01-03-2015, 10:38 PM | #68 |
10539
Rep 41,178
Drives: 2018 Alpina B6 650ix GC
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
01-04-2015, 11:24 AM | #69 |
Rep 35
01-18-2015, 11:37 AM | #71 | |
10539
Rep 41,178
PM sent.
01-18-2015, 01:06 PM | #72 |
Rep 41
Hi Swan,
thanks,unfortunately I don't get the errors away. I accidentally VO coded all ECU instead of only the needed for 3AG. I now have error Drivetrain and fuel pomp. any option that I have? |
01-18-2015, 01:20 PM | #73 |
10539
Rep 41,178
Does your DME module have CAFD with Green Dot?
01-19-2015, 12:37 AM | #74 |
Rep 41
01-19-2015, 05:51 AM | #75 | |
10539
Rep 41,178
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on DME => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level shown => Select OK => Right-Click on DME (the ECU itself not the underlying CAFD) => Select CODE. With DME, Motor cannot be running when you code it.
01-19-2015, 10:50 PM | #77 |
10539
Rep 41,178
You don't need to buy a Token for anything anymore as TokenMaster released free E-Sys Launcher Application with built in Token Generator.
01-22-2015, 05:07 AM | #80 |
10539
Rep 41,178
PSdZData and an ENET Cable to go with E-Sys.
01-26-2015, 02:09 AM | #82 |
38
Rep 130
Hi Shawn,
Could you send me the download link of latest Ediabas? Actually, I need tool32 for erasing error code. I'm using 32bit Windows. Mine is F20, is it correct for me to select 01.prg or other .prg? Thanks! |
01-26-2015, 02:11 AM | #83 |
38
Rep 130
Shawn,
I have another question and I'm sorry that I have so many questions. I found you mentioned ISTA/D Reingold, which is a diagnostic tool. Do you know where I can get this? Thanks again! |
01-26-2015, 05:30 AM | #84 | ||
10539
Rep 41,178
PM sent.
01-26-2015, 04:36 PM | #86 |
10539
Rep 41,178
PM sent.
01-27-2015, 09:21 AM | #88 | |
Rep 41
thanks for your help. I was able to fix this problem. I only have one problem that i don't get away. After coding my rear PDC stopped working. every time i put it in reverse i get error "no parking assistance, have the problem checked by service" I already have put the old CAFD for Hu-CIC and REM, but the problem remains. any suggestions? Lucardos |
