BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > TSB (technical service bulletins) for the E90 / E92
      02-14-2013, 09:00 AM   #133
u170who
u170who's Avatar
Drives: e90 330I
Originally Posted by Jason View Post
TSB#: SI B51 30 05
Category: Body Equipment
August 2005
Technical Service
SUBJECT
Cracking or Ticking Noise from the B-Pillar
MODEL
E90 (3 Series)
SITUATION
Cracking or ticking noise heard from the left and right B-pillar area while driving.
CAUSE
Door lock striker connection to the B-pillar (front left and front right doors).
PROCEDURE
1. Mark the position of the door lock striker.
2. Loosen the striker bolts.
3. Slightly move the striker away from then back to its original position.
4. Re-torque the striker bolts to 18.5 Nm.
Note: Do not change the position of the striker (mark the position before loosening the striker bolts).
WARRANTY INFORMATION
For information only.
Original TSB
http://www.bmwtis.com/tsb/bulletins/...p/B513005g.htm
Hi, sorry to be a bother, but is the striker on the door or on the pillar? I think it's draining my battery.
      05-14-2013, 08:18 PM   #134
Route 16
I got lei'd
Route 16's Avatar
Philippines
846
Drives: '10 E90 M3
Originally Posted by cobradac View Post
Here is one:
Not the whole thing as it list a lot of the test procedure on the diagnostic
SI B51 19 07
Body Equipment September 2009
Technical Service
This Service Information bulletin supersedes SI B51 19 07 dated September 2009.
designates changes to this revision
SUBJECT
Doors Will Not Unlock Using the Key Fob or Central Locking Button
MODEL
E90, E91 (3 Series) produced up to 11/2008
SITUATION
One or more of the doors may not unlock when using the remote key outside the vehicle, or the central locking button inside the car. It is still possible, however, to unlock the door by using the key in the driver's door lock cylinder or by pulling the door handle on the inside of the car.
Typically fault codes A6D4 and A6D5 are stored in the Junction Box Electronics (JBBF).
CAUSE
This is due to a blown fuse in the JBBF caused by either:
An excessive amperage draw by one of the door lock actuators, which is commonly attributed to silicone contamination; or
An intermittent, but acceptable, amperage spike slightly above 15A, due to normal variation in the locking system.
CORRECTION
Replace the fuse with one of a different rating.
Replace the necessary actuator as well, but only if it is drawing excessive amperage.
NOTE: Never spray any silicone products into the latch, as this will lead to premature failure.
PROCEDURE
Perform a vehicle test using ISTA.
Inspect fuse 57 (up to 9/07 production) or 73 (from 9/07 production) in the JBE.
Replace the blown 15A fuse with a 20A fuse.
Perform a function test by activating the door locks 10 times in succession via the central locking switch.
NOTE: The thermal protection will be activated after about 15 successive activations and does not indicate any damage to the system.
Carefully observe the operation of each lock actuator while it is being cycled. Lock actuators with some degree of damage will exhibit noticeable symptoms of this, such as slow operation, abnormal noises, etc.
If either one of the front door lock actuators is determined to be the source of the blown fuse, both front door latches (which contain the lock actuators) should be replaced per Repair Instruction REP 51 21 090. For this replacement, the door latch kit, which contains both the left and right side latches, must be used.
If either one of the rear door lock actuators is determined to be the source of the blown fuse, only that single faulty latch should be replaced per Repair Instruction REP 51 22 090.
If one of the front lock actuators and one of the rear lock actuators appears to be faulty, both front latches and the single faulty rear latch should be replaced per Repair Instruction REP 51 21 090 and REP 51 22 090.
If no faulty lock actuators can be identified, wait 2 minutes and then repeat step 4.
NOTE: If any door latches are to be replaced, the attached procedure should be utilized in conjunction with the REP noted above. This attachment will reduce the amount of time necessary to perform the replacement.
After the second functional test, if no faulty lock actuators can be identified, none of the latches should be replaced.
PARTS INFORMATION
Part Number
Description
Quantity
51 21 7 263 086
Door latch kit (contains both left and right latches)
As required
51 22 7 060 295
Door latch – left rear
As required
51 22 7 060 296
Door latch – right rear
As required
61 13 6 942 071
20 Amp mini fuse
Covered under the terms of the BMW New Vehicle Limited Warranty or the Certified Pre-Owned Program for the second cause listed above.
NOTE: If both front door latches are being replaced, the door latch kit noted above must be used as opposed to ordering both left and right latches separately. Failure to use and claim this part kit will result in a delayed or denied claim.
Defect Code:
51 21 90 15 00
Happened to me last weekend, replaced today at the dealer, all fixed!
      06-28-2013, 06:30 AM   #135
skyliner
12
Drives: E93
Convertible tension cords
Hi,
Anyone know if there is a TSB on replacing the tension cords on the early E93 (2007) headliners? Haven't been able to find one so far, but, from other threads, I understand the cords have been updated.
Thanks.
      06-28-2013, 03:12 PM   #136
raceyBMW
king of the hills
raceyBMW's Avatar
92
Drives: 2011 M3 w/ESS55, 2001 540i/6
2001 BMW 540i/6  [8.17]
1994 530i  [9.00]
2007 335i Coupe  [8.37]
Hmm, I don't know off hand, but you could start by looking on RealOEM to see if you can locate the part and see if it has an update.
      08-06-2013, 03:32 AM   #137
ATG_
Drives: e90 320d, g20 330i
I'm having issue with water, could anyone share the body of the TSB:
Body Equipment 51 33 05 October-05 E90 Water Ingress from A/C Blower Housing
Thank you
      03-14-2016, 05:47 PM   #138
09Monaco335i
Drives: Monaco 335i xDrive
2009 BMW 335i  [0.00]
Hi all. I would be eternally grateful if someone could post the full service bulletin 'SI B01 02 15', which as I understand is a bulletin regarding the N54 Engine Fuel Injectors, which provides a Limited Warranty Extension to 10 Years/120,000 Miles for the fuel injectors. I see some information from that bulletin posted on this forum, but would like to see the full bulletin.
I have a 2009 335xi that is not currently passing an emissions inspection... due to reported misfires on cylinder 3 and an associated faulty fuel injector. (New plugs and coils have been installed recently, so have narrowed down the misfire to the fuel injectors.) Based on my VIN number, the dealer is saying my 2009 335i E90 with a build date of March 2009 is not covered under this limited warranty extension. I am trying to plead my case with the dealer that I am facing the same issue with faulty fuel injectors as reported in the service bulletin.
2009 E90 335i xDrive / Monaco Blue / Beige / 6-speed Manual / Premium / Sport / Cold / iDrive / iPod
      02-02-2018, 09:58 AM   #139
hatepotholez
293
Drives: M3
Can anyone update this for a 2011 335xi? Wastegate actuator went. Thanks!
      01-09-2020, 12:25 PM   #140
mc beemer
Ireland
Drives: 2006 bmw m sport 320 d
hi new to this and hoping im writing in the righy place
Is there a TSB #for the ssr
P0500 Vehicle Speed Sensor A Malfunction,
any help on this topic or point me in the right direction thanks
