12-26-2016, 07:25 PM | #309 |
Rep 123
Shawn I am confused. Some say you cant VO code with the engine on you must use a constant power source others say you can. What modules can or cant you VO code with the engine on? Thanks for the help.
12-26-2016, 07:29 PM | #310 | |
10547
Rep 41,232
Drives: 2018 Alpina B6 650ix GC
"20) Ensure Car has adequate power and is switched on. *NOTE: A continuous power source of at least 12.6 Volts is needed. Failure to maintain proper voltage can lead to corruption of ECU Data. As such, ideally the car is connected to an external charger. In lieu of using an external charger, the car can instead be coded with the engine running in order to maintain proper voltage, which is acceptable for coding all ECU's EXCEPT the DME (Digital Motor Electronics) ECU or DDE (Digital Diesel Electronics) ECU. The DME/DDE are typically not coded anyway, so this ECU limitation is generally not an issue."[/QUOTE]
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
01-05-2017, 02:47 PM | #313 |
10547
Rep 41,232
PM sent.
01-18-2017, 06:04 AM | #315 |
Rep 1
Hi Shawn,
I got esys and psdzdata lite from http://www.bmwesys.com/guides/Beginn...e%20Coding.pdf I have an airbag warning after I tried to upgrade my F20 - 2014 cruise control, using http://www.bmwesys.com/guides/DIY%20...0F30%20F20.pdf I have an enet cable and can connect in esys and read the FA etc. I tried the transmitters option in esys but nothing happens. Any suggestions ? |
01-18-2017, 11:19 AM | #316 | |
10547
Rep 41,232
02-18-2017, 06:12 AM | #317 |
649
Rep 1,387
I seem to be having trouble with tool32. I hit f3 and loaded "F01.PRG" but it just hangs on a white window.. I have both K-DCAN cable and OBD cable, does it matter which to use a I have tried both.
I am basically trying to clear an error code "Driver restraint system" as I had to start the car with no air bag connected. Any help is much appreciated. Edit: Ran tool32 as administrator and with my OBD cable, all fixed sorry for the double post!
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) Last edited by fortythirtyfive; 02-18-2017 at 06:26 AM.. |
02-19-2017, 02:19 AM | #318 |
284
Rep 703
Hello Shawn can you sent me tool32 also. Thanks!
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
02-19-2017, 08:59 AM | #319 |
10547
Rep 41,232
02-23-2017, 02:43 PM | #321 |
10547
Rep 41,232
02-26-2017, 01:23 PM | #322 |
Rep 1
Shawn, same here please - could you please share a link to tool32? I have a break pad warning light (although pads are brand new) that gives me a "reset unsuccessful" message through the standard method. I an wondering if Tool32 can solve this?
Thanks! |
02-26-2017, 01:26 PM | #323 |
10547
Rep 41,232
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 02-26-2017 at 01:46 PM.. |
03-01-2017, 09:26 PM | #324 |
Rep 12
Shawni have enet and the latest data files.
I changed my airbags and cant seem to flash the ACSM. I tried one of the tutorials online and it completed in 2 seconds but with the same airbag errors. Can i have the version of tool32 that can do the clearing? Thanks |
03-01-2017, 11:21 PM | #325 |
10547
Rep 41,232
PM sent.
03-17-2017, 06:41 PM | #326 |
508
Rep 2,152
shawn can you hit me up with the latest files please mate. both esys and tool 32
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
03-17-2017, 06:42 PM | #327 |
10547
Rep 41,232
PM sent.
03-22-2017, 07:53 PM | #329 |
10547
Rep 41,232
PM sent.
03-24-2017, 01:49 PM | #330 | |
61
Rep 166
About a year ago I retrofitted an m sport steering wheel. So last week I was driving on a bumpy road and suddenly the airbag light comes on. When I got home I opened up the steering wheel and apparantly I didn't secure one of the connectors and it got a little loose. I secured it properly but the warning stays on the dash. Would it be possible to clear the faultcode with this? |
