09-25-2014, 05:31 PM | #23 |
340
Rep 1,089
I just dropped mine off also. They said it's a radial pull and they will swap front wheels side to side which I already tried and if no change then they will do an alignment. Will post back once I know more!
09-26-2014, 11:29 PM | #25 |
340
Rep 1,089
I just got my car back and they did a slight adjustment but I haven't got a chance to truly test it out yet. Will report back tomorrow and at the mean time take a look at the alignment sheet.
09-28-2014, 01:11 PM | #26 |
2756
Rep 3,362
I'm guessing the "spec" values shown are *not* those for an F8x car. Note the front camber spec value 0.19' is ~1/3 of a degree of negative camber, and the tolerance is shown as +/- 0.5 degrees. This is way too little negative camber for the front of an M3/M4, and there's no way the BMW spec would allow a range that goes into positive camber.
This is pretty much proven by the actual measured front camber on your car. Note that it shows -1 degree 22' which is about -1.3 degrees camber -- that sounds about exactly where I'd expect the M3/4 front camber to reside. They obviously don't have the proper set of specs loaded into their alignment machine yet for the F8x.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
09-28-2014, 01:21 PM | #27 | |
340
Rep 1,089
09-29-2014, 09:12 PM | #28 |
22
Rep 62
So I just picked up my car from service with extra 120 miles and <10mpg average again... They made no adjustments and only solution from SA is replacement steering rack on order
09-30-2014, 07:17 AM | #30 |
2756
Rep 3,362
Thanks for the update. Hey, at least it appears your dealer actually has the correct alignment specification update for the F8x loaded into their rack machine. Keep us posted on the outcome. If it is indeed the rack, issues like these are not unusual during initial parts production periods during a new model launch...regardless of the manufacturer.
Current Stable:
09-30-2014, 08:01 PM | #31 | |
340
Rep 1,089
Thank you for sharing your data with us, much appreciated!
After getting my alignment is a lot better than before, I don't need to constantly adjust my steering when tracking straight and when I let go of my steering it still goes to the right but it feels more like a tire pull now then an issue with the alignment. |
