TSB (technical service bulletins) for the E90 / E92
08-27-2005, 11:23 AM | #1 |
Administrator
40797
Rep 21,240
TSB#: SI B 65 04 05
Category: Sound System, Cruise, Alarms, Monitors July 2005 Technical Service SUBJECT Rear Interior Lamp Has No Slots for Motion Sensor MODEL E90 (3 Series) SITUATION When retrofitting a DWA (Anti-theft alarm system), the interior lamp housing has no slots for motion sensor operation. Therefore, the motion sensor is inoperative when installed. CAUSE Incorrect factory installed interior lamp. The slots that enable interior motion sensor operation are missing. CORRECTION Replace interior lamp with correct part. Refer to Parts Information below. PARTS INFORMATION Part Number: Description: Quantity: 61 31 6 971 772 Interior Lamp (Gray) 1 61 31 6 971 773 Interior Lamp (Beige) 1 61 31 6 971 774 Interior Lamp (Black) 1 WARRANTY INFORMATION The installation of the DWA kit is a customer pay item. However, if the interior lamp needs to be replaced, this may be claimed under warranty. Covered under the terms of the BMW New Vehicle Limited Warranty. Defect Code: Refer to KSD Labor Operation: Refer to KSD Labor Allowance: Refer to KSD Original TSB http://www.bmwtis.com/tsb/bulletins/...p/B650405g.htm |
08-27-2005, 12:05 PM | #2 |
Administrator
40797
Rep 21,240
TSB#: SI B51 30 05
Category: Body Equipment August 2005 Technical Service SUBJECT Cracking or Ticking Noise from the B-Pillar MODEL E90 (3 Series) SITUATION Cracking or ticking noise heard from the left and right B-pillar area while driving. CAUSE Door lock striker connection to the B-pillar (front left and front right doors). PROCEDURE 1. Mark the position of the door lock striker. 2. Loosen the striker bolts. 3. Slightly move the striker away from then back to its original position. 4. Re-torque the striker bolts to 18.5 Nm. Note: Do not change the position of the striker (mark the position before loosening the striker bolts). WARRANTY INFORMATION For information only. Original TSB http://www.bmwtis.com/tsb/bulletins/...p/B513005g.htm |
11-01-2005, 06:01 PM | #3 |
Administrator
40797
Rep 21,240
Coding, Individualization, Programming (CIP)
SI B 09 05 01 http://www.bmwtis.com/tiscode/cgi-bi...sion=716534817 Personal Profile SI B 09 03 05 http://www.bmwtis.com/tsb/bulletins/...p/B090305g.htm "Car and Key Memory" (CKM) Configuration SI B 09 03 98 http://www.bmwtis.com/tiscode/cgi-bi...sion=716534817 Service Action: N52 Reprogram Vehicle for OBD Diagnostic (CIP 19.1) SI B12 19 05 http://www.bmwtis.com/tsb/bulletins/...p/B121905g.htm (thanks to northerncalguy for providing these) |
12-10-2005, 03:40 PM | #5 |
Administrator
40797
Rep 21,240
Jammed Cupholder (cup holder) when retracted
http://www.bmwtis.com/tsb/bulletins/...p/B513705g.htm Clicking Noise from Upper B-pillar Trim http://www.bmwtis.com/tsb/bulletins/...p/B513205g.htm |
01-15-2006, 02:01 PM | #6 |
Administrator
40797
Rep 21,240
SIB 65 30 05 of January 2006
CCC: MP3 CD Playback Not Available (this gives MP3 playback feature to pre-September 2005 cars!) MODEL E60, E61 (5 Series) with SA 609 CCC-Navigation from 3/05 to 9/29/05 vehicle production E63, E64 (6 Series) from 3/05 to 9/29/05 vehicle production E90, E91 (3 series)) with SA 609 CCC-Navigation vehicles produced up to 9/29/05 SITUATION The MP3 option is not available in the audio menu. When an MP3 CD is used, it is not recognized as a valid CD. CAUSE The stability of earlier CCC (Car Communication Computer) software did not allow for proper MP3 functionality. PROCEDURE On a customer complaint basis only, retrofit MP3 functionality using Progman V20.00 or higher. Refer to the SI B09 05 01 Coding, Individualization, Programming (CIP), for the "Retrofit" procedure. Select "MP3" from the retrofit list and follow the on screen instructions for retrofitting MP3 capability. The service code "KMP3" will be added to the end of the vehicle order as displayed in the Measures Plan. After the procedure is complete, turn the ignition off and wait 5 minutes or until the driver's switch block LED goes out. Check the functionality of the system. WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle Limited Warranty. Defect Code 65 83 94 23 00 Labor Operation: Retrofit MP3 (programming/coding performed as part of a Technical Campaign) Labor Operation Labor Allowance +00 56 743 4 FRU (E60, E61, E91) 3 FRU (M5, E63, E64, E90) Labor Operation: Retrofit MP3 Labor Operation Labor Allowance 00 56 110 10 FRU (E60, E61, E91) 9 FRU (M5, E63, E64, E90) +00 56 744 8 FRU (E60, E61, E91) 7 FRU (M5, E63, E64, E90) Labor Operation: Retrofit MP3 and program/code control modules Labor Operation Labor Allowance 00 56 111 16 FRU (E60, E61, E91) 15 FRU (M5, E63, E64, E90) +00 56 745 15 FRU (E60, E61, E91) 14 FRU (M5, E63, E64, E90) Labor Operation: Retrofit MP3 and program/code control modules (including CAS) Labor Operation Labor Allowance 00 56 112 17 FRU (E60, E61, E91) 16 FRU (M5, E63, E64, E90) +00 56 746 16 FRU (E60, E61, E91) 15 FRU (M5, E63, E64, E90) Note: Should the vehicle be affected at the same time by another repair in which programming of control units is also required, programming may be claimed only once. Note: The following explanations will spell out the correct use of the work times. Main Work: Use this labor operation number when the only repair performed is the listed warranty repair. OR +Associated Work: Use this labor operation number when other repairs or services are performed along with the listed warranty repair. Under no circumstances should both labor operation numbers be claimed. Attempts to claim both times will result in an unnecessary delay in claim processing and payment. |
05-02-2006, 05:18 PM | #7 |
Administrator
40797
Rep 21,240
Thanks to Segfault:
090106 JBE Fails to Program 090206 Replacement FZD (Roof Function Center) not accepted by CIP/PROGMAN 090606 RAD2 Can not be programmed after programming abort 520305 Front seat cover retainer is loose 610303 CAN/Byteflight bus diagnostics 652005 RAD2 - CD mode malfunctions 653205 CCC: CD/CDC track counter advances after mute selected 720205 Passenger airbag status lamp goes on/off during driving 720705 Replacement OC3 mat will not enable 852505 Unable to pair or reconnect Bluetooth 111190 Engine oil capacities 510706 Console creaking noises 320106 Service action - install clip for power steering line 340406 DSC warning - various SZL FCs stored 350106 Kickdown function not available 090406 Coapi fault codes in final report 090806 DWA LED on Rearview Mirror cannot be activated 841503 BMW Assist Initialization 120405 CEL illuminated and/or vehicle overheats 840506 Diagnosis of Bluetooth handset complaints 840606 Information displayed in BMW Assist menu is incorrect or unknown 090501 Coding, Individualization, Programming (CIP) 320506 Steering wheel offset 610305 Software errors corrected with progman 650406 KL-R stays on after ignition off - comfort access only 070296 CD45: Updated DISplus & GT1 software 090906 Progman 21.0 software errors 120706 SES illuminated: FC 2EF4 Map Thermostat 652605 Audio switches off briefly when listening to FM stations 653005 MP3 CD playback not available 841005 CCC Navigation displays incorrect vehicle position 513105 Center console heats up in knee contact area 650206 CCC: Loss of audio in all modes 652805 CCC: Radio station preset list intermittently empty 840805 CCC - CID switches between BMW banner and blank 130106 Fuel system - alcohol blend fuel usage 640406 The air conditioning does not cool 650705 MOST bus is inoperateive or CID has reduced brightness 130206 TOP TIER detergent gasoline in BMW vehicles 720806 OC3 occupancy status does not change 840906 Bluetooth inoperative, TCU FC# A379 or 79 841006 BMW Assist or Bluetooth inoperative, TCU FC# A373 120606 Voluntary emissions recall 06E-A01: N52 - reprogramming vehicle for OBD diagnostic 240205 Service action: replace mechatronic adapter 320706 Steering column clicking noise 650506 CCC: CD Drive errors 720906 Airbag warning lamp, FC93EB 721005 Airbag warning lamp, FC93B4 and/or 93A8 841205 CCC: DVD drive makes clicking noise
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
08-19-2007, 06:41 PM | #9 |
20
Rep 374
Drives: '05 645Ci Coupe
Updates through end of July 2007
Sorry, just did not have the time to sort out ONLY e90/91/92/93, plus many cut across all platforms.
08-29-2007, 02:02 AM | #10 |
32
Rep 420
SI B32 07 06
Steering and Wheel Alignment April 2006 Technical Service SUBJECT Steering Column Clicking Noise MODEL E90 (3 Series) and E91 (3 Series Sports Wagon) produced up to 11/05 SITUATION Customer may complain of a slight clicking noise heard, mostly at slow speed, when turning the steering wheel at about 180 degrees. CAUSE Steering column manufacturing tolerances stack up. CORRECTION In case of a customer complaint, replace the steering column only. Do not replace the steering gear and the steering spindle (lower joint assembly). The steering column manufacturing process has been improved in 11/05. PROCEDURE * Replace the steering column per Repair Instructions RA 32 31 090. * Perform steering angle sensor adjustment/calibration per Repair Instructions RA 61 31 996. PARTS INFORMATION Part Number Description Quantity 32 30 6 772 273 Steering Column 1 WARRANTY INFORMATION For information only |
02-18-2008, 12:37 PM | #12 |
126
Rep 993
Drives: F85
Does anyone know what the TSB is for the early morning "bucking" issue with the E92 335i? Also, when I slow down at a light and it turns green before I come to a complete stop, the car JUMPS when I give it gas.....I know lots of people have this prob but can't find it above in the TSB's....
02-18-2008, 02:28 PM | #13 | |
8
Rep 315
02-18-2008, 07:28 PM | #14 |
126
Rep 993
Drives: F85
02-18-2008, 09:39 PM | #15 |
8
Rep 315
Did you try to reset the transmission? It is really easy to do. It even got rid of the rediculous lag that existed in D upon starting from a stop. Mine used to jerk forward pretty bad when the car was warming up in the morning.
02-18-2008, 09:59 PM | #16 |
126
Rep 993
Drives: F85
02-19-2008, 11:10 AM | #17 |
8
Rep 315
Put the key in the slot (I had all the doors closed, not sure if that makes a difference or not, but BMWs computers are strange sometimes), and push the start button without your foot on the break (that will put the car in accessory mode and the electronics will start up). Push down the gas pedal until it clicks and hold it there for 30 seconds. I heard a noise from the car at about 30 seconds which sounded like a noise the car makes after you turn it off after driving it (that may have been by chance). After 30 seconds, let your foot off the gas, push the break and press the start button, starting the car up. Done. Simple, no? My car has not jerked forward since I reset mine.
06-16-2008, 04:02 PM | #19 |
118
Rep 393
I have a 2008 328xi with Bridgestone RE050AII RFT's. I only have 5000 km on the car so far but have noticed that my tires are already scalloped. Someone told me that they thought there was a TSB regarding this. Does anyone know if that is the case?
07-08-2008, 01:22 PM | #21 |
20
Rep 374
Actuall two are out; one for a series of 2007 builds (just a week or so in Jan 07) and the 2nd for several months of 06 builds. You should be checking the "turbo" section http://www.e90post.com/forums/showth...light=bulletin
Member - Knights of the Roundel (bimmerdriver s.com)
Over 58 runs of the ToD (or 18,444+ curves) |
09-26-2008, 08:07 PM | #22 |
20
Rep 374
Updated list of SIBs for most models through mid September '08.
