock 18" wheels
Can you please share a pic of our 9660 kit behind the factory 18's? Thanks!
      02-28-2019, 11:41 PM   #69
m3_tristan
Be Original.
m3_tristan's Avatar
267
Drives: 2011 E90 M3
Anybody know if the brembo 380 will fit the ps7 18x10 et25
      03-01-2019, 01:09 AM   #70
Eddy@ApexWheels
BimmerPost Supporting Vendor
Eddy@ApexWheels's Avatar
445
Drives: E30 M3, F10 M5
Yes. It will clear.
      03-01-2019, 06:31 AM   #71
m3_tristan
Be Original.
m3_tristan's Avatar
267
Drives: 2011 E90 M3
Yes. It will clear.
Thanks for the quick reply! Also my rears are 18x11 et 25. Should that clear too?
      03-01-2019, 06:37 AM   #72
Rochen_00
Rochen_00's Avatar
350
Drives: M3 e92
I recently test fit my OEM 18" 260M wheels with the above listed brakes
18x8.5 et29 front wheels cleared the 380mm front brakes with 12mm spacer. 10mm may have been sufficient but I did not have one.
18x9.5 et23 rear wheels cleared the 380mm front brakes without the need for a spacer.
With the OEM 18 "260M wheels with spacer of 12mm and a brembo kit of 380mm there is possibility of cleaning ?? With 370mm I suppose that sure if
Instagram: @m_rochen
Alpinemss Tuned | Tecnocraft E9X ///M3 Envy™ Intake System | MS Pulleys | Akrapovic Evolution Exhaust | Ohlins Road&track| BBK Brembo 6p Front & Brembo 4p Rear| H&R Stabilisator| Solid subframe bushings| full spherical bushings| Recaro pole position
      03-01-2019, 09:43 AM   #73
slicer
slicer's Avatar
2746
No. Brembo 380 is far harder to clear than Stoptech 380. There are only a couple 18" wheels that clear that kit. Biggest PIA for clearance
'23 X7
Rochen_00349.50
      03-01-2019, 01:44 PM   #74
Timujin
Timujin's Avatar
353
Drives: GMC Sierra
2010 BMW M3  [0.00]
I think the BBS MRF spec RI-A in 18" clears Brembo 380 kit. Si???
We grow food to feed the animals so we can eat the animals
      03-02-2019, 09:06 AM   #75
slicer
slicer's Avatar
2746
The RIA does not clear Brembo 380. I have had bbs check caliper diagrams. It's very close and there is a possibility that they could be made to fit with brake hardware modification.
'23 X7
Timujin352.50
      03-12-2019, 10:24 AM   #76
jurrego
Drives: 2011 E90 M3 DCT
Does anybody know if the Stoptech 380 front kit will fit VMR VB3 18x9.5 +22?
      01-11-2020, 01:57 PM   #77
wyatth
3552
Drives: E90 ZCP
Bump.. does the RIA clear the Brembo 380s in any spec? Wondering if it’s an offset issue or barrel issue. iND says they’d fit here: https://www.m3post.com/forums/showthread.php?t=1413685
      01-11-2020, 09:42 PM   #78
slicer
slicer's Avatar
2746
Originally Posted by wyatth View Post
Bump.. does the RIA clear the Brembo 380s in any spec? Wondering if it's an offset issue or barrel issue. iND says they'd fit here: https://www.m3post.com/forums/showthread.php?t=1413685
See my previous post. It's a barrel issue. Doesn't matter what offset. It's within 2 to 3mm and would likely need caliper modification. The front 380 kit will be more likely to fit. The rear 380 kit is actually larger and would need modification.
'23 X7
      01-11-2020, 10:28 PM   #79
romero1990
Drives: E92 M3, F25 X3
2017 X3  [0.00]
2009 M3  [0.00]
Originally Posted by Expert@ApexRaceParts View Post
The EC-7s in 18x9.5" ET22 and 18x10" ET25 will clear the Brembo 6 piston 380mm BBK and the Stoptech 6 piston 380mm BBK up front on an e9x M3, along with the AP Racing 368mm BBK and Brembo 365mm BBK. These same wheels will also clear the 380mm rear BBKs from Stoptech and Brembo also.
The ARC-8s in 18x9.5" ET22 and 18x10" ET25 will clear the Brembo 6 piston 365mm BBK, but not the 380mm version for the fronts. The 18x10.5" ET27 ARC-8s & EC-7s as well as the 18x11" ET25 EC-7s will work in the rear with a 380mm Brembo or Stoptech BBK.
Volk Racing TE37s in 18x9.5" ET22 also clears the Stoptech and Brembo 6 piston 380mm BBK in front of an e9x M3:
We will try to get brake templates for the PFC and Alcon kits to test against both the EC-7s and ARC-8s as well, but usually Brembo utilizes the largest calipers in our experience, so wheels that clear the Brembo 380mm BBK should clear the others as well with the same or smaller rotor sizes.
Do you got any confirmation for PFC Z54 kit under EC7s? I got 18x9.5 ET22 and 18x10.5 ET27
thx
      01-11-2020, 11:22 PM   #80
wyatth
3552
Drives: E90 ZCP
Thanks for clarifying. That sucks. The rear is larger, wow!
      01-12-2020, 01:35 PM   #81
slicer
slicer's Avatar
2746
There's a bolt protruding in the rear on Brembo 380 caliper. It can be modified to improve clearance
'23 X7
      01-12-2020, 04:02 PM   #82
M3SQRD
M3SQRD's Avatar
2335
Drives: E92 M3,G20 330ix,F22 240iX,F82
thx
The front PFC Z54 brake kit fits inside Apex Arc 8 wheels so you’ll have even more clearance with an Apex EC7 wheel.
      01-13-2020, 10:17 AM   #83
wyatth
3552
Drives: E90 ZCP
Any idea what the rear modification entails? Replace with shorter bolt or grinding anything down? If the fronts clear and the rear is a simple mod, I’m intrigued!
      01-13-2020, 11:04 AM   #84
slicer
slicer's Avatar
2746
You wouldn't want to use a shorter bolt as that would reduce thread engagement and do nothing for clearance. You can inspect the bolt style and see if there's a version with a smaller head and/or grind it. You are better equipped to come up with a plan of attack if you have caliper in front of you.
'23 X7
      02-13-2020, 09:44 PM   #85
tlrid3r
just another M3
tlrid3r's Avatar
Drives: e92 M3
Couldn't find a definitive answer. Does Stoptech 380 6 piston fit under bmw m260 wheels
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
      03-25-2020, 10:46 PM   #86
Smeckael
Drives: 2011 E92 M3 ZCP -> 2019 M2C
Does anyone know if 18x9.5+22 ZE40's would clear the front Brembo 380mm ?
      03-26-2020, 04:56 AM   #87
DR-JEKL
Australia
900
Drives: Space Grey E92 335i 6MT
yes
      03-30-2020, 10:39 AM   #88
Rochen_00
Rochen_00's Avatar
350
Drives: M3 e92
Finally I would like to comment that I found a combination that I like and pound with 18" 260M oem wheels.
- Front: 6p Porsche 997 GT3 mk2 brake caliper + bmw M4 oem front rotor 380x30
- Rear: 4p Porsche 997 Carrera 4s 3.8 Petrol + bmw M4 oem rear rotor 370x24
Only need a 10-12mm spacer
m3post
